Old 04-16-2012, 08:00 PM   #1
Hedge36 OP
Chasing parts.
Hedge36's Avatar
Oddometer: 45,738
I need more bikes.
Specifically, in a range of years simultaneously. Why? So I don't need to ask questions like:
IF one had all the parts, could the later-style airbox be retrofitted to the engine/gearbox of a late-70's? As I recall, the measurements of the gearboxes and engine blocks are the same, but I'm thinking the starter cover wouldn't line up properly.
To clarify, what're the odds of being able to replace this:
with this:
Hedge36 is offline   Reply With Quote
Old 04-17-2012, 01:59 AM   #2
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 836
More bikes, sounds like a plan to me.
Bulldust is offline   Reply With Quote
Old 04-17-2012, 04:20 AM   #3
pommie john
pommie john's Avatar
Oddometer: 1,474
When people ask me how many bikes I own, my answer is always "Almost enough"
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 04-17-2012, 09:11 AM   #4
rudolf35
Warped & Twisted Mind
rudolf35's Avatar
Oddometer: 797
Wicked More
My standard reply: More than I need and less than I want!
2013 Ural Gear-Up, 2008 Fatbob, 1999 Jeep Sahara, 1982 BMW R65LS, 1973 Honda CL350 K5, 1971 BMW R50/5
rudolf35 is offline   Reply With Quote
Old 04-17-2012, 09:19 AM   #5
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,257
with this:
IIRC the odds are good.
you have plans for the starter cover?
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is offline   Reply With Quote
Old 04-17-2012, 09:20 AM   #6
bmwloco
bmwloco's Avatar
Oddometer: 1,460
I have had 31 BMWs over the years. Mostly airheads, and R80G/S ridden where I logged most miles.
At one point, I had 13. It seemed like I was always buying tires, tuning up, or something was necessary. I ended up putting clipboards on the seats so I could log when each was last ridden, etc. Too many.
Presently 6 bikes and some sometimes a scooter. Just right. ;)
'66 BMW R60/2, '83 BMW R100RS,'81 BMW R100RS "Das Beast", '87 BMW R850R '77 Honda XL125
Airhead #371
bmwloco is offline   Reply With Quote
Old 04-17-2012, 09:57 AM   #7
Hedge36 OP
Chasing parts.
Hedge36's Avatar
Oddometer: 45,738
I suspect one would have to swap for the newer style cover, which should be a non issue if everything else fits well.
Old 04-17-2012, 10:04 AM   #8
mykill
odd
mykill's Avatar
Oddometer: 1,166
I could say i have too many. Tires and batteries become an issue. Sometimes I think I want to sell some off but the cash reward never equals the loss. There is always that empty feeling when you can actually see exposed floor in the garage.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 04-17-2012, 10:54 AM   #9
Nixels
Face fears - live life
Nixels's Avatar
Oddometer: 7,750
Does anybody read the OP's question in these threads or just blurt out their own thoughts?
Oh wait, it's AttentionDeficitVector
Nevermind
Coffee first, then all your other mundane bullshit. Benjava
SmugMug coupon: cwbkgu7KGL2D2/save $5
Nixels is offline   Reply With Quote
Old 04-17-2012, 12:35 PM   #10
knary
sunshine and puppies
knary's Avatar
Oddometer: 29,511
with this:
One is ugly.
One is not.
Why would you make your bike uglier?
p.s. those parts are entirely too clean.
Artist, Father, Etc | Oil & Piston
Go Jane Go - Analog Jane and her three chamber heart
Goodbye Toolfan
knary is online now   Reply With Quote
Old 04-17-2012, 01:28 PM   #11
supershaft
because I can
Oddometer: 9,116
I think it will work with the later starter cover as well. Then there is the crank breather setup to consider. I run my through the square airbox and out the water drain hole and then up around my rear fender and out the back by the license plate . It's about the cleanest setup I have seen IMHO. I wish I had a photo of it to post. One of the tricks to my setup is that 3/8ths automotive fuel line fits perfectly inside of the stock crankcase breather hose that goes to the box. With a bit of silicone on the outside of the auto line stuck up in there it leaks no oil there whatsoever for about 150,000 miles. With a properly maintained K+N filter and all the crankcase breather oil going to the outside, my box and snorkels stay almost perfectly spotless. No crap, no dust, not even any oil. Let me warn you that that will just about never happen with the stock paper filters.
I like the square airboxes. They are a lot easier to maintain IMO and I think they help midrange a lot at very little top end expense.
supershaft screwed with this post 04-17-2012 at 01:49 PM
Old 04-17-2012, 01:30 PM   #12
rambozo
rambozo's Avatar
Oddometer: 561
i just checked an 85 starter cover against 78 and 79 ones, the 85 one looks to be a tiny bit shorter than the two clam shell types, only by a milimetre or two if at all though
only difference i can see is the hump on the older ones to match the clam shell, might look a bit odd with the newer airbox
looks to me like it will fit but the newer low cover would probably look better
rambozo is offline   Reply With Quote
Old 04-17-2012, 01:33 PM   #13
Hedge36 OP
Chasing parts.
Hedge36's Avatar
Oddometer: 45,738
Thanks, guys. I think the later boxes are an improvement as well - certainly easier to get into and it saves wear and tear on the intake tubes over time.
Old 04-17-2012, 01:45 PM   #14
supershaft
because I can
Oddometer: 9,116
I don't think the original starter cover even shortened would allow you to run the square airboxes horns and I highly recommend running the horns with the square airbox. I prefer the one small and large horn setup over the two large on my bike even after I have tuned it with a sport cam, Dell's, port work. etc..
With just a little doctoring on the square airbox cover snorkels you can get them to fit almost perfectly and leave them. Something they rarely ever do on most beemers out there. You can file almost half of the velocity stack threads off Dellorto's and the stock square airbox snorkels fit perfectly right on Dell's just like a 32mm Bing with JUST a hose clamp for a much cleaner setup IMO over running a radiator hose there and two clamps.
Old 04-17-2012, 02:53 PM   #15
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
79 only starter cover. I like the look of the early starter cover but it is a 2 horse power loss.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Times are GMT -7.   It's 10:46 AM.
