04-16-2012, 03:38 PM
#1 |
do-over...
Oddometer: 115
Brake light switch relocation on cafe builds
Hello, another lurker gone active here... First off, thanks to all you who are so willing to share you knowledge, pretty much has got me this far... wouldn't have been able to do if not for reading your posts.
So I've been slowly working on a cafe build of my 72' R75/5 and have been doing some frame modifications.. One of which is to cut the ear flap looking brackets off the sides and make a set of rearsets work... Looking through my options for rearsets and what needs to happen for the brake lights to switch on I was wondering what others have done with that little switch. Here is a pic of what I've got so far... Well... can't seem to figure out how to add a pic... ah, got it. ">![]()
Leadnuts screwed with this post 04-16-2012 at 03:55 PM Reason: add pic |
04-16-2012, 04:48 PM
#2 |
the thread-killer
Oddometer: 4,297
Don't tell my local cops...........................I don't run one.
Most of the braking I do is with the front anyway. |
04-16-2012, 05:00 PM
#3 |
do-over...
Oddometer: 115
04-16-2012, 05:14 PM
#4 |
ShadeTreeExpert
Oddometer: 5,025
I have a switch only on the rear because the front one stopped working. Just the way things go. I use my brakes together almost always so I don't see a problem.
Never memorize something you can look up. ---Albert Einstein |
04-17-2012, 04:34 AM
#5 |
/5 dirt road wannabe
Oddometer: 342
You could easily add a "Brit" type rear switch that operates off the brake rod and not the pedal. Check out Lowbrow customs as a source.
04-17-2012, 01:57 PM
#6 |
Oddometer: 75
thats a good idea from old roadie
my old bsa had one of those, i might use that idea myself on the next project they're probably not dear to buy new |
04-17-2012, 02:25 PM
#7 |
Mad Scientist
Oddometer: 2,966
I don't run a rear brake switch on one of my bikes either.
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
04-17-2012, 02:48 PM
#8 |
Oddometer: 75
i would have none happily but it wouldn't pass the vehicle test over here
you guys must have it easy |
04-17-2012, 03:04 PM
#9 |
do-over...
Oddometer: 115
04-17-2012, 04:56 PM
#10 |
ShadeTreeExpert
Oddometer: 5,025
Well, in my state, Maryland, we only have to pass a safety inspection when a vehicle gets titled. After that it is emissions only except my bike is too old for emissions so I don't have any inspection. A cop can give you a ticket for anything of a safty nature, if he notices. Having a brake light switch on either the front or the rear would hardly ever get noticed. An inspector might catch it tho.
04-18-2012, 12:56 AM
#11 |
Anglo-Saxon
Oddometer: 426
I run an old style pull brake light switch from under the gearbox (off a lug welded onto the engine spacer rear right side) the switch has a spring that leads back to a small hole drilled into the bottom back edge of the brake lever. it works well is out of sight and out of the way. (its a legal thing in the uk for the ministry test - but if it was not needed I would not bother. Sorry cant do a photo today as bikes back in bits at the paintshop.
'A tourist sees what he went to see, a traveller sees what he sees' |
