04-15-2012, 03:22 PM
#16 | |
Oddometer: 3,000
Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
04-15-2012, 03:24 PM
#17 | |
Oddometer: 3,000
![]() Spud
04-15-2012, 03:25 PM
#18 |
Oddometer: 3,000
04-15-2012, 03:39 PM
#19 | |
Oddometer: 3,000
My oil cooler installation is quite solid, and doesn't rattle. However, the installation does have enough flexibility to absorb vibration from riding. The 3/8-inch elbows have 4 hose barbs on each end, so I am confident they will not leak. I seem to be getting sufficient airflow from my drilled fender. However, I plan to cut a window in the fender, and install wire mesh if it is necessary to increase airflow. I'm still experimenting with this installation, so I appreciate all constructive input. If I encounter any problems with my current configuration of this oil cooler, I will be certainly report them. Spud
04-15-2012, 04:18 PM
#20 | |
Oddometer: 3,000
![]() I can't fool you, Brian! I invested in hose clamp stock just before I started this project. I mounted the oil cooler as high as possible while still maintaining good clearance with the forks when turned to full lock at both left, and right positions. Here are a few photographs to show the full lock, fork positions. ![]() ![]() ![]() ![]() ![]() ![]() ![]() I don't doubt the wheel would contact the oil cooler with full fork compression. However, I don't ride the bike hard enough for that scenario to concern me. If I jumped the bike, or even came close to using full fork compression, I would not have mounted my oil cooler in this location. I haven't measured for clearance of the oil cooler with full fork compression. However, the doctored photograph below simulates the amount of fork travel available before the wheel impacts the oil cooler. Incidentally, my front fender is now in a different position than the one shown in the photograph. ![]() If I pushed my "piggie" this hard, I certainly wouldn't consider mounting my oil cooler in its present location. However, I plan to ride my KDX220 in the nastier terrain, so I wanted to install an oil cooler for sustained, high engine rpms while riding on the freeway. I am confident I have enough fork travel available for the off road riding I have now reserved for my XR650L. During the design process for this oil cooler I conferred with my friend Andy, who is an experienced trail rider, and an experienced mechanic of 30 years. I have ridden with him a lot, and he doesn't think I will ever hit the oil cooler with my front wheel. He is also convinced this design is durable, and will not fail me. However, only time will tell. I will be sure to report any problems I encounter with this design. ![]() P.S. Thank you for the kind words. Spud
04-15-2012, 04:43 PM
#21 | ||
Pig Wrangler
Oddometer: 1,607
04-15-2012, 05:25 PM
#22 | |
CDI REPAIR
Oddometer: 3,421
I`m just concerned that if you hit the brake hard while in a dip in the road that the tire may contact the fender or cooler and launch your butt over the bars when the tire stops turning........so don`t be posting pics of you squished against tree....don`t wanna see you get hurt bud ![]() Otherwise it looks sturdy enough..but i`d paint the hose clamps black,,it`d blend in better,,the ones Mark provided were black,,not as noticeable... B
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.FCR MX pumper.42/158 NVCT needle.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
04-15-2012, 06:39 PM
#23 | |
Oddometer: 3,000
I might do as Red suggested, and pop the caps off the forks as an experiment.Incidentally, I agree with you regarding the Sutton oil cooler. Mark's oil cooler is not only very functional, it is a work of art. Mark's oil cooler is also, obviously, a labor of love. I doubt Mark makes more than $0.25/hour fabricating all the parts for his excellent oil cooler. ![]() Spud
04-15-2012, 06:53 PM
#24 | |
Oddometer: 3,000
I can tell the oil gets mighty hot inside these engines, and I decided adding an oil cooler was a good idea, since I removed the stock air scoops when I installed my aftermarket fuel tank. Also, I wanted to be able to monitor the oil temperature with the digital, TTO temperature gauge. Now, if the oil temperature rises too high, I can at least back off the power, or stop the engine until it cools down. ![]() Removing the spark plug is not any more difficult after installing my oil cooler. My oil hoses are all routed away from the spark plug, so they do not hinder access to it. Spud
04-15-2012, 07:00 PM
#25 | |
Oddometer: 3,000
The oil hoses are located behind the forks, and well inside the outside edge of the fuel tank. In fact, the oil lines are located just about even with the edge of the engine cylinder. Therefore, I think the hoses are well protected. However, I will report any problems I might encounter. Spud
04-15-2012, 07:05 PM
#26 | |
Oddometer: 3,000
I haven't changed my fork oil yet. How difficult would it be to get the caps back on if I made a quick check in this manner?A while back someone posted a photograph of his bike with the forks fully compressed after a jump. One can't always tell from photographs, but it sure looked as if the wheel would hit my oil cooler in a similar situation. Spud
04-15-2012, 08:39 PM
#27 | |
04-15-2012, 09:10 PM
#28 | |
Oddometer: 3,000
Please note, I intentionally installed my temperature probe in the oil line closest to the engine, before the oil enters my oil cooler. ![]() I placed the probe in this location in order to get a reading as close as possible to the temperature of the oil inside the engine. In contrast, the XRs Only temperature gauge is located in the oil reservoir, which probably contains the coolest oil in the system. If someone will loan me an XRs Only temperature gauge, I will be glad to compare the temperatures simultaneously, at both locations. I would return the XRs Only temperature gauge after a few days of experimentation. ![]() Spud
04-16-2012, 10:16 AM
#29 |
Oddometer: 3,000
As I said earlier, I suspect the front wheel might hit the oil cooler with full compression of the forks. This is a valid concern, so I want to provide some additional information. I have installed a lowering link, and raised my forks 1-inch in the triple tree. I don't know how much free sag I have with my current forks. The doctored photograph below shows approximately how much the front wheel can travel before it impacts the oil cooler on my lowered motorcycle.
![]() I think I can raise the oil cooler about an inch, if necessary. I can also trim the rear of the fender so the wheel will not grab it long before it would impact the fender. When I get a chance, I will lift the front wheel and see how much free sag I have in my forks. ![]() Spud
04-16-2012, 01:53 PM
#30 |
Oddometer: 441
Good job Spud!
we need more fabricators out there doing stuff like this! don't let the nay-Sayers get you down,(from reading several different forums) also on a side note,I keep reading about how bad it would be if you got mud on your cooler (from several different forums)...um...the oil will still be cooler then without a oil cooler...to think that somehow getting mud on your oil cooler will make it hotter then running no cooler at all just doesn't make sense.
2007 XR650L, Looking to acquire a stock XRL choke plunger. KyoXR screwed with this post 04-16-2012 at 02:12 PM |
