Old 04-23-2012, 07:38 AM   #1
khale OP
ride dirty
khale's Avatar
Oddometer: 557
BMW r75/5 possible clutch slip problem
I'm having a possible clutch issue that I need some help troubleshooting.
When I first start the bike, I put the bike in first gear and released the clutch to get the bike going, it feels like the bike is not completely engaging in first gear. The acceleration of the bike is very, very slow, and it feels like the bike isn't fully catching first gear. This continues to happen moving to 2nd gear, and I can't really go past 2nd gear as the bike is barely breaking 40mph at this point. I have already adjusted the clutch cable on the handlebar and on the bottom of the bike to allow for more clutch engagement. I've read on a few forums this could either be the clutch plates that need to be resurfaced or a leaky transmission seal that's dripping oil on the clutch, causing it to slip. If I ride for about 15-20 minutes or so, the problem vanishes about 95% of the time.
Any help is appreciated.
2013 BMW R1200 GSW | 1972 BMW R75/5 toaster | 2011 Husky TE310
"4 wheels move the body, 2 wheels move the soul"
khale is offline   Reply With Quote
Old 04-23-2012, 07:45 AM   #2
Nolan Woodbury
Nolan Woodbury's Avatar
Oddometer: 124
Worn clutches/clutch plates usually slip in top gear; when the load is greatest.
Otherwise, sounds like the rear main seal is leaking engine oil. The problem 'clearing up' after time points to this as well. I've got one ('72 R75/5) down for the same reason. It needs to come apart-
Nolan Woodbury is offline   Reply With Quote
Old 04-23-2012, 02:33 PM   #3
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,674
Originally Posted by nolan woodbury View Post
worn clutches/clutch plates usually slip in top gear; when the load is greatest.
Otherwise, sounds like the rear main seal is leaking engine oil. The problem 'clearing up' after time points to this as well. I've got one ('72 r75/5) down for the same reason. It needs to come apart-
+1
"If you don't peer over the edge now and then, how do you know where it is?" The venerable Mr. Cob
Mista Vern is offline   Reply With Quote
Old 04-24-2012, 08:46 AM   #4
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,237
I'm thinking it might be a throw-out bearing problem. Something with the throw-out mechanism might be hanging up. It just doesn't sound like an oily or slipping clutch - not the normal symptoms.
How much slack do you have at the lever?
Old 04-24-2012, 12:48 PM   #5
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 1,005
That was my first thought as well. Have had several where that little very expensive bearing is gone from wear or poor lubrication.
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 05-04-2012, 11:19 AM   #6
khale OP
ride dirty
khale's Avatar
Oddometer: 557
The problem is very sporadic. For instance, I took my bike out yesterday to ride, no problems whatsoever.
So the 2 possible causes are a rear main leaky seal and and throw out bearing gone bad? How heavy of a job is it to change either of these? I figure if I get into the clutch I might as well replace both.
Good place to buy either part?
Old 05-04-2012, 11:20 AM   #7
blaine.hale
blaine.hale's Avatar
Oddometer: 3,211
It's probably your four burner inner spinner after shafter.
Yup. That's it.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 05-05-2012, 07:27 AM   #8
SJ BMW
SJ BMW's Avatar
Oddometer: 82
Just clear things up - rear main seal leaks do NOT get on the clutch, only a leaking transmission input seal will get on the clutch plate.
Chris
Faster than you
SJ BMW is offline   Reply With Quote
Old 05-07-2012, 01:18 PM   #9
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 626
Throwout bearing is a 1 beer job. Easy peasy.
Current: 93 R100GS, 03 XR650R
Prior: 73 CB350, 77 R100/7, 83 R100RT, 04 XR650L
I love every motorcycle I've owned and even some that I haven't.
ignatz72 is offline   Reply With Quote
Old 05-07-2012, 01:26 PM   #10
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,188
Unless you've let it go far too long, then it becomes a kegger...
'73 R60/5 Toaster
Old 05-11-2012, 04:20 PM   #11
patanga
BMWAirheadsDownunder
patanga's Avatar
Oddometer: 161
Either way it sounds like you make have to take the box out to confirm your diagnosis. If you fail to find a problem with your clutch then another often overlooked fault is the gearbox output yoke nut. These can come loose (rare but it happens) and will give you very similar symptoms. The output shaft to yoke is a tapered shaft (not splined) and relies on the nut tension (220 ft/lbs) to provide positive power transmission. If/when you take to box out, it is unlikely that you will be able to test this simply by hand, or visually. You will need to lock the yoke to stop it rotating (BMW special tool) and then use a socket and also hold the input shaft still (in gear) to test. If the nut is the culprit then you will be able to turn the yoke/input shaft (in gear) as the taper slips. The bad news is, if that's the case, then you may be up for a gearbox rebuild as the slippage usually causes fretting damage to the output shaft and yoke. In more extreme cases the shaft and yoke can become cold welded together. Slippage then stops but really yuk outcome. That can also make strip down more challenging. If you don't have the right tools or know how then make sure to have your local BM repairer test this for you prior to reassembly.
____________________
"The only reason people get lost in thought is because it's unfamiliar territory" (Joe Garcia)
Check us out on facebook at "BMW Airheads Downunder", (The Australia and New Zealand Airhead Community). "B.A.D"
http://www.facebook.com/groups/anzairheads/
patanga screwed with this post 06-28-2012 at 03:20 PM
patanga is offline   Reply With Quote
Old 05-11-2012, 05:04 PM   #12
noman
Oddometer: 927
adjustment
" I have already adjusted the clutch cable on the handlebar and on the bottom of the bike"
when sorting out a problem, i usually start at the beginning. how much play do you have at the clutch throwout lever? should be 2mm or so, at least it is on my r75/6.
1976 r75/6 -- mine since 1980, thx lloyd!
1997 900ss -- modified to full sp specs
noman is offline   Reply With Quote
Old 05-11-2012, 08:24 PM   #13
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,465
I experienced a similar symptom with my sidehack but also had a rear main seal leak. Pulled the gearbox and found a large chunk missing on each side. Don't know how long it ran this way. I ended up changing every componant in the clutch assembly.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 06-27-2012, 11:08 AM   #14
khale OP
ride dirty
khale's Avatar
Oddometer: 557
More symptoms:
1. The bike has a horrible screeching noise when I'm at the end of the clutch lever to engage the gears. I'll try to post video if I can.
2. The problem really shows up when I'm on an incline. If I first start the bike and have to go up a small hill, even if the grade is less than 5% I hear the awful screeching noise and the bike barely moves, as if the bike is not in gear
Old 06-28-2012, 03:18 PM   #15
patanga
patanga's Avatar
Oddometer: 161
Originally Posted by khale View Post
More symptoms:
Why are you still riding it? You're only doing more damage....... If the adjustments are ok, then trailer the bike to a repairer to take the box out and look at the clutch, throw out, oil contamination AND the rear yoke nut. Remember there is a procedure involved in removing the clutch and for checking the output yoke.
Times are GMT -7.   It's 03:46 AM.
