Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 11-28-2013, 03:02 PM   #5146
Corsica101
Corsica101's Avatar
Oddometer: 426
Originally Posted by Bails View Post
Be very wary of filter replacements, most foam filters will flow more air and also more particles, which will cause more engine wear. Independent tests on heavy equipment air filters showed folded paper filter with greater surface area were much better in all aspects then foam filters, uni was one that was tested if I recall.
This may help: If you are interested in facts rather them hype.
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
https://www.youtube.com/watch?v=H2biMJH4tys
Ok those are interesting fact. Thanks for sharing that;)
From what I understand is that the airbox is "leaking" around the edges, correct me if I'm wrong...If that's the case why not just put a beat of silicone round the edge and presto...job done! I don't live in a dusty area but when I opened mine at around 4500k's I did find musquitos and smallish flies etc inside the box. (should have taken pic) ...Not good
Corsica101 is offline   Reply With Quote
Old 11-28-2013, 05:00 PM   #5147
speed_racer
speed_racer's Avatar
Oddometer: 707
Originally Posted by FuzzyDunlop View Post
I have exactly the same problem and bike has just reached my dealer. Happened 700km from home.
Hopefully I will have an answer in the next day or so but I would be keen to hear how yours goes.
Sorry to hear this.. I have noticed that mine can be hard to start sometimes, like the battery doesn't have enough CCA to kick it over, was yours the same?
I was thinking of upgrading the battery
13' KTM 1190 Adventure R
KLX650R
RIP - BMW F650 GS Twin
speed_racer is offline   Reply With Quote
Old 11-28-2013, 05:17 PM   #5148
OrangeV
OrangeV's Avatar
Oddometer: 646
Favourites settings
Hi I was just wondering if any of you would like to share what your Favourite screen settings are, I havent got the bike yet but thought this may be a good start
Are there any other ones that are absolutely essential in your mind.
Thank you for your input.
Favourites
Drive Mode
Odometer
Fuel Range
Trip1
Air temp
OrangeV is offline   Reply With Quote
Old 11-28-2013, 05:20 PM   #5149
speed_racer
Oddometer: 707
Mode: Sport
HandGrips: min
FuelRange:
Air Temp:
Trip 1: (i reset this with each tank)
i might be missing one here.. but they are the essentials. anything else like tyre pressure etc, pops up as a warning when low.
KLX650R
Old 11-28-2013, 06:06 PM   #5150
PPiA
Pete
PPiA's Avatar
Oddometer: 1,182
Heated grips
ABS
MTC
Average speed (we have point to point speed cameras)
Distance to empty
PPiA is offline   Reply With Quote
Old 11-28-2013, 07:40 PM   #5151
The "OC"
The "OC"'s Avatar
Oddometer: 137
Average cons
Air temp
Odometer
Fuel range
Trip 1
Riding mode can be seen just above the clock
The "OC" is offline   Reply With Quote
Old 11-28-2013, 08:27 PM   #5152
FuzzyDunlop
Oddometer: 273
Nope. No indication of problems before it happened. If the valves are out of whack it will be harder (or impossible) to start when cold.
I have has confirmation from my dealer that the valves are indeed jiggered and that dust is the likely cause.
Currently riding 2013 KTM 1190 Adv R
FuzzyDunlop is offline   Reply With Quote
Old 11-28-2013, 09:03 PM   #5153
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,937
Any triple clamp/bar riser available yet?
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 11-28-2013, 09:11 PM   #5154
LowSpeedHighDrag
KTM Dealer
LowSpeedHighDrag's Avatar
Oddometer: 148
There are a couple of options in the Off-Road PowerParts book.
2014ish KTM 1190 Adventure
LowSpeedHighDrag is offline   Reply With Quote
Old 11-28-2013, 10:02 PM   #5155
Audun
Audun's Avatar
Oddometer: 68
Mode: Sport
HandGrips: min
FuelRange:
Air Temp:
Ride mode
Hand grips
Air temp
Battery
Fuel range
Audun is offline   Reply With Quote
Old 11-29-2013, 12:31 AM   #5156
rompe
Oddometer: 60
Hi I was just wondering if any of you would like to share your favorites
Mode
Susp Mode
tyre front
tyre rear
heat grips (winter) range (rest of the year)
My other toy has tits . . .
rompe screwed with this post 11-29-2013 at 12:52 AM
rompe is offline   Reply With Quote
Old 11-29-2013, 02:26 AM   #5157
sleepyOwl
sleepyOwl's Avatar
Location: United Kingdom of her Majesty's Tax Collectors
Oddometer: 2,311
I have fuel range on their too but it may as well say "have a guess" the way it works!
Either that or I have a fuel tank that is always feeling very optimistic when I fill him up and get gets depressed an very pessimistic once hes half full
Everything is Amazing and No one is Happy
sleepyOwl is offline   Reply With Quote
Old 11-29-2013, 05:37 AM   #5158
numbutt
john
numbutt's Avatar
Oddometer: 101
Wise words
Wise words I was scared to offer ,,, paper filters FILTER but oiled foam largely relies on the inertia of the dust particle having it crash into the sticky oil rather than find its way through a passage in the foam....for this reason I left the paper element and only very very lightly oiled the minimal area new foam piece supplied later . it will clog rapidly.
numbutt is offline   Reply With Quote
Old 11-29-2013, 05:58 AM   #5159
Nerb
Oddometer: 207
I have
Trip1
Fuel consumption 1
Fuel Range
Air Temp
Odometer
The mode is visible above the clock, so useless in the favorites.
I wanted the oil temp in the favorites in place of air temp, but it wont let me put it there. I hope that is fixed in an update.
Nerb is offline   Reply With Quote
Old 11-29-2013, 06:24 AM   #5160
Schussboelie
Schussboelie's Avatar
Oddometer: 599
Heated grips
Fuel range
Air temp
ODO
Trip 1
Schussboelie is offline   Reply With Quote
Times are GMT -7.   It's 05:16 AM.
