Old 05-11-2009, 12:53 AM   #31
makazica
makazica's Avatar
Oddometer: 746
Originally Posted by mikeprod92211
Makazica,
Zerodog je odlican majstor!
On je uredio moj 2000 LC4E da je sada kao nov!
A ja sam 220 lbs (malo tezi od tebe).
Njegove preporuke su vrlo precizne, i stvarno covek zna o cemu govori!
Thanks man! I had no worries about his qualifications. I worry about the price that he's going to post....+ shipping.
Where are you from...??
BTW....Zerodog, I'm still waiting for your PM.....gimme some recommendations, guidelines....prices..
makazica is offline   Reply With Quote
Old 05-16-2009, 12:36 AM   #32
mikeprod92211
Desert Rat
mikeprod92211's Avatar
Oddometer: 589
Zrenjanin, Banat!
Emigrated to the USA 40 years ago!
LC4 Rider
mikeprod92211 is offline   Reply With Quote
Old 05-16-2009, 09:13 AM   #33
Mtncrzr
Just Kidding, not really
Mtncrzr's Avatar
Oddometer: 1,213
I hate to say it, but when I got my 640 it handled like crap. New springs remedied that. WP is great, it just needs set up for you.
New valving was the icing on the cake... Thanks Zerodog!
I'll be the one on the horizontal silver 640 KTM Adventure.
Mtncrzr is offline   Reply With Quote
Old 04-08-2010, 05:32 AM   #34
DaBit
Oddometer: 345
OK, I will continue in this thread instead of creating a new one. I'm fairly new here, so if this is not what people want, let me know.
Three questions about the suspension:
1) Sag setting.
The previous owner mounted heavier springs in the forks and on the rear shock. Since he weights about as much as I do, these springs work well for me too. I have no idea what springs are installed, though.
But now I am about to pack the bike for a trip to Morocco. This means 10-15kg of luggage. I have not tried it yet, but I am probably unable to set the static sag and sag with rider both to the correct values without changing the springs. Which I cannot do since I'm out of 'bike-money'.
Now, if the current springs prove to be too heavy or light: would I change the preload so that the static sag is correct? Or would I set the preload so that the sag with rider is correct? Or would I choose a compromise?
2) Rear shock frame mount bushing.
I had my shock serviced, and got it back yesterday. When mounting the shock, I noticed there were a few millimeters of vertical play on the upper mounting point of the shock with the bolt torqued to the value in the user manual (45Nm if I recall correctly).
I suppose a little play is OK, but I cannot find a maximum value of the play allowed. How much play is acceptable on that bushing?
3) Rear shock removal.
What is the quickest way to remove/reinstall the rear shock on an LC4 Adventure 2003? I could not find a way to wrestle the shock in place with everything else attached, so I ended up pulling the swingarm backwards. But there must be a 'trick'...
DaBit is offline   Reply With Quote
Old 04-08-2010, 07:27 PM   #35
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,697
remove linkage first...then it drops out the bottom ... I wouldnt worry about 1-15 K just try seting the clickers to a stiffer setting
wrk2surf is offline   Reply With Quote
Old 04-08-2010, 09:19 PM   #36
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,426
A few millimeters sounds like too much. I'd pull that shock back out & have a close look at the bushing, bolt & mount. On my 640 the lower shock bearing seems to be the most wear prone part of the rear suspension.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 04-08-2010, 11:45 PM   #37
bmwktmbill
Traveler
Oddometer: 5,102
That sounds good to me. With rear shock removal there are several threads that describe the best way to rotate the shock and work the swing arm up and down. Watch out, when it falls out it is heavy and will hurt you.
Do you have stiffer springs front and rear?
When setting the clickers back off on the rebound a little and increase the compression.
Check this out:
http://mx-tech.com/downloads/tuning_guide.pdf
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 04-09-2010, 01:41 AM   #38
DaBit
Oddometer: 345
Bolt was OK; I cleaned and greased it before mounting the shock. Mount is OK too; no movement of the bolt there. So, it's the bushing.
I also contacted the suspension guys, and they agreed the play was too much. They will send me another bushing, I will replace it myself. I suppose it's not more difficult than any other bearing on the bike. Doing it myself is quicker than sending the shock to them again.
That ProLink bearing on the linkage was completely shot on my bike. I replaced that already when I regreased the linkage.
Yes. Although I don't know how much stiffer compared to original they are. I haven't found a number on them yet (but I haven't looked too hard for that number either)
Check this out:
Good link, thanks!
I will have to set the preload anyway. It came back from the suspension guys with preload close to minimal. That gives me about 30mm static sag and a bike which almost rides like a chopper.
Old 04-09-2010, 12:55 PM   #39
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
DaBit,
curious: did you not find any of the sag threads, or perhaps they are not easily understandable? There is a whole pile of them in Post #1 of the 640 index. No flame, just wondering. The sag must be set, and must fall into the range specified by WP/KTM, or your suspension's behavior may be poor. Your manual will specify, and it is discussed ad nauseum in the sag threads.
You may already appreciate this, but adapting the suspension to more weight by using preload envokes the law of diminishing returns. The action of the suspension will become harsher as the preload is increased. You will loose the plush response and may end up with alot of chatter. Just want you to be aware of the cost of preload.
