Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 02-18-2014, 10:28 PM   #6466
paturoa
paturoa's Avatar
Oddometer: 250
Originally Posted by BigMan73 View Post
Why not lower the bike with different dog bones?
Many short V-Strom Riders have gone that route, with much success.
It is also a reversible solution, when you want to sell the bike in the future.
There are a number of aftermarket Dog Bone manufacturers, try contacting them.
EDIT: This is the V-Strom Wiki page for dog bones, but the idea should be similar, and the different vendors are likely to be the same ones for KTM.
http://stromtrooper.wikispaces.com/Suspension+Links
There are no dog bones (on the R - suspect that the std model is the same). The shock bolts to the cross member that you can see in sleepy owls photo above (the ali piece just under the wiring loop between the arrows) and the bottom of the shock bolts directly to the swing arm. So no solution there. It is probably a PDS shock.
paturoa is offline   Reply With Quote
Old 02-18-2014, 10:35 PM   #6467
Wonway
KTM Fanboi #2
Oddometer: 423
Originally Posted by docgonzo View Post
Take a beautifully proportioned, aesthetically pleasing bike that's great fun to ride, then add a giant tumor to the back, so it looks like the hunchback of Notre Dame…. Don't get it:
In Russia, topcase holds motorcycle.
1994 Ducati 888 LTD #61
2008 Husqvarna TE610
2014 KTM 1190 Adventure R
Wonway is offline   Reply With Quote
Old 02-18-2014, 10:46 PM   #6468
IgorBorisenko
adventurer
IgorBorisenko's Avatar
Oddometer: 63
Yep!
Need lots of space for a pocketable bear, Vodka box and a small red nuclear command center over here.
IgorBorisenko is offline   Reply With Quote
Old 02-19-2014, 06:47 AM   #6469
BigMan73
Binary Adventurer
BigMan73's Avatar
Oddometer: 259
Thanks for clarifying this.
My White Pearl. Photo by: Lilolita. RIP dear friend
Suzuki V-Strom (Stromtrooper) Wiki
BigMan73 is offline   Reply With Quote
Old 02-19-2014, 02:50 PM   #6470
Thagua
Let's go adventuring...
Thagua's Avatar
Oddometer: 354
Heat shields for KTM 1190 standard
Working on the new heat shields for the standard model without crashbars
As soon finished will post definite photos
Cheers,
Roberto
'Let's go adventuring'
Thagua is offline   Reply With Quote
Old 02-20-2014, 01:15 PM   #6471
ternus
El Gran Camino
ternus's Avatar
Oddometer: 90
Will this fit the 2014 standard with crash bars, or should I be getting the R-model for that?
ternus is offline   Reply With Quote
Old 02-20-2014, 08:27 PM   #6472
Thagua
Thagua's Avatar
Oddometer: 354
Standard with crashbars
You should ask for the R-model (same price)
Cheers,
Roberto
Old 02-21-2014, 03:42 AM   #6473
jj_pt
Oddometer: 45
Originally Posted by IgorBorisenko View Post
Yep!
I'm thinking in possibly getting the new Shad SH39, but I've read it's limited to 120 Km/h. It's not really compatible with a 1190.
IgorBorisenko, do you notice any speed limits on yours?
2013 KTM 1190 Adventure R.
2010 Yamaha XT660Z Ténéré (Sold).
jj_pt is offline   Reply With Quote
Old 02-21-2014, 05:12 AM   #6474
docgonzo
Old Gadfly
docgonzo's Avatar
Location: within 20 miles of the Center of the Universe
Oddometer: 13,386
I had a Honda Blackbird (CBR 1100XX...http://en.wikipedia.org/wiki/Honda_CBR1100XX) for a few years. It was a beautiful and fast bike. I decided I needed luggage, so got two GIVI side cases and a top case for the beast. It turned it into a very dangerous tank-slapper machine.
My engineering/physics explanation was that the weight I had added was behind the rear wheel axle, causing the center of gravity of the machine to shift dramatically towards the rear from the balanced bike that it was. This lightened the front end, who's geometry was upset. On fast acceleration, unexpected tank slappers were fairly common, with the bike trying to spit me off. I'd worry more about that then the speed restriction.
later, *
docgonzo screwed with this post 02-21-2014 at 09:10 AM
docgonzo is offline   Reply With Quote
Old 02-21-2014, 07:14 AM   #6475
Black Hills
Oddometer: 1,138
My engineering/physics explanation was that the weight I had added was behind the rear wheel access, causing the center of gravity of the machine to shift dramatically towards the rear from the balanced bike that it was. This lightened the front end, who's geometry was upset. On fast acceleration, unexpected tank slappers were fairly common, with the bike trying to spit me off. I'd worry more about that then the speed restriction.
I believe wind plays a huge factor as well. a friends FJR works fine with a heavy load in the saddle bags, but add the top box and it develops a wobble no matter if it is loaded or not?
Black Hills is offline   Reply With Quote
Old 02-23-2014, 06:13 AM   #6476
IgorBorisenko
adventurer
Oddometer: 63
As far as I know all the topboxes, including OEM ones have this or close speed limit. (givi claims 130) Can not test this setup yet due to the season here.
I expect it to be OK up to say 160. For more I'd expect stability issues.
But, In sense of aerodynamics my guess is that an Alu square top box of 40l will be a worse case than this 48l plastic round shaped
Old 02-23-2014, 10:18 AM   #6477
sleepyOwl
sleepyOwl's Avatar
Location: United Kingdom of her Majesty's Tax Collectors
Oddometer: 2,304
Finally got round to fitting the Zumo. This has got to be the easiest bike I have fitted it to.
Took the time to update the splash screen image too
Everything is Amazing and No one is Happy
sleepyOwl is offline   Reply With Quote
Old 02-23-2014, 11:28 AM   #6478
Dualsport Crazy
Oddometer: 108
Looks great sleepyOwl
Which GPS mount did you use ?
Thanks for sharing the picture !!!
Dualsport Crazy is offline   Reply With Quote
Old 02-23-2014, 11:40 AM   #6479
sleepyOwl
sleepyOwl's Avatar
Oddometer: 2,304
thanks DC
The bike came with the OEM mount so I used that. Feels a bit flimsy though so double tightened everything!
Wont have time to test it this week unfortunately.
Old 03-11-2014, 02:09 AM   #6480
Tails_KTM
Tails_KTM's Avatar
Oddometer: 62
Sorry if this is subject has been covered, there's a lot of posts...
I just went to my dealer to have the Bosch MSC installed. They say it has been pulled off KTM's servers because the software presented issues with the speedometer readout in some way. New software should be available in April. I'm definitely waiting until it's right before I have my bike messed with an pay for it too!
My 2013 1190 also needed several updates, both software and hardware. They mentioned the sidestand (I already had a new spring for that) and something about the centerstand. Not quite sure what else but I'm having everything done at the same time.
Can give full details somewhere in April in case anyone is interested.
Tails_KTM is offline   Reply With Quote
Times are GMT -7.   It's 10:50 PM.
