Old 04-24-2012, 02:00 PM   #1
Katoom119 OP
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
Safari tank owners!!!
Mods you can merge this if needed, I just didn't want it to get buried in the Safari tank threads.
Check your fuel lines coming out of the fuel petcocks. I had one rubbing against the battery box cover and rubbed through the fuel line. Time to break out the Dremel.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 04-24-2012, 02:31 PM   #2
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,973
Why not just space the bottom of the tank out a little with a larger fender washer over the bolt. This gives more support to the tank from pushing in on crashes too?
I guess a pic would help.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 04-24-2012, 02:39 PM   #3
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
Yeah it happened right when I was headed to a final exam review.
From the petcock, there is a part of the plate that is recessed right above the lower tank bolt. That little recessed area was what was rubbing the fuel line right where it connected to the petcock.
Pictures to come.
Old 04-24-2012, 06:37 PM   #4
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
Ok, here's a picture and a better story.
On MY bike, and I stress that this is only mine and I'm not saying that Safari tanks are a bad design, will steal your girlfriend, and vote ___________, the fuel hose that connects to the petcock had touched the battery cover plate right where my finger is pointing in the picture above. It had actually worn the rubber right that was covering the tip of the petcock.
Now that I had a chance to think about it (because I was cursing in 3 languages trying to get it to stop leaking fuel so I could go to a law exam review), I had to ride with it for about 50 miles because I sold my old crash bars and couldn't find the bolts that would allow me to bolt the battery cover plate back on. No harm, I thought, because I thought there was enough clearance to allow for that. Well, I was wrong (no surprise).
Moral of this (psychotic) story is when you fit your Safari tanks, check to make sure there is enough clearance between the petcock and the cover plate. There is just barely enough to see light around mine so I'm going to grind some of it away simply because I want more clearance.
Old 04-25-2012, 05:36 AM   #5
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,973
I too had the same thing many years ago. Save your time grinding away at the cover plate, it will only get worse again with time.
Or.....
Why not just space the bottom of the tank out a little with larger fender washers over the bolt. This gives more support to the tank from pushing in on crashes too?
Reason I say this again, is that the rubber grommets on the bottom tank mount WILL push into the tank. You can see that there is about an 1/8" of space now. After a few dirt naps it will be zero. A larger washer /Disc ( I made some .2" thick Alum discs about 2" in dia) that fit there to prevent it from getting worse. This is mounted between the OEM Alum spacer IN the tank and the Tank mounting plate.
If you need help sourcing this, send me an email. I'll see if I can turn some up.
Good Luck.
cjracer screwed with this post 04-25-2012 at 07:23 AM
Old 04-25-2012, 07:16 AM   #6
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
Ok, I'm with you now. I didn't know how thick the spacers were. My dad's does a lot of gunsmithing and machining so I'll send him some dimensions and see if I can get him to cut some out of some old barrel blanks.
Thanks CJ!
Old 04-26-2012, 08:45 PM   #7
kailwathne
Adventure Rider
Oddometer: 262
I had a conflict with my valves as well but I just flipped them 180 degrees in the mounting holes so the hose faces forward, I lengthened the hose length and looped the hoses back around. It was a simple solution and has worked fine for over three years. no machining or cutting required.
Kail
kailwathne is offline   Reply With Quote
Old 05-01-2012, 02:05 PM   #8
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
Took your advice, CJ...
Pretty simple and pretty affordable... quick trip to Ace Hardware for some M8 washers and 2 new M8 bolts.
FYYFF!
http://www.youtube.com/watch?v=NtpUv4VBDhA
Bikes: 2013 BMW K1600GT
A Few Past Bikes
: 2003 Suzuki DRZ400E | 2012 BMW K13S | 2009 KTM 990 Adventure
Narsisco Lopez is offline   Reply With Quote
Old 05-01-2012, 03:20 PM   #9
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,973
What's the thickness you ended up with? might need to make up a batch....
Old 05-01-2012, 03:24 PM   #10
Narsisco Lopez
Addlepated
Oddometer: 2,207
Just about 15mm. I had to go from a M8 50 (stock bolt) to a M8 70. (Though an M8 60 would be plenty... Ace didn't have any 60s)
FYYFF!
A Few Past Bikes
Old 05-01-2012, 09:41 PM   #11
mdfehrmann
mdfehrmann's Avatar
Oddometer: 338
Ya I noticed mine are getting tight as well and need to do some shimming to get it off the brace.
Small price to pay to ride the distance.
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo-
2006 KTM 950 ADV S - 2004 Sherco 2.9
http://www.mdfeditions.com/
http://www.cjdesignsllc.com/
mdfehrmann is offline   Reply With Quote
Old 05-02-2012, 05:07 AM   #12
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,973
Sounds good.
You're going to want to get something larger in Diameter though. First fall and it will push the tank over the rubber grommet and be back where you started. I'll see if I can get you some test parts sent out.
Old 05-02-2012, 05:46 AM   #13
Narsisco Lopez
Addlepated
Oddometer: 2,207
Sounds good.
FYYFF!
A Few Past Bikes
Old 05-02-2012, 06:58 AM   #14
xdbx
Motorcycle Connoisseur
xdbx's Avatar
Oddometer: 2,502
Sounds good.
+1.
Just go back into Ace and look specifically for "fender Washers".
Daniel
2005 KTM 950 Adventure S
2004 KTM 525 exc
2006 Beta Rev3
xdbx is offline   Reply With Quote
Old 05-02-2012, 12:04 PM   #15
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,187
Sounds good.
Funny, I've done this mod too. The largest washers I could find are nearly the same diameter of the grommet.
So I cut a piece out of a flat bar to make up for it and it works. But I have some round and some square.
Sign me up for a proper set Craig.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Times are GMT -7.   It's 03:09 AM.
