03-18-2013, 03:25 AM
#616 | |
Get away, evil car!
Oddometer: 238
Well, not in the middle but here's the pic:
Lusting for: 2013 Triumph Trophy SE Current: 2012 Berg FE570, 2010 Street Triple R (wifey), 2011 Tiger 800 XC -- O YEA! ![]() Sold: 1975 CT90, 2008 XVS650, 2007 Rocket III Classic, 2010 Rocket III Roadster
03-18-2013, 07:06 AM
#617 |
Oddometer: 84
Header Guard
I have the Flatland Racing guard on my 570 too. I've had two issues with it in the past year. The first issue is the breaks in the guard along the front edge work like teeth. I've had plant material get caught in here several time out on the trail and begin burning. It hasn't hurt the bike, but I'm a little concerned about the possibility of starting a wildfire. The second issue is the screw and brackets that hold it to the pipe. I've replaced the screws more than once and a bracket once. I finally safety wired them to keep them in place, Other than those two items, it is a good piece, just requiures a little attention if you are bush bashing and occasional maintenance.
03-18-2013, 07:17 AM
#618 | |
Oddometer: 93
I had been waiting to put in a 12v cig plug, then converting to USB, but now installing the USB plug just cuts out the middle man! Lost, I left the iphone 4s to get a droid. ;-) |
03-20-2013, 03:42 AM
#619 | |
Oddometer: 1,565
I have no key - the passive loss of electricity is huge. These things draw power even with nothing plugged in!! ![]()
03-20-2013, 08:53 AM
#620 | |
Oddometer: 108
3BR stuff
I noticed the same with the 3br USB wired directly to the battery on my WR250X. Seems like it takes about a week to draw the battery down, but it definitely has a significant draw (just sitting there, not charging anything). It's a great piece though & very waterproof...but probably a good idea to find a switched circuit to connect it to though. |
03-20-2013, 09:00 AM
#621 | |
Oddometer: 93
03-20-2013, 09:26 AM
#622 | |
Oddometer: 108
I imagine with the little batteries they have to stuff in an XRR it could become an issue pretty fast. |
03-20-2013, 11:10 AM
#623 |
Broken Roadie
Oddometer: 2,784
My Fluke clamp meter shows a .01a draw at idle and I could notice a drop in my battery voltage after a couple days, even with a Shorai battery. My bike doesn't sit on a tender so I'm just keep the positive lead disconnected when the bike is sitting.
03-20-2013, 11:14 AM
#624 |
Oddometer: 93
Thanks LostRider,
0.01a isn't enough to get excited about for me. I wonder if the higher output model has a lousier dc-dc converter. |
03-20-2013, 11:38 AM
#625 | |
Broken Roadie
Oddometer: 2,784
To be honest my Fluke RMS meter isn't really designed for this testing, it's my work meter with a 700amp AC measuring capability so that number is probably not accurate. It's drawing something though at idle for sure and did drain my battery slightly after a few days. Like you said, maybe the larger capacity USB converter draws more than mine. Easy fix for me having the connections easily accessible though. Here's from the 3BR site on their product: 3. TAPP quiescent current (power consumption with no load) will drain a small motorcycle battery in as little as three to five days if connected directly to the battery. It is recommended that TAPP be connected to a switched power source to prevent battery drain when the vehicle is not running. A Posi-TapTM tap connector supplied in the installation kit makes a robust connection to the vehicle electrical system quick and easy. |
03-20-2013, 01:43 PM
#626 | |
Oddometer: 1,565
03-20-2013, 03:32 PM
#627 | |
Oddometer: 108
03-20-2013, 03:38 PM
#628 |
Oddometer: 1,565
I read that too. I think it's a significant fault. I have Garmin power leads directly connected to the battery, hid power leads and no drain at all. What is it about an unloaded USB port that drains power?
Imagine all the electricity the world is consuming from unloaded (unused) USB ports!!!! |
03-20-2013, 07:44 PM
#629 | |
Oddometer: 18
I am glad this info was posted today. I was just about to install a USB adapter on my bike - hooked directly to the battery (through a fuse). I have now changed my mind - I will only hook it up when needed to avoid this power draw.
-------------------------------- 2010 Husaberg FE450 |
03-20-2013, 09:21 PM
#630 |
Oddometer: 1,565
Glad I could help.
I will cut the connection and only reconnect when bike is running. My battery resides under the seat
