Old 04-16-2012, 09:15 PM   #1
gerrynj OP
Oddometer: 137
R80 Gas tank
I bought a '86 R80RT a while back and based on the reviews I have read - I thought I had a >5 gallon tank. Well - I found out last week, that I do NOT have a >5 gallon tank. I almost ran out of gas after a 120 mile ride.
So this past week-end I emptied the tank completely and refilled it with 3.9 gallons of gas. Do I have an odd sized tank (it looks like the original) ? or was there an option when the bikes were new?
thanks
Gerry
gerrynj is offline   Reply With Quote
Old 04-16-2012, 10:11 PM   #2
supershaft
because I can
Oddometer: 9,116
Mine holds about 5.9 according to the pump the one time I had it completely empty. You have got to take the flap out to fill it that high. I have put 5.7 in it quite a few times.
Old 04-16-2012, 11:33 PM   #3
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,478
Some of the post 85 tanks have a flap in them that do not allow you to fill them up all of the way.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-17-2012, 07:47 AM   #4
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,493
thanks
Gerry
Are you sure you really drained it? Reserve on both petcocks? 3.9 is way small.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 04-17-2012, 11:18 AM   #5
bmwloco
bmwloco's Avatar
Oddometer: 1,415
It could have an R65 tank on it. That's the only one I can think of that has such a tiny tank in the "modern" boxer era.
'66 BMW R60/2, '83 BMW R100RS,'81 BMW R100RS "Das Beast", '87 BMW R850R '77 Honda XL125
Airhead #371
bmwloco is offline   Reply With Quote
Old 04-17-2012, 11:30 AM   #6
supershaft
because I can
Oddometer: 9,116
My R65 tank held just a few tenths less than my Mono tank.
I don't remember the exact method I used to remove the flap. I think I bent it and broke it off with some long needle nose pliers and then folded it up with the same pliers inside the tank and removed it out through the top.
Real soon I am planning on removing the entire welded on neck extension for the flap. I think then I will get a couple of more tenths in it. The internal vent might be an issue that full but I will soon find out. I don't want to do away with the internal vent since I always have a tank bag on and I really appreciate the cap not venting and filling up my tank bag with fumes. That's a great feature of an otherwise not so great system.
supershaft screwed with this post 04-17-2012 at 11:58 AM
Old 04-17-2012, 12:01 PM   #7
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,029
My R 80 ST tank is supposed to hold 5 US gallons according to the manual. I think I was only able to squeeze 4 or 4.1 into it after draining it.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Times are GMT -7.   It's 12:27 AM.
