Old 04-19-2012, 02:05 PM   #1
Hudson OP
Hudson's Avatar
Oddometer: 36
Botched rear rack install
Hey folks,
I received my Adventure Designs rear rack today. I was just about finished installing it when the last screw started free-spinning. I can't get it in or out. I've tried all of the usual tricks, but it won't budge. I'd like to get the tail light assembly off so I can look up under the rack screws and see where the trouble is. Is there any way to get in there with the rack in place? I'm heading out to the garage to give it a shot.
Any advice would be most appreciated.
(sigh.. I haven't even had the bike two weeks yet and it's already busted.)
Safe Journey,
Hudson
Newport News, VA
"They both savoured the strange warm glow of being much more ignorant than ordinary people, who were only ignorant of ordinary things."
-Terry Pratchett
Hudson is offline   Reply With Quote
Old 04-19-2012, 02:13 PM   #2
señormoto
Supermoto Abuser
señormoto's Avatar
Oddometer: 1,110
same thing happened to me when installing the TT rear rack. I hit it with a hammer a bunch and it was then able to be removed while holding a screwdriver under it while turning the torqx driver on the bolt. If that doesn't work then you need to access it from below.
I have a feeling that there are some decisions being made on certain teams lately to make things more complex in order to ensure a certain technological standard of confusion is met.
señormoto is offline   Reply With Quote
Old 04-19-2012, 02:31 PM   #3
toowheels
on a mission...
toowheels's Avatar
Oddometer: 966
Originally Posted by Hudson View Post
Hey folks,
You bought the wrong rack but let me help.
They're Rivnuts and it's definitely been about 1 in 100 that have less than perfect threads.
These two threads should give you your answers:
http://advrider.com/forums/showthrea...hlight=rivnuts
Thanks,
Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
www.motooverland.com
toowheels is offline   Reply With Quote
Old 04-19-2012, 02:48 PM   #4
Hudson OP
Hudson's Avatar
Oddometer: 36
Well I know I bought the wrong rack now don"t I
Thanks for the heads up. Having a broken rivnut explains the play I am feeling in the screw. It all makes sense now. I'll research how to get underneath and if I can't pull that off while the rack is in place then maybe my dealer can help out.
SenorMoto.. I tried the hammer. no joy. Thanks though.
As for now I'll leave it as is. Man.. this is gonna bug me.
Safe Journey,
Hudson
Newport News, VA
-Terry Pratchett
Old 04-19-2012, 06:55 PM   #5
dalebor
Oddometer: 25
I had the same problem on my brand new F8 two summers ago. I never did figure out how to take the tail piece (it"s actually three pieces of plastic) off with a bolt stuck in a spinning rivet nut. I ended up using a hack saw to cut off the bolt between the partially installed rack and the plastic top tail piece. Then I could take off the plastic and get at the rivet nut. My dealer was completely useless in helping me with this. They didn't even know that the fastener in the frame was a rivet nut let alone where to get a new one. Eventually I figured it out for myself.
Dale B
dalebor is offline   Reply With Quote
Old 04-19-2012, 07:10 PM   #6
Casejeep
Casejeep's Avatar
Oddometer: 736
Hey folks,
I had one of these almost break off. so i took the tail off, not hard at all, maybe 6 skews?
Then I JB Weld'ed the shit out of them.
These rear bolts aren't very beefy for putting any weight on them. So I figured id do this to both sides.
2012-04-12_12-21-38_46
2012-04-12_12-21-30_863
MY F800 GS Build
Casejeep is offline   Reply With Quote
Old 04-20-2012, 09:28 PM   #7
Machete-LC
Machete-LC's Avatar
Oddometer: 113
Had the same thing happen to me when I was installing my Jesse Bags. Huge disappointment! I ended up trying to use a Helicoil to try and re-thread but when I tried to drill it out it just spun in the frame and ended up breaking off the rive-nut. I ended up getting a wing nut and JB-Welded it to the frame as a replacement. Worked great! Maybe if you use a drill to spin your bolt it will break as well, very thin and soft material. Funny cause all the other nuts are welded into the frame except these which are highly likely to but used to anchor accessories. If you need help feel free to PM and leave your phone number.
Good Luck!
The only normal people you know are the ones you don't know that well yet!
Machete-LC is offline   Reply With Quote
Old 04-20-2012, 11:34 PM   #8
hammick
hammick's Avatar
Oddometer: 1,923
I had one spin on my '11 RT when installing a CB bracket. I had to drill it out. The dealer was very helpful and warranty claimed an entire new rear rack.
2015 R1200 GSA
2014 Moto Guzzi California Custom
2014 Husky FE501
hammick is offline   Reply With Quote
Times are GMT -7.   It's 02:36 PM.
