Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 04-22-2013, 11:36 AM   #271
SMIFFXC
SMIFFXC's Avatar
Oddometer: 138
Originally Posted by browneye View Post
Mine wasn't on there either. Maybe they pack them with the bike un-installed. I had one or found one, put it on. You don't want your battery flying out if the bike flips. I guess.
good point!!!
I think mine had 2. One on the battery and one under the passenger seat just laying there. If I remember right I put it in that awesome tool kit that came with the bike that must be taking up space in somewhere in the garage. Looks like I got yours JG!
If I ever get the urge to try a back flip I'll be sure and double band it!
SMIFFXC is offline   Reply With Quote
Old 04-22-2013, 12:10 PM   #272
burmbuster
burmbuster's Avatar
Oddometer: 1,444
Originally Posted by SMIFFXC View Post
good point!!!
They have to be replaced yearly anyway. I did a thorough cleaning of my bike yesterday and the battery strap is already dry rotted. One year old, almost to the day.
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 04-24-2013, 08:26 AM   #273
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,644
Lost near all ability to shift coming into work this morning. Shifter is just limp. I can go up without too much difficulty but down shifting is hit or miss and mostly miss. I just rode most of the they way in 4th gear which made starting a stresser for my clutch especially since I am -2 in the rear. I suspect it is the selector return spring even though I did that TSB about 8 months ago. Still under warranty but I've got a trip planned in 2.5 weeks...........
I vaguely recall someone having a shifting problem that was not the return spring and it was something more severe.....am I remember correctly? If so what were the symptoms? Was shifting possible at all?
swimmer screwed with this post 04-24-2013 at 08:31 AM
swimmer is online now   Reply With Quote
Old 04-24-2013, 11:35 AM   #274
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,644
This sounds like my problem.
http://www.tiger800.co.uk/index.php/topic,6138.0.html
Dropping it off at the dealer this afternoon...
Old 04-24-2013, 11:39 AM   #275
McKay
McKay's Avatar
Oddometer: 920
that was me and it took 7 weeks to get fixed. Shift forks, drum and bushings all shot, 1200 or so total miles on bike. They said the heat treating must have been bad and that wiped out the shift mechanisms. They actually had to produce the replacement parts for me. I could up shift just fine, could not downshift at all. Good luck!
Triumph NA was stellar in their support though, I asked for them to extend my warranty since it had been in so long and they did, plus added on alot more for my troubles.
Jeff
McKay is offline   Reply With Quote
Old 04-24-2013, 11:44 AM   #276
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,644
My bikes has about 15k miles on it. If whatever the problem is takes 7 weeks to get fixed things are going to get ugly.
Old 04-24-2013, 03:33 PM   #277
T
stay classy
T's Avatar
Oddometer: 5,398
When this happened to me (about a month ago) with 13k miles on the clock the Triumph wrench thought it was the return spring (recall item). Turned out to be the pin in this photo (he showed me the pieces after disassembly). Took about 10 days for me to get back on the road. Yet another cinque in the Triumph armor.....
Inconsequential Adventurer
T is offline   Reply With Quote
Old 04-24-2013, 04:09 PM   #278
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,644
Thanks for info. When your pin broke could you shift at all? As I rode it to the dealership I found I could shift down by lifting the lever with my foot to the position where it would normally rest if it wasn't fucked up. The weight of the mechanism was enough to bring the lever down from up shifts so shifting up was no problem, just sloppy. The shop said he would probably be able to open it up tomorrow.
Old 04-24-2013, 04:22 PM   #279
cug
Oddometer: 4,879
Sounds more like the spring than anything else.
cug is offline   Reply With Quote
Old 04-24-2013, 04:32 PM   #280
T
stay classy
T's Avatar
Oddometer: 5,398
Exactly the same symptom(s). I actually pulled over in a car dealer's lot and adjusted my shift lever up (quite a bit) to make it to the Triumph dealer 10 miles down the road.
When I examined the broken parts the pin in question appeared to be pressed in. The whole "gear selection shaft" came as a unit-no separate pin. It really did look like a weak design link in the shift unit.
Check out the gear selection shaft from a 2005/06 Tiger 955i. Definitely a different design. BTW: I never had any such problem on my 05 with 50k miles.
Old 04-25-2013, 10:45 AM   #281
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,644
The shop called. It was the pin that broke. The warranty work has been approved by triumph. The bad news is that the part is back ordered until 5/8. The good news is that knowing I have a trip planned my shop is going to pull the part off of a 2013 model since it’s a quick job and they’ll just put the new(er) part on that bike when it arrives. I’ve bought 3 bikes from them, don’t know if that matters but, MASSIVE props to Performance Cycle Center in Tucson from coming through for me. I asked the mechanic to look and see if he notices any differences in the pin construction from the new bike. Mine is an early build 2011. I wouldn't be surprised if another TSB or recall is created from this part failure since the work is pretty quick and part not too crazy expensive.
Old 04-25-2013, 08:17 PM   #282
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,799
What makes it fail in the first place?
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RRLaguna Seca 2012 RRSequoia 3-Day CampoutThanksgiving 2012
browneye is offline   Reply With Quote
Old 04-25-2013, 08:18 PM   #283
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,644
bad design????
Old 04-25-2013, 08:20 PM   #284
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,799
bad design????
Well, it doesn't break on it's own. Is it just from shifting? Hard shifting, or what? Does hitting the shifter break it?
Is it something unrelated? What puts stress on it to break it?
Old 04-25-2013, 08:20 PM   #285
live2ridetahoe
RN
live2ridetahoe's Avatar
Oddometer: 1,466
bad design????
It is British after all...
OH SIT!!
JG
live2ridetahoe is offline   Reply With Quote
Times are GMT -7.   It's 07:55 PM.
