Old 06-22-2012, 04:44 PM   #46
rudiemoto
rudiemoto's Avatar
Oddometer: 17
[QUOTE=hillbillypolack;18870152]Andreani????
Is that a concern? I thought these were supposed to be Ohlins.
Andreani are custom ohlin builders
You can order
Weight of rider
Type of riding
And so on
rudiemoto is offline   Reply With Quote
Old 10-08-2012, 04:18 AM   #47
gkaan
Bikes on the Brain
gkaan's Avatar
Oddometer: 505
HP2E mods coming
i have a pending sale for my G650X-challenge which means I will have some funds to fix/improve my HP2E. firstly it needs a new rear drive
secondly, the fork tube is shot which is OK as i plan on calling FBI to discuss alternatives as the front end is still too soft for me even after installing heavier springs and fork oil. I have also decided that ill be doing much more on-road riding moving forward and am installing the supermoto wheels/tires and leaving them on for a season or two. This means i need to improve the front brake as it is great for off road but a litlle underwhelming for aggressive on road riding. It would be great to know what experiences folks have had with the front brake alternatives out there that would work for street riding? I will also be looking at rear shock if i don't run out of money first. I cant wait to get started!
gkaan is offline   Reply With Quote
Old 10-08-2012, 05:08 AM   #48
Some Dude
what attitude problem???
Some Dude's Avatar
Oddometer: 4,757
How good of front brakes do you want? I have a radial 4 piston caliper on my HP2 E with KTM 48mm forks for my "street" set-up and I have a KTM 950SM front end (complete) that can easily be adapted to the HP2 E for a truly nice handling MegaMoto set-up complete with radial calipers and master cylinder from an S1RR.
The Stock SM wheel set is going to help with braking as it has a 320mm front rotor instead of the 265, but you're still squeezing with the very small front caliper so it's only a marginal improvement. QTM makes a radial caliper adapter for the KTM forks which can be adapted to the HP2 E. This will give you much better valving for comp/rebound which is the major weakness of the stock Zoke forks and there can be custom springs made for either fork, but even with the right springs the valving has to match.
Just some dude on the internet,..
Some Dude is offline   Reply With Quote
Old 10-08-2012, 07:20 AM   #49
bikecat
bikecat's Avatar
Oddometer: 1,122
Why not simply transfer MM front end to HP2E and upgrading the forks with Racetech and springs?
bikecat is offline   Reply With Quote
Old 10-08-2012, 08:39 AM   #50
Some Dude
Some Dude's Avatar
Oddometer: 4,757
new MM forks would be way more $$$ then used KTM 950 SM of SMR forks and new lower triple clamp as there are no parted out MM's out there. Also the MM Zokes are not as nice as the WP 950 SM or SMR forks. Both options are going to lower the bike quite a bit and rear shock should be matched accordingly.
Old 10-10-2012, 04:24 AM   #51
gkaan
Bikes on the Brain
gkaan's Avatar
Oddometer: 505
sound slike you have a great set up somedude. any pix of your front end? i have a 950sm which im selling. this is part of the reason i'm looking to convert my hp2e as id like to approach the handling and braking of the KTM although i know that would be difficult. i dont know what the costs are for the 950SM fork and radial caliper conversion but that sounds ideal. is there no caliper rotor conversion kits? i have seen rotors but no calipers sold as after market for HP2E but maybe im not looking hard enough.
Old 10-10-2012, 09:40 PM   #52
GSMarc
GSMarc's Avatar
Oddometer: 1,121
should be this :
http://www.advrider.com/forums/showp...77&postcount=1
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 10-20-2012, 10:43 AM   #53
gkaan
Bikes on the Brain
gkaan's Avatar
Oddometer: 505
Just ordered my cartridge kit from David at FBI. Can't wait!
Old 05-23-2014, 11:01 PM   #54
configurationspace OP
delooper
configurationspace's Avatar
Oddometer: 9,061
I'm draining the oil from my forks -- first oil change since the FBI cartridge inserts. Holy hell it takes forever for the oil to drain! Every time I think I've drained the oil, I turn the forks upside down for a while, pump them a few times, turn them back upside-down, and another 5 tablespoons come out.
Is there a quick way to get the oil out? Maybe I'm being too fussy, but wow. It's also only around 12c here right now, that might have something to do with it.
configurationspace is online now   Reply With Quote
Times are GMT -7.   It's 08:48 PM.
