Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 07-08-2014, 10:47 PM   #6736
Bluesilver
Bluesilver's Avatar
Oddometer: 393
Originally Posted by Spayn View Post
Hi, having high vibrations on handlebar at 150+ km/h speed. Any suggestions?
Look for the simple problem, wheel balancing.
Then check, under hard braking you feeling a knock through the steering...or hearing a knock..if so your steering bearings need to be torqued and thread locked.
Damper will only stop the tank slapping when the front gets light and road undulations force the wheel to track left and right or a stone or bump at speed...faster you go the worse it gets.
Again, start with the easy one, wheel balancing.
Bluesilver is offline   Reply With Quote
Old 07-08-2014, 11:45 PM   #6737
Spayn
Oddometer: 140
Yes i hear the knock when hard braking. Thanks for tips, will check.
Spayn is offline   Reply With Quote
Old 07-09-2014, 02:05 AM   #6738
Bluesilver
Bluesilver's Avatar
Oddometer: 393
There are a shyte load of questions on this steering problem all over the forum, KTM MUST thread lock the nut.....I spent 11 months fighting with KTM to sort their shyte out and it's fianlly fixed my side now.
Oh and don't lift the frontend pulling the forks like we used to the do to see if there is play, the play is so small you will not notice it unless you braking...been down that as well.
Old 07-09-2014, 02:08 AM   #6739
Spayn
Oddometer: 140
Loctite will work also?
Old 07-09-2014, 02:12 AM   #6740
Bluesilver
Bluesilver's Avatar
Oddometer: 393
That is the stuff......just remember, when you use the stuff your torque settings will change a bit to the factory spec. I left it to the KTM dealer as it was their shyte and the bike is under warranty.
Old 07-09-2014, 09:35 AM   #6741
The "OC"
The "OC"'s Avatar
Oddometer: 137
Also have a look at the two bolts right at the bottom of the front forks, I also had a knock but it was not the steering it was that these two bolts had gone AWOL!
The "OC" is offline   Reply With Quote
Old 07-09-2014, 02:08 PM   #6742
4bikes
Oddometer: 245
My 2013 1190 adv std.
I bought my 1190 std 6 weeks ago. Since then I have more than doubled its milages to about 7000 km. Around 600km are done on a race track. The 1190 is my 4th KTM. The earlier bikes
Have performed perfectly, and so has this so far.
The bike is definatly fast at the track, it's very nice on the road, and take me true the gravel and singletrack with ease aswell.
I have put on some assessories like ome heated grips, skidplate and engine protection. A Madstad 20" windshield, Scottoiler, Wings heatshield, SW-MOTECK side panniers and a Givi topbox.
4bikes screwed with this post 07-13-2014 at 06:18 AM
4bikes is offline   Reply With Quote
Old 07-16-2014, 11:51 PM   #6743
pinglow
pinglow's Avatar
Oddometer: 257
Do not want to mess up anything so just checking. As I do not a garage I need to disconnect the battery and bring it up my apartment to charge. Will the bike show up any fault code after connecting back?
If I do not recall wrongly some owners had some fault codes showing..
pinglow is offline   Reply With Quote
Old 07-17-2014, 12:51 AM   #6744
Spayn
Oddometer: 140
It shouldn`t.
2013 KTM 1190 ADVENTURE EU
2013 KTM 250 SX 2 stroke beast
Old 07-17-2014, 04:21 AM   #6745
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,439
No
You will have to rest the time and date settings when you turn it back on
ebrew is offline   Reply With Quote
Old 07-17-2014, 04:42 AM   #6746
pinglow
pinglow's Avatar
Oddometer: 257
It shouldn`t.
Thank you gentlemen!
Old 07-24-2014, 02:36 AM   #6747
Alarm
Oddometer: 294
Hello.
Since yesterday i am a new owner of 2013 1190 .
On my very first ride i noticed that when i brake i hear a "clicking" sound when the suspension compresses and again a click sound when the suspension returns to normal position.
It does not sound like a deeper noise like a lose bearing (i think), but more like a click sound almost every time i brake. I could not locate where it comes from, but i think that it comes somewhere from the upper part of the bike (front).
Any ideas ?
Alarm is offline   Reply With Quote
Old 07-24-2014, 05:24 AM   #6748
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,120
Front brake disc. Lots of stuff here on this
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is offline   Reply With Quote
Old 07-24-2014, 05:45 AM   #6749
Bluesilver
Bluesilver's Avatar
Oddometer: 393
Originally Posted by Alarm View Post
Hello.
Any ideas ?
Steering header bearing........................................... ....
Old 07-24-2014, 06:51 AM   #6750
Alarm
Oddometer: 294
I am expecting a different noise from the bearing. I am not exlcuding it though.
Times are GMT -7.   It's 12:47 AM.
