Old 04-15-2012, 09:17 PM   #1
onestop OP
Oddometer: 85
R90/6 speedo repair
Hi I have just bought a 74 R90/6 and the odometer is broken as t keeps changing numbers and the rev counter goes all over the place can they be fixed if so where,
Can they be changed to the newer model that has the electric rev counter
thanks darryl
All roads are great.
onestop is offline   Reply With Quote
Old 04-15-2012, 10:56 PM   #2
FMB John
Oddometer: 20
Send a message to "wirespokes" he can set you up, he is currently doing mine.
1977 BMW R100S
2004 Kawasaki KLR 650
FMB John is offline   Reply With Quote
Old 04-16-2012, 07:21 AM   #3
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,190
+1 on wirespokes. He is the resident gauge person.
Those units are not usually considered DIY. I think using the electric tach should be an option but it's probably easier or cheaper to get the original working proper. They are not a problem when they work.
---Albert Einstein
Old 04-16-2012, 07:45 AM   #4
sebastianhammer
Oddometer: 33
thanks darryl
You can change to an electronic rev counter -- they come up on eBay every so often, but note that some include a 'window' for the high beam indicator, while others don't.
http://bmwmotorcycletech.info/tach.htm for info on the connections.
sebastianhammer is offline   Reply With Quote
Times are GMT -7.   It's 04:59 AM.
