Old 11-20-2012, 12:32 PM   #61
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 549
Online calculator:
http://www.mez.co.uk/mezporting/exhaust_length.html
Cheers, Jon-Lars Sorenson
Beverly, WA
http://www.facebook.com/BMWR90S
Jon-Lars is offline   Reply With Quote
Old 11-21-2012, 10:53 AM   #62
Leadnuts OP
do-over...
Leadnuts's Avatar
Oddometer: 116
Originally Posted by Jon-Lars View Post
Wow, thats a nice link..
Couple of things though... He mentions that adjusting the length of primaries with change various power outputs, but does not mention what adjusting the tail piece will do? I like the shorter look and am curious if its going to mess things up? Also do adding a few bends mess things up?
Regarding the CL (collector box) it calculates out to 5.761", my question is what is that measuring... the length of the part, the length of the opening in which pipes are merging?
Is it worth getting stainless pipe, it really doesn't seem that much more if you look at some sort of heat resistant coating costs with steel? I really like that look of spring held joints.
Leadnuts is offline   Reply With Quote
Old 11-22-2012, 10:45 PM   #63
khale
ride dirty
khale's Avatar
Oddometer: 557
Pretty rad man. I have a 72 toaster and love it. I believe Butch Walker (famous Atlanta, GA rock n roller) has a cafe'd toaster:
Wes Burden of Apex Cycle did a lot of work on his ride
2013 BMW R1200 GSW | 1972 BMW R75/5 toaster | 2011 Husky TE310
"4 wheels move the body, 2 wheels move the soul"
khale is offline   Reply With Quote
Old 01-13-2013, 07:19 PM   #64
Leadnuts OP
do-over...
Leadnuts's Avatar
Oddometer: 116
exhaust
Today I got a few parts of the exhaust cut and staged up... It had a 2 to 1 Luftmeister when I got it, but the headers were a banged up so I needed to figure something else out. Found a few stainless mandrel bends on the cheap.. Ended up going with stainless after calculating its cost vs. needing some sort of coating on the mild steel version.. Stainless was waaaaay cheaper.
Staged up the collector to roughly what I was thinking. It is offset to get to the oil drain plug as well as to even out the length of headers due to the left on being set forward. Cut strips of board to figure out the angles I needed.
[IMG]WP_001237[/IMG]
After a few cuts this is what I've got..
[IMG]WP_001238[/IMG]
Aaaand the underside. Need a couple more bends to snake out the side between the stand and frame but its a start.
[IMG]WP_001240[/IMG]
I think I will install spring joints between the collector and headers
Thanks for lookin'
Old 01-13-2013, 08:41 PM   #65
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,796
Damn Dude, that looks beautiful! I love spring joints as well, so much from me!
Old 01-14-2013, 01:46 PM   #66
Leadnuts OP
do-over...
Leadnuts's Avatar
Oddometer: 116
Thanks, i was getting a bit depressed with my lack of progress... but I'm pretty happy with where it's going.
Anyone.. Do I need to be concerned with making an oil collection can?
thanks.
Old 01-14-2013, 05:40 PM   #67
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,940
Are you Sure you will be able to get that oil pan off with out disturbing the pipes? Oil change won't drip on hot pipe?
It does look nice. I like custom exhaust systems on Beemers.
---Albert Einstein
disston is online now   Reply With Quote
Old 01-14-2013, 07:27 PM   #68
Leadnuts OP
do-over...
Leadnuts's Avatar
Oddometer: 116
Yea, not a problem... the collector is well to the side of the drain plug, and when the pan needs to drop it will be an extra 5 mins tops to pull the pipes back and to the side.
I sure hope I don't have to do it again as my arms are noodles from hacksawing and filing... AAAnd just realized I have to have a different gas to weld stainless
and thank you.
Old 01-14-2013, 08:09 PM   #69
supershaft
because I can
Oddometer: 9,116
I have never been interested in fabbing stainless exhaust. I have always kept my stuff painted. It isn't that hard? I never had a problem with corrosion but I never packed my silencers either. Some say they run better packed. They sure are quieter!
Old 01-14-2013, 08:15 PM   #70
Houseoffubar
fine beer sampler
Oddometer: 1,796
Are you Mig welding this?
Old 01-15-2013, 08:10 AM   #71
Leadnuts OP
do-over...
Leadnuts's Avatar
Oddometer: 116
yeah, I don't have enough experience to try and TIG them.
Old 01-15-2013, 10:26 AM   #72
Houseoffubar
fine beer sampler
Oddometer: 1,796
I got ya, just wondering why different gas, but that explains it.
I just love the aesthetics of the pipe layout! gonna be one bad looking setup!
Old 01-15-2013, 10:54 AM   #73
Leadnuts OP
do-over...
Leadnuts's Avatar
Oddometer: 116
Wait, is it possible to TIG with what I have for mild steel? Is it possible to stick weld them w/o a gas?
Old 01-15-2013, 01:08 PM   #74
Houseoffubar
fine beer sampler
Oddometer: 1,796
I would not weld them with stick, that is better for thicker material. What do you have for a tig setup?
Old 01-15-2013, 01:21 PM   #75
Leadnuts OP
do-over...
Leadnuts's Avatar
Oddometer: 116
Gas-wise I have 80/20 mix for steel... as for the actual TIG its nothing special but only DC,
Times are GMT -7.   It's 10:48 AM.
