Old 04-15-2012, 05:20 PM   #1
gearguywb OP
Oddometer: 115
Garmin 665 Sat radio antenna..
Any suggestions on where to mount the 665's antenna for the sat radio? I have seen a couple mounted on top of the brake reservoir. Not sure if that was done with velcro or ?
gearguywb is offline   Reply With Quote
Old 04-15-2012, 07:36 PM   #2
Okie Preacher
Okie Preacher's Avatar
Oddometer: 867
That is what I have done with mine. Heavy-duty double stick velcro and it has sat there for thousands of miles. And...the 665 has been flawless!
Okie Preacher is offline   Reply With Quote
Old 04-15-2012, 08:46 PM   #3
OkieTom
OkieTom's Avatar
Oddometer: 632
You might want to fill in your profile, it's kind of hard to offer advice when we don't know what kind of bike you have.
"If you have to ask,
You wouldn't understand"
2005 1200GS "The Big Red Pig"
OkieTom is offline   Reply With Quote
Old 04-15-2012, 11:22 PM   #4
darrendeep6
BMW Dirty Dozen
darrendeep6's Avatar
Oddometer: 286
In between the lower windscreen mount. Velcro, no reception problems.
darrendeep6 is offline   Reply With Quote
Old 04-16-2012, 04:17 AM   #5
mikegc
mikegc's Avatar
Oddometer: 1,622
When I got my 665 in January of 2010, I made a little aluminum plate and used silicone seal to attach it to the bike right behind the windscreen. It has been across the US a couple of times and, so far, it has been fine:
I hope this helps.
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 04-16-2012, 04:40 AM   #6
gearguywb OP
Oddometer: 115
Thanks guys!
Old 04-16-2012, 06:09 AM   #7
camnowell
Still a n00b
camnowell's Avatar
Oddometer: 37
I mounted mine in the same place as mikegc, but just used velcro strips instead. It's been holding there with no issues since I bought the bike in January. I was able to tuck the extra wire in behind the GPS as well so that it looks nice and neat.
camnowell is offline   Reply With Quote
Old 04-16-2012, 10:40 AM   #8
OHRider
BMWMOA, BMWRA, AMA (Life)
OHRider's Avatar
Oddometer: 157
Gxm 40
Garmin says “The GXM 40 antenna should be mounted at a minimum of 10 (4”) cm away from the zumo 665. An ideal distance would be at least 30 (11.8”) cm between the devices. If the GXM 40 is mounted closer to the zumo then you may experience interference that can interrupt the XM signal. “ I did have mine mounted on the front breaker reservoir and I did have problems. So I moved it to the beak on the front fender with Velcro.
Al
Warren, OH
01 R1150GS
00 R1100RT
07 KLR650
84 RZ350
73 R75\5 LWB
BMWMOA. BMWRA, AirHead, AMA (Life)
OHRider is offline   Reply With Quote
Old 04-16-2012, 01:59 PM   #9
Snarky
Vodka Infused.
Snarky's Avatar
Oddometer: 1,342
This is true, I've tested it and it does seem to affect the signal a bit. But it's not that bad, it drops the XM signal by about a bar.
When I had my Versys I mounted the GXM 40 on the the passenger grab handle on a techmount on my alu-rack and ran the USB cable to the rear.
On my GS and threw caution to the wind and mounted the antenna to the GPS mount using a bracket.
I'm still fine tuning the adjustment of both the bracket and the mount, but I would like to think that the steel bracket the GXM40 is screwed into, helps shield the XM signal from interference from the Zumo 665 itself. It blocks the bottom of the entire antenna with a steel plate directly between it and the Garmin.
ALL ADDERS ARE PUFFS!
2012 BMW R1200 GSA, 2009 Kawasaki Versys (sold), 2001 Yamaha XT225 (sold)
PC Gamer? Support Star Citizen! Save PC Gaming and bring back Space Sims!
Pledge today! Service guarantees citizenship. @ http://www.robertsspaceindustries.com Thanks.
Snarky is offline   Reply With Quote
Old 04-16-2012, 03:05 PM   #10
mikegc
mikegc's Avatar
Oddometer: 1,622
My antenna is 3.5" from the unit and I've never had a reception problem. It works like a champ.
Mike
IBA 25881
mikegc screwed with this post 04-17-2012 at 03:48 AM
Old 04-16-2012, 08:01 PM   #11
darrendeep6
BMW Dirty Dozen
Oddometer: 286
Originally Posted by mikegc View Post
My antenna is 3.5" from the unit and I've never had a reception problem. I works like a champ.
Mike
Werd
Old 04-16-2012, 09:37 PM   #12
Brock
Brock's Avatar
Oddometer: 9
This is how I did mine, just with the bracket towards the windshield rather than over the GPS unit itself. When I had it over the unit, originally, it would impede the release on my locking mount.
I tried to locate mine similar to the location in post 5 when I first installed it. When driving north, either the GPS, dash, or my gigantic melon would block the signal of the satellites (in the southern sky, presumably, made worse being in Wisconsin). Having it just that little bit higher keeps the signal from cutting out ever.
Brock is offline   Reply With Quote
Old 04-17-2012, 12:45 AM   #13
dsy
dsy's Avatar
Oddometer: 89
Originally Posted by Brock View Post
When driving north, either the GPS, dash, or my gigantic melon would block the signal of the satellites (in the southern sky, .
I have mine mounted like mikegc also and notice the only time I have any signal cut out is when I'm headed North also. May have to try and raise it up some.
Doug
dsy is offline   Reply With Quote
Old 04-17-2012, 03:49 AM   #14
mikegc
mikegc's Avatar
Oddometer: 1,622
Originally Posted by darrendeep6 View Post
Werd
Yup
IBA 25881
Old 04-17-2012, 09:47 AM   #15
Iron Rey
Oh shit, not him!
Iron Rey's Avatar
Oddometer: 861
This is how I did it.
Iron Rey is offline   Reply With Quote
Times are GMT -7.   It's 06:15 AM.
