Old 04-25-2012, 04:04 AM   #16
blaster11
I'm back!
blaster11's Avatar
Oddometer: 7,051
Originally Posted by GH41 View Post
I guess I have to do everything for you. Here you go, http://www.vibrationmounts.com/Store...=Products1.htm GH
I guess if you had some idea what you were looking for you wouldn't continue posting useless links...wow your so smart!
blaster11 is offline   Reply With Quote
Old 04-25-2012, 09:32 AM   #17
epicxcrider
epicxcrider's Avatar
Oddometer: 647
Ricochet sells a set, but I don't know if they are poly or oem style
Old 04-27-2012, 02:48 PM   #18
DabsAlot
DabsAlot's Avatar
Oddometer: 302
McMater Carr
[QUOTE=Dorito;18463354]Does anyone make aftermarket Skidplate isolators out of poly urethane?
http://www.mcmaster.com/#vibration-d...mounts/=haji8p
2009 BMW F800GS
2008 KTM 250 XCW
2008 Yamaha WR250R
2005 Gas Gas 280 Pro
1975 Yamaha TY-175
DabsAlot is offline   Reply With Quote
Old 07-28-2012, 11:58 AM   #19
epicxcrider
Oddometer: 647
So say I was riding it like it was a dirtbike (hypothetically) and I tore two of the mounts in half. What would be the best way to get the remaining half out???
Old 07-28-2012, 01:42 PM   #20
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 602
Old flat tip screwdriver, or a chisel, and CAREFULLY tap the edge counter clockwise to unscrew it.
Ryan
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 07-28-2012, 02:05 PM   #21
epicxcrider
Oddometer: 647
Old 07-28-2012, 11:23 PM   #22
greenthumb
b00b
Oddometer: 250
Originally Posted by Maxacceleration View Post
......Or maybe a hex surface to grab on the isolators....
Funny, my '09 has hexagonal mounts, and the stock plastic plate has matching recess that they lock in to. Maybe this is a feature aftermarket guards should incorporate into their design. I usually back up the rubber side with a wrench and it prevents them from twisting off.
greenthumb is online now   Reply With Quote
Old 07-30-2012, 06:15 PM   #23
epicxcrider
Oddometer: 647
Well I got one off, the other is being quite stubborn. Gonna have to figure out another method for that one.
Times are GMT -7.   It's 08:41 PM.
