Old 04-23-2012, 02:18 AM   #1
Padmei OP
enamoured
Oddometer: 3,718
O ring needed for mixture screw???
Hi all.
My LHS mixture screw (36mm bings off R80GS) is missing a spring. What purpose does this spring serve?
Also in the bing book an O ring is shown between the spring & screw. I am unsure if mine had them originally - should they have? I am chasing down a revs getting hung up problem & trying to eliminate problems.
Cheers
Padmei is offline   Reply With Quote
Old 04-23-2012, 02:48 AM   #2
Pete-NZ
Pete-NZ's Avatar
Oddometer: 751
Originally Posted by Padmei View Post
Hi all.
Cheers
The spring stops the screw vibrateing out by keeping preasure on the thread..
there most lightly was a 0-ring...
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ is offline   Reply With Quote
Old 04-23-2012, 02:54 AM   #3
lockyv7
lockyv7's Avatar
Location: Sunshine Coast Australia, There is no winter here.
Oddometer: 1,058
I only just rode a 100GS home on the weekend and it has a revs hung up problem, when it gets hot it wants to idle really high sometimes, i was thinking it was in the bean can, maybe the weights advance staying on or something like that.
I am sure someone will be along shortly to either give me or you an answer.
lockyv7 is offline   Reply With Quote
Old 04-23-2012, 03:30 AM   #4
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,655
As mentioned the spring and o ring stop the screw working loose and sealing at the same time.
Idle slow to drop is often due to air leaks, may be time to replace the carb/head rubber.
Throttle cable not letting the butterfly valve close....throttle shaft worn/leaking.....
Voltaire is offline   Reply With Quote
Old 04-23-2012, 06:09 AM   #5
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,213
Adjust the carbs when they're fully warmed. When the idle is high, that's the time to adjust and synch them. Most likely, that will cure the situation.
Old 04-23-2012, 07:42 AM   #6
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,586
Ride it for 20-30 minutes, then tune the carbs. Tuning when not warm enough will cause a high idle.
boxerboy81 is online now   Reply With Quote
Old 04-23-2012, 12:35 PM   #7
Padmei OP
enamoured
Oddometer: 3,718
Just to confirm with those of you that have the same carbs - is there def is a small o ring that sits on the smooth shaft between the thread & the point & not just the one that sits at the end in its' own recess?
Old 04-23-2012, 01:17 PM   #8
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,335
Nope, just sits in a recess near the threads.
Does that book cover multiple Bing carbs, or just your model? The carbs are 32mm btw.
Put up a photo if you're still not sure
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Times are GMT -7.   It's 06:05 AM.
