Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 06-15-2013, 03:29 PM   #376
XCRider803
Loftin' the wheel
XCRider803's Avatar
Oddometer: 878
Originally Posted by Yankee Dog View Post
OK, before I break something. Is the front axle a left hand thread? Either that or the dealer torqued the poop out of it during assembly.
I twisted the head right off my little DIY bolt and nut tool. Im headed back to buy a real hex tool.
The pinch bolts are loose right?
2013 Triumph Tiger 800 XC
2013 Husky TE 449
XCRider803 is online now   Reply With Quote
Old 06-15-2013, 04:42 PM   #377
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,945
What pinch bolts?
I should have know that would be coming. Yes, they are loose.
2005 Ural
2005 BMW F650GS
2012 Triumph Tiger 800xc
Yankee Dog is offline   Reply With Quote
Old 06-15-2013, 05:28 PM   #378
Kawidad
Kawidad's Avatar
Oddometer: 4,806
What pinch bolts?
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 06-15-2013, 07:28 PM   #379
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,266
Maybe the dealer didn't over-torque it, and instead you have a touch of galvanic action helping to hold it in place
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 06-15-2013, 10:54 PM   #380
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,591
The front axle is a big heavy duty piece with big threads at the end - it's easy to get it torqued in there pretty tight. You need a 17mm allen tool that you can put a real wrench on, not just a big allen key, although it doesn't need to be that tight.
I bought one of these the day after I picked up the bike and realized they didn't provide anything in the took pack to get the front wheel off with. This aluminum one is light, but stupid expensive...
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 06-15-2013, 10:57 PM   #381
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,591
More service items
I'm at 6500 and so I'm doing various maintenance as soon as I see a need. Based on Bueller's post for this lower motor mount (he posted it up in the prep for dirt thread) I took mine apart today and got about 3/4 of a turn on it. The very slight buzz at 4-5Krpm is now gone. My Tiger is back to butter-smooth throughout the rpm range again.
In order to get to that lower motor mount you have to remove the brake and shifter pivots - they are locktited in. Good opportunity to grease them, both were serously lacking proper lubricant. Re-greased and blue locktited them back in after torquing the motormount bolt.
I think this is a must-do service on the pivots as well as checking the motor mount.
Courtesy Bueler's post on the lower motor mount bolt and shim:
[/URL]
I was also getting a thunk in the stemhead on rough road sections even though I had already tightened the bearings. This time I thought I would completely disassemble and inspect it, re-torque it all. The tink/thunk I was getting is now gone.
So factory grease isn't completely missing, but they sure are stingey about it....I loaded it up with waterproof grease on reassembly.
[/URL]
While I was putting the front end back together I thought it was a good time to rebalance both tires, took about an ounce on both ends to true them up. Makes for really smooth running on the hiway.
And it was a good time to look at the front fender mounts and figure out how to raise it a bit. I think the factory setting is too close to the tire for gravel and mud.
The fork leg mount has a plastic stand off that is fastened with a plastic plug in the center hole - and it turns out to be threaded same as the top and bottom mounting holes. So I just drilled another hole in the fender/fork slider guard and moved it up one. Then made a couple of extender brackets for the rear fender mount out of 3/4X1/8" aluminum. If you look close you can see the left side one in the pics. Reused all the existing fasteners, just added a 6M bolt with nyloc to fasten the fender to the new brackets. The brakeline cross over is JUST long enough to accomodate this extra inch or so of fender height.
[/URL]
[/URL]
Old 06-16-2013, 06:14 AM   #382
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,266
The motor mount write up is actually posted in this thread, a couple of pages back.
Glad it helped the vibration issues! Between that and synchronizing the throttle bodies yesterday as part of my 12k service mine feels like a new bike.
Old 06-16-2013, 06:44 AM   #383
rustynut2
Oddometer: 479
browneye, have you compressed the front forks with the fender extension. Bad things might happen after a large bump
Work harder, millions on welfare depend on you.
12 T800XC
09 KLR 650
rustynut2 is offline   Reply With Quote
Old 06-16-2013, 10:18 AM   #384
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,591
I have not...measuring it's gonna be really close!
EDIT: I've run the fork legs down flush with the top clamp. Measing travel and clearance I may be short an eighth to a quarter inch. I guess If I bottom it I'll find out if it hits. Or I could remove the caps and run them all the way up and see if the fender hits the lower clamp.
browneye screwed with this post 06-16-2013 at 11:49 AM
Old 06-16-2013, 10:34 AM   #385
live2ridetahoe
RN
live2ridetahoe's Avatar
Oddometer: 1,451
9000 mile service?
For the past few hundred miles I have had the service symbol pop up during initial startup. The little wrench symbol has been accompanied by a mileage countdown. I am now at 9000 miles and the wrench symbol is on all the time now.
I was not aware of a 9000 mile service interval. What's up? Does anyone else have this?
JG
live2ridetahoe is offline   Reply With Quote
Old 06-16-2013, 11:16 AM   #386
cug
Oddometer: 4,861
Every 6000 miles or every year. Is that what it is?
cug is offline   Reply With Quote
Old 06-16-2013, 11:47 AM   #387
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,591
JG
The regular service interval is 6K - major at 12K or 2 years which includes valve clearance check.
Perhaps your dealer reset your service indicator at 3K.
Old 06-17-2013, 07:05 AM   #388
Kawidad
Kawidad's Avatar
Oddometer: 4,806
JG
I thought I read over on another Tiger forum the service interval can be set to whatever desired numbers.
Old 06-17-2013, 07:30 AM   #389
T
stay classy
T's Avatar
Oddometer: 5,331
I'm not 100% sure if the actual software at the dealer is similar/same as my Dealertool program, but I can put in any mileage number up to 6000 (maximum) for my next service.
Inconsequential Adventurer
T is offline   Reply With Quote
Old 06-17-2013, 07:38 AM   #390
rustynut2
Oddometer: 479
I got rid of the wrench light this weekend using the dealertool. Worked just great. I noticed you are only able to go up to 6000 on the reset, was hoping to set it higher. Is that all we get.
12 T800XC
09 KLR 650
Times are GMT -7.   It's 08:48 PM.
