Old 04-15-2012, 06:33 PM   #1
upsman OP
Oddometer: 256
1985 R80 squealing brakes
is there a fix for squealing front brakes on this airhead? sounds like the pads are glazed to me, should i take them out and sand them? thanks in advance for any advice.
upsman is offline   Reply With Quote
Old 04-15-2012, 06:36 PM   #2
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,523
Did you just get the bike? Is it a new rotor or new pads? Sometimes certain compounds of brake material don't get along with certain rotors. Remove the pads and measure material thinckness. You could be at the end of you pads.
Old 04-15-2012, 07:00 PM   #3
tennessee thumper
now in Mt. View, AR
tennessee thumper's Avatar
Oddometer: 739
check the snowbum bmw site for some possible fixes on this. New pads do not always solve the issue.
Things to try include
anti sieze on the backs of the pads
good clean of rotors and check the wear limit
sanding, as you mentioned
rebuilding the calipers if you have a pad rubbing due to a bad dust seal or dirty pistons
I think I did all these, in that order, including buying new pads to finally get my GS quiet.
I had a R100 Mystic that no matter what I did they were noisy.
tennessee thumper is offline   Reply With Quote
Old 04-15-2012, 07:04 PM   #4
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,728
you can also give a rotor hone a shot, this will rough up the surface for new pads.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 04-15-2012, 07:44 PM   #5
upsman OP
Oddometer: 256
1985 brakes
thanks for the tips, i will get to work on them this week.
Times are GMT -7.   It's 05:17 PM.
