Old 04-16-2012, 03:36 PM   #16
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,060
Originally Posted by disston View Post
Talking about valve push rod tubes, not guides....snip...
Sorry I wasn't more clear on the analogy, but valve guides are way more robust than the tubes and even with a proper mandrel, it can be easy to ding or bend them up while driving them into position. Even with heated heads and frozen guides. DAMHIK.
P/R tubes, being more fragile, present an even greater opportunity to screw up.
However, given the success stories posted so far, I feel better should I have to do any of mine one day.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 04-16-2012, 05:13 PM   #17
Velocipede
Velocipede's Avatar
Oddometer: 455
I've given this problem a lot of thought over the years that I've owned and wrenched on Airhead Beemers.I am far from being a BMW Guru as some of the inmates undoubtably are but it occurs to me,where were the heads of the BMW engineers when they redesigned the motor and moved the pushrod tubes from over to under the cylinders.Why didn't they forget the tubes altogether and just cast the pushrod tubes into the cylinders.
I've owned Triumphs and BSA twins over the years and I've always found that it was easier to build an oil tight motor on a BSA with cast in pushrod tubes than a Triumph with external tubes.
John
Velocipede is offline   Reply With Quote
Old 04-16-2012, 05:21 PM   #18
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,666
I'll bet the reason is weight reduction. I don't know this for fact but think cast in passages would mean more weight.
The reason for moving the cam shaft from above the crank to below I don't know. I think I might have heard why that was but I forgot.
Crank on bottom was a selling point I think. My friends who rode /2s would tell me the center of gravity was lower.
---Albert Einstein
disston is online now   Reply With Quote
Times are GMT -7.   It's 06:25 PM.
