Old 05-02-2012, 02:18 PM   #16
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
Originally Posted by bikyto View Post
Funny, I've done this mod too. The largest washers I could find are nearly the same diameter of the grommet.
So I cut a piece out of a flat bar to make up for it and it works. But I have some round and some square.
Sign me up for a proper set Craig.
See what happens when you post, CJ? You end up with even MORE work
(Hope you know how much we all appreciate it, though )
FYYFF!
http://www.youtube.com/watch?v=NtpUv4VBDhA
Bikes: 2013 BMW K1600GT
A Few Past Bikes
: 2003 Suzuki DRZ400E | 2012 BMW K13S | 2009 KTM 990 Adventure
Narsisco Lopez is offline   Reply With Quote
Old 05-02-2012, 02:24 PM   #17
Katoom119 OP
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,836
No joke. I sent CJ an email asking about his ver.2 light brackets for the Rigid lights I plan to buy this fall. Poor guy has such a workload that you have to plan a purchase months in advance!
Nah it's good to have products that are of such a quality that people are keeping you busy. Hell if he quit doing shipping I'd ride up there and pick it up myself.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 01-12-2013, 01:46 PM   #18
catalina38
Contrarian
Oddometer: 1,622
Originally Posted by cjracer View Post
I too had the same thing many years ago. Save your time grinding away at the cover plate, it will only get worse again with time.
Or.....
Why not just space the bottom of the tank out a little with larger fender washers over the bolt. This gives more support to the tank from pushing in on crashes too?
Reason I say this again, is that the rubber grommets on the bottom tank mount WILL push into the tank. You can see that there is about an 1/8" of space now. After a few dirt naps it will be zero. A larger washer /Disc ( I made some .2" thick Alum discs about 2" in dia) that fit there to prevent it from getting worse. This is mounted between the OEM Alum spacer IN the tank and the Tank mounting plate.
If you need help sourcing this, send me an email. I'll see if I can turn some up.
Good Luck.
I put a couple of large 2" OD 1.0625" ID 0.11" thick 18-8 made in the USA stainless washers between the lower mount rubber bushing and the Safari tanks with a couple of smaller washers to provide some extra clearance. I may put a piece of thin rubber
to cushion the washer against the tank
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 screwed with this post 01-12-2013 at 02:27 PM
catalina38 is offline   Reply With Quote
Old 11-13-2014, 09:10 PM   #19
SoloRide
Oddometer: 5
Safari tanks
I'v just bought used crf450x with safari tanks,21front with saddle tank rear..But fill up and is start to leak from rear tank, then there was continuous fuel out from carburator black small hose,breather I think!..what a bad sell,it was my first attempt,wake up early morning..
SoloRide is offline   Reply With Quote
Old 11-13-2014, 09:21 PM   #20
Qwik
Adrenaline Addict
Oddometer: 6,739
I found an aluminum spacer that's about 14mm and spaced mine out because I didn't like the lack of space.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 11-13-2014, 09:36 PM   #21
Dusty
Dusty's Avatar
Oddometer: 1,297
I need to do this as well but it sure would be nice to have a all in one piece like CJ was talking about, I dont mind paying the Quality that come from him.
I think every Safari tank owner would buy them.
Hate to have more pieces to keep track of.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 11-15-2014, 03:51 AM   #22
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 996
I just finished fine tuning my tank fitment. Even though we dont have ethenol, well we do but I dont use it, the tanks have swelled up a bit. So I wanted to have the mount points (except for the one near the filler) enlarged a bit so no fighting the tank to secure.
Even needed to enlarge the holes in the headlight bracket where it mounts so the headight can move forward a touch. I then rely on the tank to headlight bolts to hold it tight.
Works a treat. (sorry no pics)
I also ground out the recess for the fuel line.
Now the tanks can go on / off fairly quick.
Cool.
990 Adv 06, Aprilia Tuono 03 Racing gen 1
rossguzzi is offline   Reply With Quote
Old 11-15-2014, 11:12 PM   #23
Qwik
Adrenaline Addict
Oddometer: 6,739
The tip I was given was to loosen the front stay bracket bolts at the steerer tube and then loctite them. I have enough play to mount everything and then when I snug it all down its solid.
Old 11-16-2014, 04:18 AM   #24
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 996
Yeh I did that, but needed a bit more movement, so enlarged the holes in the stay as well.
Old 11-16-2014, 08:27 PM   #25
Qwik
Adrenaline Addict
Oddometer: 6,739
I noticed my fuel lines from the Y to the carbs were cracking. Might be worth checking those if you have the tanks off. Bike is an 05 950Adv
Times are GMT -7.   It's 03:19 AM.
