Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-17-2014, 11:49 AM   #6721
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,110
Originally Posted by ChrisK7 View Post
Sounds like you may have a pin hole in the rubber strip over the spokes. This happened to someone else I know.
I personally like the tubeless setup. I've already plugged the rear tire on my bike 3 times with good luck.
Kag to the red phone
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is online now   Reply With Quote
Old 06-17-2014, 06:17 PM   #6722
kag
Wander Lust
kag's Avatar
Oddometer: 1,715
I just put 6 oz of slime in the rear tire and sealed it up after about 50 miles. Did absolutely nothing to the TPMS....works fine. Same slow leak type issue. Now have 3k + miles since doing it and all is well
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 06-17-2014, 10:13 PM   #6723
Bluesilver
Bluesilver's Avatar
Oddometer: 343
It does nothing initially however, even the manufacturers warn you that the slime will damage the transmitter in your tyre, if you doubt this then read up on the countless service bulletins on the net warning people against the use of tyre sealants.
I say, you get a puncture and don't have a tyre plug in your pack which I carry two packs of with CO2 cans and a hand pump, then use the sealant but as soon as you can, have the tyre taken in, rim cleaned, puncture repaired and transmitter cleaned.
But that is me as those transmitters cost PLENTY and fitment centers like to damage them when they reseat the tyres in the machine.
Bluesilver is offline   Reply With Quote
Old 06-18-2014, 12:58 AM   #6724
pinglow
pinglow's Avatar
Oddometer: 246
What is in the owner's folder content? The one you get when u take delivery of the bike?
Saw someone posted pics of the whole set.
Ready to RACE!
pinglow is offline   Reply With Quote
Old 06-18-2014, 04:29 AM   #6725
kag
Wander Lust
kag's Avatar
Oddometer: 1,715
Its the liner that's leaking.
Well when the transmitter dies I will let you know. The TPMS dies eventually no matter what so we will see how long it lasts. At the next rear tire I put on I plan to look at the liner and see what I can come up with to fix it but until then .....
Old 06-18-2014, 05:15 AM   #6726
Bluesilver
Bluesilver's Avatar
Oddometer: 343
Ok then for sure only "slime" will be a quick fix...to date I've been lucky, no problems guess I must add slime to my puncture kit before I leave.
Old 06-18-2014, 03:28 PM   #6727
CaliBerger
CaliBerger's Avatar
Oddometer: 436
good info!
CaliBerger is offline   Reply With Quote
Old 06-22-2014, 01:28 AM   #6728
PilbaraGoat
PilbaraGoat's Avatar
Oddometer: 218
Is there such a thing yet as a 300mm suspension upgrade for the 1190r?
Difficulties be Damned
PilbaraGoat is offline   Reply With Quote
Old 06-22-2014, 01:42 AM   #6729
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,413
Don't think so
Limited to 285-265 can't remember what one. Lower chain slider and exhaust position
ebrew is offline   Reply With Quote
Old 07-07-2014, 11:57 AM   #6730
Audun
Audun's Avatar
Oddometer: 68
Tire pressure sensor location
Does anybody know where the sensors are relatively to the filling valve? A tyre change is coming up. I tried to guess based on balancing weights, but it didn't give me any conclusion.
Audun
Audun is offline   Reply With Quote
Old 07-07-2014, 12:05 PM   #6731
bigboyxl
bigboyxl's Avatar
Oddometer: 328
Audun
TPMS sensor is located exactly on the filling valve, it's a approximately 5 cm long and 2 cm heigh plastic thing, just be careful near the valve and you'll be good
KTM LC4 640 Adventure 2006 KTM 530 EXC 2011
KTM LC8 1190 Adventure
www.alburmoto.com
Nomada panniers, Holan crashbars, Remus silencers etc. Worldwide shipping. Better deals for ADVriders
bigboyxl is offline   Reply With Quote
Old 07-07-2014, 09:11 PM   #6732
Bluesilver
Bluesilver's Avatar
Oddometer: 343
yep, the transmitter is a small block that does not move, most damage is done when they slide in the tyre lever at the valve stem where the unit sits but mostly when they refit the tyre in the machine as it rotates to be reseated...units snap clean off and are FLIPPING expensive...my last two were damaged on my pickup and that is the price of a complete new setup so for sure, KTM will be....very expensive to replace.
One fact, these sensors have build in batteries normally and they have around 5yrs lifespan, once dead you have to replace the complete unit, my experience so far with KTM, it ain't gonna last 5 yrs...
Old 07-08-2014, 09:24 AM   #6733
Spayn
Oddometer: 105
Hi, having high vibrations on handlebar at 150+ km/h speed. Any suggestions?
Spayn is offline   Reply With Quote
Old 07-08-2014, 02:04 PM   #6734
bigboyxl
bigboyxl's Avatar
Oddometer: 328
Did your dealer check the steering damper as the factory proposed? If the damper is ok, try balancing the wheel - I had the same issue
www.alburmoto.com
Old 07-08-2014, 02:43 PM   #6735
veesquared
Oddometer: 126
Question Is it something new?
If it is a new vibration have you made any changes like saddlebags , exhuast , skidplate? Check your fasteners. How is your chain adjustment. How many miles on your bike? Do you only feel it in the bars?
KTM 1190 KTM 690 E KTM 200 Exc
veesquared is offline   Reply With Quote
Times are GMT -7.   It's 07:49 AM.
