04-19-2012, 08:00 AM
#1 |
Oddometer: 60
My R 80 g/s died suddenly while running perfectly. We went over a big speed bump and the engine just died. The battery is fine, the starter motor turns fine, the lights, horn etc come on but the lady stands as still as Greek economy. I yanked and spray cleaned every cable and cable port I could reach, still nothing.
Ignition coils (latest bmw version) I measured gave a reading of 0,96 ohm for primary coil and 12,68 Kohm for the secondary coil. I 'm not really good with the multimeter and electronic stuff (I just tried to follow haynes guide lines as best as I could) so I don't trust my findings to indicate that I should fork the money for a new coil with any certainty. I just checked it cause adv wisdom states that when in bad weather or bumps airheads die of bad coils. Haynes states that the resistances should be between 1,15 -1,32 ohms for primary and 7,50 kohm -9,15 kohm. I also guess that it couldn't be any spark plug or spark plug caps or their leads as it would be rather unlikely that they both fail together so no sign of engine poping goes on. Once I had a cut spark plug cable and the machine started poping with the one of the two cylinders. My wiring loom is also fairly new, I changed it a few years back. Any ideas? Suggestions? Old airhead mandras? What should be the proper priority I give to start suspecting components? |
04-19-2012, 08:05 AM
#2 |
odd
Oddometer: 1,092
Trace power
From a bump to dead, there is a good chance it is a bad connection.
Have you fiddled with the kill switch? A very likely culprit. Do you have power to the coils with the key on? if so, check connections to the ICU and bean can. If not, trace back to ignition switch. This will be simple.
Never underestimate the laxative properties of motorcycling. |
04-19-2012, 10:18 AM
#3 |
Oddometer: 60
Is there a possibility to have indicator lights on and starter motor working and at the same time the kill switch off?
04-19-2012, 03:41 PM
#4 | |
airhead or nothing
Oddometer: 7,932
Do you have spark? I am going to guess no
"punkrocks what it's all about" - J. Strummer Quote:
04-19-2012, 05:01 PM
#5 |
Shit for brains
Oddometer: 4,847
Certainly sounds like a bad connection. i just had this happen and it ended up being a broken wire to my igniton switch. I bet it's something real simple, and cheap to fix.
04-20-2012, 06:32 AM
#6 |
Oddometer: 60
Well I tried to find any broken or loose wire by eye and hand inspection but zero effect. I also sprayed everything with electrical contact spray. Nothing. Now I need some advice on where to start looking first since my electrical power is there and my starter motor is turning. How do you recoment I check for spark? Should I just pul out the spark plug cable or the hole spurk plug with the cap and cable and press the button?
04-20-2012, 07:09 AM
#7 |
Oddometer: 93
To check for spark: remove plug, reconnect wire, ground plug to engine (touch it to case), crank and see if spark jumps gap in plug. Of course, be careful not to make your self "part of the circuit".
Or spark testers are available for $10 or so. I have one that is simply placed next to the wire and senses current through induction. Easy-peasy. |
04-20-2012, 07:43 AM
#8 |
Oddometer: 60
Thanks for the "how to". When I was young we did it this way on jap bikes but I 've heard that doing it to beamers causes it to fry some circuit or something. I 'll give it a go.
04-20-2012, 08:05 AM
#9 |
Beemerholics Anonymous
Oddometer: 7,354
You won't fry anything if the plug is grounded - touch the threads to the cylinder head.
To check for voltage at the coil - connect the voltmeter with black lead to battery minus (ground), and red lead to coil terminal #15. With ignition turned on you should see 12.7 volts. Do this quickly because the ICU will turn off after a few seconds once it detects the engine isn't spinning.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
04-20-2012, 11:07 AM
#10 |
Oddometer: 93
I think the danger of frying something (the coil) comes when the impulse doesn't have a place to go. Grounding the plug allows it to go to ground.
Also believe that high-energy ignitions are more susceptible to this type of damage, but don't know if your bike has one. 1980 G/S? |
04-20-2012, 11:31 AM
#11 |
Oddometer: 60
Although its not polite to speak of a lady's age, mine is a 1984 G/S. Its voltage regulator is the latest type, as is the ignition coils and diode board. I 've changed them through the 11 years I rode her.
04-20-2012, 10:40 PM
#12 |
Oddometer: 416
I know it sounds too simple, but did you check how well the connectors at the battery are connected to the wires? I once stood on the side of the road for over an hour chasing a gremlin that turned out to be a bad connection between wire and terminal on a battery connection.
04-21-2012, 10:34 AM
#13 |
Oddometer: 60
First think I checked as I had a visit from the same f@cken gremlin three years ago.
