Old 04-14-2012, 07:49 PM   #1
d_mpls OP
Oddometer: 72
1978 bmw r75/6
Hello I have been looking at buying an airhead for a while (i posted on this forum already asking advice)
I found one (actually someone from this forum found it and sent me the link) that seems pretty interesting
1978 BMW R75/6
30,541 miles
cosmetically ok, not great, it has a non matching windjammer.
asking $3000
I went to see the bike, all seems good to me with the exception of the following and i would like to hear some more experienced people tell me if i'm heading in the right direction or not.
ISSUE 1:
The is an oil leak coming from under the bike, initially i thought it was the oil pan gasket, but upon inspection i noticed that the oil comes from a wire/bolt on the left side (maybe the oil sensor). Initially the oil was just one drop, but after starting the bike i saw another 6-7 quickly coming down (especially after i pushed the throttle at higher rpm)
here is the image of the bolt
http://www.mediafire.com/?yg5a9wgqlsjk8p2
here is the image of the area above the pan, which seems to have quite a bit of oil
http://www.mediafire.com/?gujyrwpvzluz8z3
ISSUE 2:
The bike seems to take a little to warm up, is 2 minutes with the choke on too much before being able to have no hesitation, or common for this kind of bikes?
ISSUE 3:
When the bike was started some water dripped down from somewhere on the left side. I think it was from one of th exhausts, but the water was more or less near the center of the bike, odd. Can someone tell more about this? Common? Scary?
Bottom line, Does it seem like a decent bike for the price?
Thank you id advance people!
d_mpls is offline   Reply With Quote
Old 04-14-2012, 07:57 PM   #2
bmwhd
God Bless Texas
bmwhd's Avatar
Oddometer: 1,476
I think issue number one is that if it's a '78 it's an R80/7, not an R75/6
Perhaps I could interest you in: http://www.advrider.com/forums/showt...3#post18457523
Todd R.
'78 R80/7
'06 FJR1300A
"Gentlemen, gentlemen, be of good cheer, for they are out there and we are in here!" - Robert Culp, attributed by Hugh Hefner as the official slogan of the Playboy Mansion
bmwhd is offline   Reply With Quote
Old 04-14-2012, 08:26 PM   #3
ritetwist
ritetwist's Avatar
Oddometer: 178
The switch is the oil pressure sensor,it has a gasket under it.I am not sure if it can be tightened,I'm quite sure it
cannot be bought seperate from BMW.Probably have to change the switch(relatively inexpensive).
The leak on the back of the pan is most likely from the neutral switch, quite common and much discussed.
Seems to be a weak point.Check procedure to replace.
On the warm up,some seem to take more time,I don't think that is a bad thing but some tuning may be in order.
The moisture is from the exhaust (condensation).
I am not sure about your model or year, you can check against the SN.
Good luck.
Afraid to sleep for fear of missing something.
ritetwist is offline   Reply With Quote
Old 04-14-2012, 08:49 PM   #4
d_mpls OP
Oddometer: 72
Nice, thanks for the info!
When you said ..."cannot be bought separate from BMW", what do you mean, that there is no after market?
Good luck.
Old 04-14-2012, 09:13 PM   #5
ritetwist
ritetwist's Avatar
Oddometer: 178
I would try an aluminum or maybe a copper gasket of the right size. ( 12 X 16 mm ?)
Old 04-15-2012, 03:50 AM   #6
Horsehockey
A GPS? Huh?
Oddometer: 328
First, what's the VIN number (stamped into the engine case, immediately above the dipstick)? That number will determine what year bike (engine) you're dealing with.
http://bmbikes.co.uk/enginechassis.htm
General comments:
Second, for your planning purposes, if you actually want to "fix" everything that will have been neglected on the bike and make it really roadworthy, plan on putting about another $2K into it over the next year or two. A bike like the one you describe sounds like it needs a new oil pressure switch (the leak) and other deferred maintenance on a new-to-you airhead typically involves tires, battery, replace all lubes, any new cables needed etc. The oil accumulation on the "shelf" under the engine is either a leaky neutral switch, leaking rear main seal or leaking oil pump cover. None of this is a huge dealbreaker but the replacement or repair of anything other than the oil pressure switch is more involved. Lots of guys run their bikes with weeping in these locations....
Use of the choke for a couple minutes in Minneapolis in April sounds about right. The "water" leak question is odd...maybe just condensation from the exhaust. That could be sorted out.
If you would prefer to just buy a bike and ride, you probably should look for a newer bike. These old airheads can be brought back and can be superbly reliable for lots and lots more miles (mine has 96K on the clock now), but time, money and effort are required.
Horsehockey is offline   Reply With Quote
Old 04-15-2012, 12:14 PM   #7
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,571
If the bike is actually an R75/7 I`d be buying it in a flash. BMW didn`t make many 750cc /7`s before increasing the capacity to 800cc; They are quite rare.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 04-15-2012, 01:09 PM   #8
LonerDave
LonerDave's Avatar
Oddometer: 120
The oil sensor sometimes leaks through the switch itself (where the wires come out). If that's the case, a new gasket won't help. I bought a replacement switch from Auto Zone for less the $10, IIRC. Equivalent parts are listed in a sticky at the top of this forum, or search. Take a closer look for the source of the leak before you buy parts.
LonerDave is offline   Reply With Quote
Old 04-15-2012, 05:48 PM   #9
d_mpls OP
Oddometer: 72
Thank you for the info
Thank you everybody for the info and the tips, this is exactly the kind of help that i was looking for.
I'm not looking for the perfect bike, in the end i love these airheads and i'm willing to put up with spending some money.
Times are GMT -7.   It's 06:55 PM.
