Old 04-17-2012, 07:47 AM   #1
fiwi OP
Oddometer: 145
Torx Screws
Hello all. As far as im aware the small black plastic panels on both sides of the 800 are held on with 2 metal prongs plus a m5x25 torx screw. I have stripped out the housing that the screw screws into on one side. I want to drill out the housing, feed a longer torx screw through and fit a nut to the back. Im struggling to find torx screws that have the same head but are up to 50 long. If i can i would like to stick to the same looking fasteners that are on the bike. Any ideas?
fiwi is offline   Reply With Quote
Old 04-17-2012, 08:04 AM   #2
WRW9751
WRW9751's Avatar
Oddometer: 186
You might give Fastenal a try.
http://www.fastenal.com/web/Search.e...rm=torx+screws
WRW9751 is offline   Reply With Quote
Old 04-17-2012, 08:49 AM   #3
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,970
Originally Posted by WRW9751 View Post
+1 great company!!!!
Motorfiets is offline   Reply With Quote
Old 04-17-2012, 08:51 AM   #4
GH41
Oddometer: 626
How will you get the nut on if you do this? I would put a helicoil in it and retain the original screw. If I couldn't find a shop to do it and didn't want to buy a $40-50 kit to do one screw I would tap it out to the next size up. The boss on the cover is large enough to do it. I also would't go out of my way to find a torx screw. Button head allen screws are easier to find. GH
GH41 is offline   Reply With Quote
Old 04-17-2012, 12:07 PM   #5
señormoto
Supermoto Abuser
señormoto's Avatar
Oddometer: 1,001
+1 -- the other option is to get a replacement fastener like stock.
I have a feeling that there are some decisions being made on certain teams lately to make things more complex in order to ensure a certain technological standard of confusion is met.
señormoto is offline   Reply With Quote
Old 04-17-2012, 06:49 PM   #6
fiwi OP
Oddometer: 145
I guess sticking to the same torx screw isnt totally neccessary, i just thought i would if i could. Its the panel on the right side, quite easy to get my hand under the back of the panel to fit a nut if need be.
Anyway, after reading the replies, I guess the nut option isnt the best. Seems like the 2 best options are to just clean up both holes, re tap them and insert a larger screw/bolt, most likely not torx, I guess that isnt a big deal OR the helicoil idea. Didnt know what a heli coil was till I just checked on youtube. That would be the best idea but costly I am assuming.
I dont want to sound as though its a big deal, its not, I just love the idea that I can get on here with little idea of how to fix something and a number of people have some great ideas. Thanks
Old 04-18-2012, 03:47 AM   #7
GH41
Oddometer: 626
Here is one more thought. There is a possibility the frame boss is threaded deaper than the existing screw is long. If it is you can use a screw slightly longer the the original one. If you can get 3-4 threads engaged it will be OK. Maybe a drop of BLUE locktite for insurance. GH
Times are GMT -7.   It's 10:56 PM.
