Old 04-15-2012, 05:36 PM   #1
Mane OP
Mane's Avatar
Oddometer: 399
Question Advice on R100GS handlebar risers?
Hi folks,
I'm looking to fit some handlebar risers to my R100GS and thinking about Rox Risers, but wonder if someone else has tried this before. My main concerns are fitment and lines length. Any comments?
Regards,
Mane
'94 BMW R100GS Bumble Bee
'08 Triumph Tiger 1050 (Sold it, solid performer)
'06 KTM 640 Adventure (Sold it and regret it since day one)
'03 BMW R1150GS Adventure (Death because of hopistalary infection R.I.P.)
"Never wrestle with a pig. You both get all dirty, and the pig likes it".
Mane is offline   Reply With Quote
Old 04-15-2012, 05:42 PM   #2
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 1,460
Originally Posted by Mane View Post
Hi folks,
Regards,
Mane
Yup got 'em at the time that I went to fat bars (ATV). They're good. No issues with cables.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 04-15-2012, 05:53 PM   #3
igormortis
igormortis's Avatar
Location: Moving further away from Wellington, New Zealand
Oddometer: 1,096
Happy with mine also. 3 1/2 inch risers with Pastrana FMX bend Protaper bars. No cable problems.
Operation: Battle Panda
igormortis is offline   Reply With Quote
Old 04-15-2012, 06:45 PM   #4
Mane OP
Mane's Avatar
Oddometer: 399
Thank you for comments...
Is this the correct size for the R100GS?
Pivoting Risers 2"x7/8"x7/8" Black Anodized
Regards,
Mane
Old 04-15-2012, 09:09 PM   #5
igormortis
igormortis's Avatar
Oddometer: 1,096
If you are keeping the GS handlebars, then yes, 7/8 is the right size. It’s close enough to the 22mm of the BMW bars.
Old 04-16-2012, 06:52 PM   #6
Mane OP
Mane's Avatar
Oddometer: 399
Thank you
Regards,
Mane
Old 04-16-2012, 07:14 PM   #7
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 3,005
Hi folks,
Regards,
Mane
You can use almost any bar riser for 22mm or 7/8" bars even if the application does not say R100GS. The worst case you would need to find the correct length 8mm bolts. In many applications you can re-route the cables and replace the brake line with a longer one. If you just want a raiser and not a set back Wunderlich are the best bang for the buck.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
bmweuro is offline   Reply With Quote
Old 04-17-2012, 09:43 AM   #8
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 601
I've got the Wunderlich 25mm risers and love em.
Makes a big difference in comfort, no issue w/ cables or brake line.
Might see an issue w/ the 35mm ones though.
Current: 93 R100GS, 04 XR650L
Prior: 73 CB350, 77 R100/7, 83 R100RT
I love every motorcycle I've owned and even some that I haven't.
ignatz72 is offline   Reply With Quote
Old 04-18-2012, 12:41 AM   #9
batoutoflahonda
Oddometer: 1,256
Well, depends. I put Rox on my R80G/S and had to swap the wire harness connectors under the tank, R/H side of the frame spine. With the bars tuned they were really strained, and the throttle cables pulled at full lock.. So if it's an early R100GS, or even a later model, I would pull the tank and check the wire and cable routing lock to lock.
I eventually took them off, as I'm 5' 6" and found sitting more up right put more pressure on my tail bone and over a distance was quite uncomfortable. Also, with the small fairing on the G/S and early R100GS, sitting more up right has you fighting the wind. A good rule of thumb is to make a fist and place your knuckles against the grips. This equals about an inch of set back and/or rise. Sit on the bike like that and see how it feels.
Rox does make a quality product.
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S
Save lives. Legalize lane sharing.
Cow eyes don't glow.
batoutoflahonda screwed with this post 04-18-2012 at 12:47 AM
batoutoflahonda is offline   Reply With Quote
Times are GMT -7.   It's 01:24 AM.
