Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 01-23-2014, 10:25 AM   #6301
wpbarlow
Oddometer: 10,594
That tire/rim news is too bad. I wish KTM had done better or even copied Aprilia or BMW design and paid the license fee to get a better solution.
wpbarlow is offline   Reply With Quote
Old 01-23-2014, 10:37 AM   #6302
SCflyer
SCflyer's Avatar
Oddometer: 1,605
I spooned up a set of Karoo3s (which are tubeless tires) and the rear tire would NOT hold air. Leaked rapidly from the spokes. From what I am told, unless there is sufficient air pressure to hold the rubber membrane against the rim, the tires will leak air. I believe I had about 30 lbs of air but the rear was flat in no time. The front seems to be holding air fine.
Also, the valve stem / tire pressure monitor will need to be removed and you will need to put an M10 washer under the nut for the valve stem as the hole in the rim is enlarged to accommodate the sensor. Just a suggestion.
*** - Maybe a bad rim "tape"/cover? First time anyone has mentioned this being an issue in all the other tire swaps done. ***
Either way, good luck with things and have a great trip!
"Not all those who wander are lost" J.R.R. Tolkien
SCflyer is offline   Reply With Quote
Old 01-23-2014, 11:01 AM   #6303
Keks
Oddometer: 23
There´s reports from folks that the slightly off-centre valve hole can be used with a regular tube; however it seems more of an emergency way to do things than as regular good use. There are off-center valve tubes out there for use with Milwaukee steel, but I have not found one yet with the correct size. Anyways, it appears to be possible to use the rims of the Superenduro with the original hub, which would be a solution for those of us who use the bike for trips to remote areas and regularly pack a tire iron... Needless to say these are neither tested for use with the 1190 nor approved by KTM or any vehicle authority.
Cheers
Chris
Need to fix your Africa Twin? Check out my step-by-step frame strip pictures at
Google+ album: http://tinyurl.com/6u93yv2
Dropbox with zip-File: http://tinyurl.com/czj8qgw
Keks is offline   Reply With Quote
Old 01-23-2014, 11:08 AM   #6304
chief_lee_visceral
chief_lee_visceral's Avatar
Oddometer: 378
Not me... For all practical purposes you cannot true a BMW rim once it is out.
-= Never put your finger where you wouldn't put your face =-.
chief_lee_visceral is offline   Reply With Quote
Old 01-23-2014, 11:44 AM   #6305
strider.deano
Oddometer: 333
Originally Posted by KTMforget View Post
Also - one important discovery I found. Not sure if this has been covered elsewhere. Been a little busy to keep up with the thread. If you are going to install something other than street tires, make sure you have some tubes handy. I spooned up a set of Karoo3s (which are tubeless tires) and the rear tire would NOT hold air. Leaked rapidly from the spokes. From what I am told, unless there is sufficient air pressure to hold the rubber membrane against the rim, the tires will leak air. I believe I had about 30 lbs of air but the rear was flat in no time. The front seems to be holding air fine.
That kinda sucks.....
I wonder if the same is true for the 1190 Adv Std's 17" rear?
strider.deano is offline   Reply With Quote
Old 01-23-2014, 12:45 PM   #6306
HIgh Water
Waisting Time
HIgh Water's Avatar
Location: Los Barriles, Baja - Colorado - Stuttgart Germany
Oddometer: 351
Woodys can, had them do both my GS wheels came out great. Also did my 950 with excel 7000 rims after I made octagons out of my originals. I'll bet they are working on an 1190 solution!
http://www.woodyswheelworks.com/home.htm
'04 BMW 1200 GS (Germany Bike)
'06 KTM 950 Adv S
'03 KTM 640 Adv
'06 KTM 525 EXC Baja 2008 Race Bike
'06 KTM 450 EXC
HIgh Water screwed with this post 01-23-2014 at 12:51 PM
HIgh Water is offline   Reply With Quote
Old 01-23-2014, 01:22 PM   #6307
chief_lee_visceral
Oddometer: 378
Best wheelwright in the business for sure but I meant for the end user/rider it is not practical. That said, I assuming the 1190 wheels could go on a stand like my dirt wheels but that may not be a valid assumption.
Old 01-23-2014, 06:23 PM   #6308
BigMan73
Binary Adventurer
BigMan73's Avatar
Oddometer: 295
I'm also skeptical of this.
Magazines testers have ridden factory KTMs equipped with TKC-80. Nobody complained about any issue with the tires, quite the opposite.
Tiger 800 XCx in White - Ain't she pretty?
SOLD: 2011 V-Strom 650A White Pearl. (Photo by: Lilolita. RIP dear friend )
Suzuki V-Strom (Stromtrooper) Wiki
BigMan73 is offline   Reply With Quote
Old 01-24-2014, 12:56 PM   #6309
Keks
Oddometer: 23
Getting back to the issue of air filter and airbox. I am not too confident that the front inlet of the airbox snorkels will not take in water when crossing a creek. Apparently, some others are not overly confident, too. Check out this solution from South Africa. This could prove to be an excellent mod.
Cheers
Chris
Old 01-24-2014, 01:42 PM   #6310
PPiA
Pete
PPiA's Avatar
Oddometer: 1,182
Not sure where you got that idea.
I've trued them before.
PPiA is offline   Reply With Quote
Old 01-24-2014, 01:51 PM   #6311
docgonzo
Old Gadfly
docgonzo's Avatar
Location: within 20 miles of the Center of the Universe
Oddometer: 13,461
The rims on my 1150 GS have 100,000 miles on them, and are still going strong. Can run the rims tubeless of course, but also with a tube if you get a puncture and your not happy with the plugging. Did that on a new tire, and got the full use out of it. Have never had to adjust the spokes.
Surprised KTM couldn't come up with rims for this "Adventure" bike that couldn't easily use knobby tires. Seems a shame that you have to spend an additional $1,500 for new rims just to play in the dirt.
By the way, the rims on the SuperEnduro are pretty tough, compared to what used to come on the old Adventures. Hopefully, the rims on the new Adventure will be tough off of the asphalt.
later, *
docgonzo is offline   Reply With Quote
Old 01-24-2014, 02:08 PM   #6312
CHRIS_D
CHRIS_D's Avatar
Oddometer: 932
I think you would be getting off cheap spending only $1500. The other problem that I see with the tubeless tires is that you aren't able to lower the air pressure down all that much for traction.
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 01-24-2014, 03:59 PM   #6313
nikoktm
nikoktm's Avatar
Oddometer: 276
I'm not agree with that. I have the Karoo 3 for almost 5 months now and never have that issue!.
nikoktm is offline   Reply With Quote
Old 01-24-2014, 04:02 PM   #6314
nikoktm
nikoktm's Avatar
Oddometer: 276
I ordered a new set of rims.Still waiting for the back one. I will post the photos as soon I have those ones.
Old 01-24-2014, 09:12 PM   #6315
hochdoerffer
Oddometer: 2
Question front wheel-off balance
Hi,
picked up my new toy ( Adventure Std Grey) from my dealer Tuesday and had to return it after finding out that the front tire is completely off balance.
Counted the wheel weights the factory added to the front wheel ..160 gr.
Looks like I am getting a new front wheel..
Anyone had a similar issue??
hochdoerffer is offline   Reply With Quote
Times are GMT -7.   It's 06:37 PM.
