Old 02-01-2013, 07:10 PM   #91
bwalsh
bwalsh's Avatar
Oddometer: 11,904
Nice work there super samurai! I may have to order on of those coolers and do some fabrication work.
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is online now   Reply With Quote
Old 02-01-2013, 07:11 PM   #92
super samurai
super samurai's Avatar
Oddometer: 316
This is howi ran my lines. Picked up some hose rated to stand up to oil from belfair hose and supply, but they should have some at any auto parts store.
They are not ran anywhere that heat from the exhaust will be an issue.
I had to use one little 90 deg. Stainless elbow on the line going up.
i know my clear tank is ugly!
super samurai is offline   Reply With Quote
Old 02-01-2013, 07:19 PM   #93
super samurai
Oddometer: 316
The cooler is tilted back towards the tank slightly.
Dont take this as an expert set up or that i know what i am doing!:what:
I know it is not in direct air flow but it will deff. Get some flow. Thinking more of the heat radiation which is when these bikes get hot at low speed hard riding. I do have a thermo dipstick so i can monitor temps.
It would be easy to tap into a line to put a tto gauge later also.
This whole set up was less then $50 doing it all myself.
A welder, 4in cutoff wheel and 4in flap disk sander wheel for a small angle grinder.
The paint was called noble shelter paint that seems to match the stock frame when new.
Old 02-01-2013, 07:31 PM   #94
Spud Rider OP
Spud Rider's Avatar
Oddometer: 3,785
You did a nice job, Samurai! Thanks for documenting your work with photographs, and adding your knowledge to this thread.
Did you record oil temperatures before adding this oil cooler? If so, I would like to hear how well the oil cooler is reducing oil temperatures under the same riding conditions.
Spud
Old 02-03-2013, 08:00 PM   #95
super samurai
Oddometer: 316
Sorry spud i didnt record like you had done. It is winter and it has been sitting in my wood stove heated garage.
I have not rode in awhile, been 4 wheeling. But i do recall what it was running at temp. Wise in my head. I figure anything will help. When i get out and ride when the temps are warmer or possibly sooner i will report back. Next will be the daves mods. I dont think it has been done to mine. Ohh and i picked up another stock muffler to cut open and modify.
Old 02-03-2013, 08:03 PM   #96
super samurai
Oddometer: 316
They are spendy little coolers but are made pretty good, all steel.
If you can fabricate at all it is easy, mostly time spent deciding where and how to run lines and place cooler.
I placed mine diff. Cuz i didnt want to cut and lower fender. So other options are there.
Old 09-15-2013, 04:26 PM   #97
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,404
Did you use all .375ID hose?
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 09-15-2013, 08:15 PM   #98
Spud Rider OP
Spud Rider's Avatar
Oddometer: 3,785
Yes, I used 3/8-inch hose I bought from the local, auto parts store.
Spud
Old 09-17-2013, 07:47 AM   #99
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Location: Da frozen tundra eh? 1.5 mile west of Lambeau
Oddometer: 726
Some excellant development and results. Makes me want to plan something similar for my eventual Retro-Motard project on my old XL600. But I do have some comments that I'm not sure have been addressed:
  • Oil temps come down with the cooler, but temps above 200 F are still pretty high for engine oil in general. Use synthetic oil only?
  • Air flow behind any fender is marginal at best, so a cooler placement off to the side would be more beneficial, but more complex.
  • Flow rate/time through the cooler also impacts effective cooling, so a low restriction cooler is required because its on the low-pressure return side of the system. Flow from the bottom (inlet) to the top (outlet) of the cooler may also bring down the temps.
  • Hose temperature rating and inner tube material, must be compatible with the application.
  • Minimize the number of connections whenever possible. I applaud the idea, but WAY too many connections and hose clamps. Better hose routing and longer hose runs would simplify it.
I have worked in hydraulic hose applications for nearly 20 years. Even a low pressure hose, when at temps above 180 F, can soften significantly, and loose the ability to maintain compression on the connection points to avoid leaks. Barbed connections, especially with hose clamps should be carefully applied. Connections with sharp barbed edges, used with hose clamps, can actually cut the hose inner tube and create leak routes in your oil system.
Over time and heating cycles, hose will "thermal set" meaning it looses the "spring" needed to maintain a seal. Worm clamps loose their holding ability after the hose thermal sets, and leaks can develop. A constant-tension style hose clamp, or one that continues compression as the hose sets is better.
Use beaded tube style connections where possible, along with a constant tension style hose clamp to minimize degradationo of the connection over time.
Most low pressure hoses are not rated for oil over 212 F. Some are rated for oil up to 257 F, and some (a few) are rated to 300 F. Better to select the higher rating whenever possible. Your temp guage may read 225 F, but hot spots in the system are very likely as temperature is not always uniform in the system. The hose inner tube MUST be rated for the fluid and temperature. Otherwise the inner tube can/will break down, and possibly clog the return flow of the system and starve the pump.
When life throws you a curve,.....lean into it!
42+ year rider, 22+ year MSF Coach, Street, Dirt, Ice, ride em all!
Andyvh1959 is offline   Reply With Quote
Old 09-17-2013, 04:57 PM   #100
joexr
Oddometer: 3,773
Your reputation precedes you.
Old 09-20-2013, 05:33 AM   #101
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Oddometer: 726
Ok, I know I'm wordy, and not too exciting. Been around hose too long maybe? Just points to consider based on what I've seen.
Old 11-04-2013, 07:03 AM   #102
LexLeroy
Chief Mansplainer
LexLeroy's Avatar
Oddometer: 2,429
Aeroquip FC332 hose is rated for oil up to 300 degrees F but it doesn't make sharp bends - so use fittings or bends made from 3/8" .028" wall tubing . Hose clamps are from McMaster-Carr, their tensioning screws replaced w/ 4mm socket-heads... just 'cuz I like 'em.
Haven't gotten around to fabricating a stone guard but I'm still considering a 4"x4" Baker Precision cooler mounted up high 'n tidy. Winter's coming and I get bored easily.
"They're smarter than you son... that's why they're the police."
LexLeroy screwed with this post 11-04-2013 at 04:48 PM
LexLeroy is offline   Reply With Quote
Times are GMT -7.   It's 06:18 PM.
