04-19-2012, 10:09 AM
#31 | |
Albuquerque
Oddometer: 845
Heck, it wasn't until 1981 that they got electronic ignition ... the best "environmental" improvement they ever did to an Airhead. 2nd crossover makes a 38mm system equal (or larger) in volume to a 40mm system Guys just need to understand that it is 100% hype that aftermarket exhausts are an improvement worth the money. It's astounding how many experts have been born just by reading some advertising. It usually entails blaming the factory and blaming greenies and this thinking is as "conventional" and "me too" as the clothing found at Harley dealers.
Kent Christensen Albuquerque '12 R1200RT, '02 R1100S, '84 R80G/S |
04-19-2012, 12:53 PM
#32 | |
Oddometer: 359
BMW "improvements" over the years to the exhaust system, intake system, and cylinder heads on the R100RS have netted a loss of at least 10hp, lower comfortable cruising speed, and a rougher motor. |
04-19-2012, 01:17 PM
#33 | |
Mad Scientist
Oddometer: 2,966
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
04-19-2012, 04:16 PM
#34 |
Beemerholics Anonymous
Oddometer: 7,356
One of the 'improvements' robtg didn't mention was lower gas mileage as well. Go figure - EPA improvements should decrease fuel consumption, not increase it!
I'd also like to understand how crossovers increase the effective diameter of the exhaust system. With exhaust velocities what they are, I'm sure above 2K RPM all the exhaust 'sees' is added turbulence - especially since the Xover is at right angles to the flow. I thought the /2 didn't have a crossover.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
04-19-2012, 05:25 PM
#35 |
Oddometer: 871
Various thoughts
I haven't seen a pre-70 BMW with a crossover pipe.
I would think the primary performance advantage to the crossover pipe would be to aid in the scavenging effect. I am sort of thinking on the fly here, but bear with me (sometime this gets me in trouble). Cylinder 1 is on the exhaust stroke. Fast moving exhaust is steaming past the crossover pipe, this creates a slight vacuum in the crossover pipe. Just as blowing over the top of a straw in a glass of water picks up water out of the glass. Cylinder 2 is coming up on the compression stroke. Cam overlap still has the intake cam open just as the cylinder is begining to rise. Exhaust velocity is probably relatively high at this point since clyinder pressure is high as the begining of the exhaust valve opening. At this point the vacuum effect of the crossover pipe helps draw more fresh mixture into the other cylinder, scavening the exhaust out of the combustion chamber. This increases volumetric efficency making MORE POWER. Eric |
04-19-2012, 05:50 PM
#36 |
Oddometer: 10
pre-1970 crossover pipe
"I haven't seen a pre-70 BMW with a crossover pipe."
Sorry to rain on your parade, but my 1954 R-68 with the original exhaust system has a crossover pipe. |
04-19-2012, 09:32 PM
#37 | |
Oddometer: 871
Huh, I may have a lot to learn about what years have crossover. Remaining pro crossover. Eric |
04-19-2012, 10:02 PM
#38 |
Along for the ride
Oddometer: 912
For a better explanation of the crossover by Professor Wizard (David Visard) see his explanation in the Mustang forum:
http://mustangforums.com/forum/2005-...explained.html
__________________________________________ "There's a fine line between a skinning and a shearing" |
