Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 03-18-2013, 05:34 PM   #196
advtenn
advtenn's Avatar
Oddometer: 1,364
Originally Posted by McKay View Post
It is the seal running surface though, the seal is worthless when the runner is grooved that bad. Some wear is fine but Id replace those.
Tip, pack the seal groove (V) with grease before you put the runner/spacer back on. Helps with the wear.
Thanks for the tip. I flipped it over on my first tire change but didnt use enough grease.
bikes guns and shine
"My body thinks my brains gone crazy" ..........Corky McMillian
advtenn is offline   Reply With Quote
Old 03-19-2013, 09:26 AM   #197
Rabbot
rain+superbike=adventure
Rabbot's Avatar
Oddometer: 560
Mine is actually a bent shaft, hoping they do the spring at the same time. My problem started small and got big very fast.
there is a pivot bolt behind the heel guard that I sheared off. wonder how/if all this shifter stuff is related other than it's shifter stuff breaking?
Started small then no shifty
"Red hair and black leather, my favorite color scheme".
Rabbot is offline   Reply With Quote
Old 03-31-2013, 04:45 PM   #198
rockchucker
rockchucker's Avatar
Oddometer: 23
New XC sprung a leak
Any help from the collective would be appreciated. New, ~300 miles, xc got hungry and ate a screw that came out of the back half of he chain guide, munched on the cs sprocket guard and chewed a hole in the rubber coolant hose immediately in front of the cs sprocket. 500 mile service scheduled for next Saturday the 6th but it looks like I'll be trailering it there 150 miles and having a 300 mile service instead of 500. Should I be requesting a new cs sprocket and chain? Any thing else?
Thanks for any advice and loctite is your friend!
rockchucker is online now   Reply With Quote
Old 04-01-2013, 06:58 AM   #199
Kawidad
Kawidad's Avatar
Oddometer: 4,843
Hand tighten every nut and bolt on the bike?
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 04-01-2013, 07:29 AM   #200
rockchucker
Oddometer: 23
Went through most of them but this one caught me out.
Old 04-01-2013, 07:35 AM   #201
Snapper
Snapper's Avatar
Oddometer: 2,508
I'll throw in one to keep an eye out for...
If you tend to touch your pegs down (yes, and I do get a cheek off the seat), keep an eye on your kick-stand safety switch plunger. I bottomed out hard on mid-corner dip once and sheared my plunger clean off. I only realized what I was missing after someone posted pics of what it should look like. Mine's a first model year, I understand they've redesigned it on later models. Now have suspension risers installed (shorter links).
Lateral G Junkie
Fear Deer
Snapper is offline   Reply With Quote
Old 04-01-2013, 08:43 AM   #202
bluesman
Oddometer: 3,343
just FYI on side stand. Thanks to author - my friends did same and works like magic
http://www.tiger800.co.uk/index.php/....html#msg78075
bluesman is offline   Reply With Quote
Old 04-01-2013, 08:47 AM   #203
burgerking
echt bezopen
Oddometer: 496
But that will not work if you have the center stand fitted.
burgerking is offline   Reply With Quote
Old 04-01-2013, 09:40 AM   #204
bluesman
Oddometer: 3,343
Correct. But I personally hate center stands.
Old 04-01-2013, 09:48 AM   #205
Snapper
Snapper's Avatar
Oddometer: 2,508
^^ also wouldn't help the pegs dragging - on both sides - which I find very disconcerting. The 1/2" risers pretty much solved my problems though, only very rarely touch down now. Being very honest, this Roadie has less ground clearance than my previous stock Harley (an XR1200).
Lateral G Junkie
Fear Deer
Old 04-01-2013, 10:13 AM   #206
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Subframe gets bent you're FUCT. Waiting for the insurance adjuster to let me know what the damage is...
Keep your $0.02 if it ain't going towards the bill
Dubl-A is offline   Reply With Quote
Old 04-01-2013, 10:13 AM   #207
bluesman
Oddometer: 3,343
mine is XC and I am not very heavy, so no issues for me.
Old 04-01-2013, 10:23 AM   #208
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,670
Oh, that sux! What's the backstory?
Old 04-01-2013, 10:41 AM   #209
BlackBeast
BlackBeast's Avatar
Oddometer: 934
Ouch! Hope you managed to get out the way in time.
BlackBeast is offline   Reply With Quote
Old 04-01-2013, 11:05 AM   #210
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Tell me about it!!
Elderly woman, new van, keyless start/stop "Thought" she put it in park and went in for some dog food. Came back out, doors were locked and it was dry humping my baby. Actually drug it over 6ft and over a curb!!!
She is insured but I have a feeling that I have taken a HUGE loss. Almost had it right the way I wanted it too. Good thing my new Holan Nomada's panniers hadn't been mounted yet :(
Times are GMT -7.   It's 09:54 PM.