When you did the prolink bearing did you check the bearings on the frame where the dog bones attach? It sounds like you probably did, but those were the worst on my 03.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 04-09-2010, 03:50 PM   #40
DaBit
Oddometer: 345
Originally Posted by meat popsicle
DaBit,
Of course I did find the sag threads. That's also why I continued in this thread instead of creating a new one.
But I missed the 'what to do with luggage'. I might have overlooked it since most suspension threads quickly turn into half a flame war.
What I couldn't find through the index was the 'easiest' way to remove/reinstall the shock. The forum search wasn't very helpful either. Google did it better, but it was actually the first time I used Google to search a single site.
I know. But for a given load on the bike, there is only a single spring rate which satisfies both the static sag and rider sag perfectly. All other spring rates deviate somehow. I just wondered where to optimize for.
I was also asking in advance so I can do the job start to finish. There is a fair chance that the current spring is OK.
But if it's not, so be it. I have no money left to buy another spring. I'd rather take a less perfect bike to unknown places than have a perfect bike in the garage but no money to do something with it.
I did. They were nicely packed with grease and totally OK. In fact, they were the best preserved bearings in the entire linkage.
I cleaned the old grease out with some petroleum, blowed them dry with compressed air, and re-greased them with waterproof (Bel-Ray) grease.
The shock bushing was in the mailbox today. Nice and quick service (although they should have replaced it while servicing the shock in the first place...).
Unfortunately they did not send me the seals also .
DaBit screwed with this post 04-09-2010 at 03:56 PM
Old 04-11-2010, 12:05 AM   #41
meat popsicle
Ignostic
Oddometer: 14,224
Sounds like you got your head screwed on right DaBit: travel before farkling! The other way around is the equivalent of masturbation eh?
I hope your current setup works well enough to carry you through Africa, and does it well too. I recall folks saying you optimize for your usual weight (rider + gear, if that includes luggage: OK). But remember that at the speeds most sane folks travel long distances through Africa, without a support crew and such, will probably negate most issues related to this. Just my thought probably.
I can't think of what other tuning trick to do on the back for weight compensation besides preload, but if you do have to ride a little lower you might want to compensate by balancing it with the front - slipping the forks up in the triples might help - best to get a suspension tuner's attention or alot of time to filter through the sag threads.
Thanks for the feedback on the index; wish I had time to do something about it.
Old 04-11-2010, 11:40 PM   #42
bmwktmbill
Traveler
Oddometer: 5,102
Dabit,
When you have the shock off take the spring off and shorten it as much as possible(if you have the skill or the guts), that will stiffen it.
I did that before I forked over the money for a new spring the right weight.
Torch it, bend it flat, grind it.
Install.
Pray.
This is for fork springs but springs are springs.
http://www.thumpertalk.com/forum/arc.../t-611933.html
bill
Bill Shockley
bmwktmbill screwed with this post 04-11-2010 at 11:49 PM
Old 04-12-2010, 12:33 AM   #43
DaBit
Oddometer: 345
I do as little farkling as possible. I'm more a ducttape, tiewraps and pennytech kind of guy
I suppose it will. Even without much preload (preload rings to 'minimum' position) the rear is not that saggy.
When the seals for the shock bushing arrives, I will pull the shock, install a new bushing, crank up the preload a bit, and adjust the riding sag for rider+gear+luggage. Then I will check if the static sag is not that much off.
OK, that's what the question was all about.
Who says I'm sane?
But you are right. However: there are three things that keep you on the road and off the nearest cliff: brakes, suspension and tyres. The engine is also somewhat important of course, but it's not keeping you on the road.
I will keep the rear at it's original height. That's going to be fun when loaded with luggage (32" inseam) :)
Just note that it might also be me being a bit too lazy.
Originally Posted by bmwktmbill
Dabit,
Too risky a good week before leaving. Especially the 'pray' part :)
But good to know it can be done this way.
Old 04-12-2010, 10:43 AM   #44
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,179
I do quite a bit of loaded travel with my 640 and the setup I have is maybe not ideal but it works for me... After riding for a few years with the too soft stock setup I moved towards a firmer ride...
I picked up a rear shock that had been rebuilt by Race Tech and had the stiffer 75-260 installed... After installing this the front end seemed even softer so I went shopping for stiffer front springs...
I put a want add up in the fleamarket for some used 4.8 950 springs, received many replies and took the best deal.... The 950 springs are 15-25 mm shorter so I made a spacer out of pvc pipe that would put the total spring length+spacers about 10mm shorter than the stock 640 setup... I blended 50/50 5wt fork oil with ATF and filled both tubes to 120mm from the top... This setup works pretty good with the comp/rbd clickers setup close to the stock position {exact #s I don't remember}...
This setup ended up being pretty balanced on both ends but because I do a lot of loaded/loaded 2 up travel I made the back end a little stiffer by cranking the preload ring down about 40% of the thread from the top. This made for a good all around setup with the back being a little stiff when running light but no ill effect on overall handling... I made no changes to this setup when running loaded, it handled the extra weight just fine and rode very smooth... Of coarse what works for me may not for others as it's all about individual choice when it comes to suspension...
gunnerbuck is offline   Reply With Quote
Old 04-12-2010, 10:55 AM   #45
Tseta
Lost
Tseta's Avatar
Oddometer: 672
For anyone else looking for stiffer forks springs, "direct-fit, no spacers necessary" .48 fork springs for the LC4 Adventure are detailed in this post.
Cheers,
Tseta
Tseta is offline   Reply With Quote
Times are GMT -7.   It's 03:53 PM.
