Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 07-24-2014, 06:52 AM   #6751
Alarm
Oddometer: 292
Originally Posted by pizzaboy View Post
Front brake disc. Lots of stuff here on this
It does it also when i compress the suspension without moving the bike.
What was the problem with the brake discs ? Lose rings ?
Alarm is offline   Reply With Quote
Old 07-24-2014, 07:45 PM   #6752
1190ADV
1190ADV's Avatar
Oddometer: 32
Originally Posted by Alarm View Post
I am expecting a different noise from the bearing. I am not exlcuding it though.
Had the same exact issue within the first hundred miles. Torqued the steering head bearing and it's been good since. Added a little blue thread locker also. Noticed most under braking but could also do it sitting still like you described.
1190ADV is offline   Reply With Quote
Old 07-24-2014, 10:56 PM   #6753
Alarm
Oddometer: 292
That is very helpful . Thank you very much.
Old 07-25-2014, 09:55 AM   #6754
The "OC"
The "OC"'s Avatar
Oddometer: 137
18500km and still going strong ! Go 2013 models !
Sent from my iPad using Tapatalk HD
The "OC" is offline   Reply With Quote
Old 07-28-2014, 10:26 PM   #6755
Alarm
Oddometer: 292
Went to the dealer. You were correct. It was the bearing.
Old 07-29-2014, 04:29 AM   #6756
alongat
alongat's Avatar
Oddometer: 1,235
Same experience here - took the bike in for its first service, they re-torqued the head bearing (and told me that the bearing race was actually not completely in all the way ever so slightly), a tiny bit of blue fairy blood and zero issues since despite many glorious and adventeurous KMs ridden since. Job done...
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 07-31-2014, 01:22 AM   #6757
PilbaraGoat
PilbaraGoat's Avatar
Oddometer: 218
Where can I go to hear gossip relating to updates for the 2015 model.
How about a 30litre tank, suspension lift (maybe between 265 and 300mm would be cool), and faring which actually reduces buffeting rather than increasing it?
Difficulties be Damned
PilbaraGoat is offline   Reply With Quote
Old 07-31-2014, 04:05 AM   #6758
alongat
alongat's Avatar
Oddometer: 1,235
For all you KTM windscreen haters (just kidding: for those of you, like me who could never find the right position for the windscreen and have tried other screens and tried to convince yourself that they work...), try removing your mirrors and go for a ride. I installed my CPR Rottweiler CRG Arrow mirrors yesterday and removed the stock mirrors and wow - proving again that KTM cannot manage to make aerodynamic mirrors that don't create buffeting. I'm not just talking about dirty air hitting your shoulders, this totally cleaned up the air on the sides of my helmet and the air is sooooooooooooo smooth now - zero buffeting :)
Toronto, Canada
Old 07-31-2014, 07:29 AM   #6759
DirtJack
DirtJack's Avatar
Oddometer: 1,600
As long as you're taking stuff off, don't forget the hand guards. WRT wind noise/buffeting, my HDB setup is quite different than OEM. Body size, and helmet brand/type also make a huge difference. Forget I said this as it sounds like yet another wind screen thread.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 07-31-2014, 09:14 AM   #6760
RobZorba
RobZorba
RobZorba's Avatar
Oddometer: 437
Originally Posted by Bluesilver View Post
There are a shyte load of questions on this steering problem all over the forum, KTM MUST thread lock the nut.....I spent 11 months fighting with KTM to sort their shyte out and it's fianlly fixed my side now.
Oh and don't lift the frontend pulling the forks like we used to the do to see if there is play, the play is so small you will not notice it unless you braking...been down that as well.
Thanks a lot for the "heads up". It was the same on my 2014 - checked at 3,500 km. There was play in the head bearings causing a clunk when braking and sometimes when cornering. The nut needed tightening and thread locking. The nut coming loose is a safety concern.
KTM 1290 SA, KTM 1190R, Suzuki VStrom 650 ABS, Honda ST1300, Suzuki SV650, Yamaha RD250
RobZorba is offline   Reply With Quote
Old 07-31-2014, 10:09 AM   #6761
alongat
alongat's Avatar
Oddometer: 1,235
Good point - I've always believed that ktm handguards are aerodynamically flawed. Personally, I don't like handguards with metal reinforcement on a bike this heavy so if I did change mine out, I'd probably consider the touratech plastic guards as they're quite good (and I generally don't love touratech).
Toronto, Canada
Old 07-31-2014, 03:15 PM   #6762
DirtJack
DirtJack's Avatar
Oddometer: 1,600
The HDB sure are nice when the bike goes down, saving the levers, bar, etc.
2008 KTM 690 Enduro
Old 07-31-2014, 03:19 PM   #6763
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,414
For sure
+1 hdb
ebrew is offline   Reply With Quote
Old 07-31-2014, 04:18 PM   #6764
Bigem
Bigem's Avatar
Oddometer: 2,565
Wink
Adding that much to the height of it would mean you would have to be 8 foot tall to sit in it!!
"I'm a thousand miles from nowhere,
Time don't matter to me,
Cause I'm a thousand miles from nowhere,
And there's no place I'd rather be!!
Bigem is offline   Reply With Quote
Old 07-31-2014, 04:31 PM   #6765
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Originally Posted by ebrew View Post
+1 hdb
The set I have on my 1190R were on my 990 for a few years. Both bikes have been down on the dirt and pavement. No damage to anything on the bars or the HDB itself (except mars to the black finish which were "fixed" with a file and black permanent marker).
2008 KTM 690 Enduro
Times are GMT -7.   It's 02:24 PM.
