Old 04-21-2012, 11:03 AM   #1
Ricklesss OP
Ricklesssssssss
Ricklesss's Avatar
Oddometer: 145
How much oil in an oil filter housing is normal?
So if I don't (but actually don't know yet) have worn rings or valve guides, and the engine oil isn't topped off too high, what's the amount of oil lying in the bottom of an R80 air filter housing that might signify a problem?
What's the "about" normal amount for these R80 and R100 engines? My ST has a messy 1/16th to an 8th thick smear of it, pooled at one end.
It doesn't drip out of the plastic air intakes. (yet?) or appear to even make it's way into those intakes, but did make it's way out that one way rubber grommet valve and then onto the tranny a bit.
Ricklessssssssss in Oregon
"Never ride faster than your guardian angel can fly."
"And no matter what, what ever you do, NEVER chase camels faster than your guardian angel can fly...
Ricklesss is offline   Reply With Quote
Old 04-21-2012, 01:56 PM   #2
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,047
My ST will get a trace of oil like that sometimes.
However, comma, once I did have about the amount that you described collected in the filter box. Turned out one of the preformed rubber tubes coming off the T from the breather tube to send crankcase gases to each carb had a big split in the bottom side. That allowed oil mist in the blowby gases to condense out and collect in the airbox.
New tube from the dealer and problem solved. Might not be your case, but check the T fitting and both tubes leading into the carb runners.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 04-21-2012, 02:01 PM   #3
Ricklesss OP
Ricklesssssssss
Ricklesss's Avatar
Oddometer: 145
Ya' know...I didn't REALLY inspect "said" vent hose...
I'm off to the garage, now!
RIck
Times are GMT -7.   It's 09:25 AM.
