Old 04-22-2012, 07:09 AM   #1
rockitdoc OP
rockitdoc's Avatar
Oddometer: 391
OIl Change Messy Usually?
I looked for threads re this, but having not located any, here goes the question:
I changed my 990A oil yesterday for the first time. Everything went routinely until filling the oil tank. It's supposed to take 3L, but at about 2.5L the tank overflowed and was totally full. I realize the engine takes some of it, but even after running it for a few seconds (20?) the level in the tank didn't go down much. Is there a better process for adding the oil so it doesn't overflow like that?
S
'00 DR650SE
'60 BSA Gold Star Clubman (in process)
'76 BMW R90S
'77 BMW R100RS
'85 Laverda RGS1000SFC (also in process)
rockitdoc is offline   Reply With Quote
Old 04-22-2012, 07:30 AM   #2
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
Oops... misread the original post. My bad.
FYYFF!
http://www.youtube.com/watch?v=NtpUv4VBDhA
Bikes: 2013 BMW K1600GT
A Few Past Bikes
: 2003 Suzuki DRZ400E | 2012 BMW K13S | 2009 KTM 990 Adventure
Narsisco Lopez screwed with this post 04-22-2012 at 05:05 PM
Narsisco Lopez is offline   Reply With Quote
Old 04-22-2012, 09:30 AM   #3
Sumi
Sumi's Avatar
Oddometer: 1,799
S
The whole bike should take 3L, not the oil tank only.
That's why they say in the (for example users) manual to put 2.5liters of oil into the oil tank, run the bike until up to operating temp. (4bars) then adjust oil level until the level reaches the max mark on the dipstick (approx. 0.5 liters).
Old 04-22-2012, 10:03 AM   #4
rockitdoc OP
rockitdoc's Avatar
Oddometer: 391
Who reads instruction manuals? Good to know it can be run with only 2L in. That was what I was afraid to do. Thanks.
'00 DR650SE
'76 BMW R90S
'77 BMW R100RS
Old 04-22-2012, 11:26 AM   #5
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,338
Behold: The Wal-Mart Funnel:
It wedges in place, no muss, no fuss and about $50 cheaper than the drain hose set up. I don't get why so many want to make this really complicated...
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 04-22-2012, 11:35 AM   #6
Sumi
Sumi's Avatar
Oddometer: 1,799
I'm not sure 2L would be enough.. But the oil tank has a capacity of approx. 2.5-2.7l and the sump has another approx. 0.5 liters. So when you put 2.5 liter in the oil tank and run the engine up to 4 bars, about ~0.5 liter of the oil from the oil tank will "go" in the sump. That's why you have to add another 0.5l after, to get the level up to the MAX mark on the dipstick, and have about 3L in the whole system.
But you can't add 3L of oil into the OIL tank itself - in one step, as normaly if the engine is not running it won't drain into the sump and the capacity of the OIL tank is only about 2.5-2.7L, so it will overflow -> that's why you have to run the engine for a while, to transfer some oil from the tank to the sump.
Old 04-22-2012, 11:51 AM   #7
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
Check out the form a funnel. A little spendy, but really cool. Basically a sheet of flexible lead sealed in Nitrile rubber. Reading on their website suggests that they now make it out of aluminum. I think I got it from Napa.
http://www.formafunnel.com/
'07 KTM 990 Adventure Long Road to Dug Bar
Nut Clutch is offline   Reply With Quote
Old 04-22-2012, 12:46 PM   #8
Peanuts
Peanuts's Avatar
Oddometer: 1,637
I remove the large aluminium piece that the tank, sumpguard and engine bars bolt to. Then the oil drops vertical into my drain bowl.
Undo the two screws for the regulator and tie it aside when the screen is cleaned, a few dribbles on the regulator bracket are soon wiped up...... or let the oil dribble on the regulator and connectors to help offset corrosion
Peanuts is offline   Reply With Quote
Old 04-22-2012, 03:12 PM   #9
666
Agnostic and Orange
666's Avatar
Oddometer: 1,316
Funnel doesn't work as easy if you have tank guards.
I installed quick valve ( for about 20$ shipped). I found coupon online.
Just changed oil yesterday and it took about 10 minutes to completely drain.
here is guide http://www.ktm950.info/how/Orange%20...l%20valve.html
2006 KTM 950 ADV; 2006 KTM 525EXC; 2013 Tiger 800 street
Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423
Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109
666 is offline   Reply With Quote
Old 04-22-2012, 04:07 PM   #10
catalina38
Contrarian
Oddometer: 1,622
If you didn't bother to RTM are you sure you got all the oil out?
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 04-22-2012, 07:12 PM   #11
rnoliver
Oddometer: 36
I did just that the first time I did an oil change- then the drain bolt promptly slipped out of my fingers and into the funnel, making the perfect stopper. Messiest oil change I've ever done. Then the wind kicked up so nothing would drip into the pan Next time will be better!
rnoliver is offline   Reply With Quote
Old 04-22-2012, 08:53 PM   #12
ten_fiver
ten_fiver's Avatar
Oddometer: 2,026
ten_fiver is offline   Reply With Quote
Old 04-22-2012, 08:56 PM   #13
ten_fiver
ten_fiver's Avatar
Oddometer: 2,026
But yes, like the others have said. Follow the manual, and all will be ok. I just changed my oil myself for the first time yesterday. My only snag was filling up the oil to max while I had the bike on the side stand...
Old 04-22-2012, 09:35 PM   #14
crashmaster
ow, my balls!
crashmaster's Avatar
Oddometer: 5,256
I use aluminum foil. You can find it at pretty much any grocery or convenience store on the planet.
Also works good for keeping things clean when you drain the screens and the oil filter cavity.
Riding the Americas: No Fumar Español
_____________________________________________
crashmaster is offline   Reply With Quote
Old 04-23-2012, 10:46 AM   #15
rockitdoc OP
rockitdoc's Avatar
Oddometer: 391
PRetty sure. Drained oil tank, drained sump (crankcase), removed/replaced replacable filter, cleaned screen on brake side of engine. Is there any other oil lurking anywhere else?
'00 DR650SE
'76 BMW R90S
'77 BMW R100RS
Times are GMT -7.   It's 07:01 PM.
