Adventure Rider
Welcome, lurker!   Even if you don't post, the system can help you find the good stuff faster if you register.
Register Members Pics Search Today's Posts Mark Forums Read
Old 05-05-2005, 10:58 AM   #1
PASSMORE
Just the last name...
PASSMORE's Avatar
Oddometer: 4,133
Altitude/Elevation readings from a 276c
I am in need of some altitude/elevation readings... Seems this would be a terrific "excuse" to pick up a 276c that I have been coveting
In what incriments does the 276c give these in? Have you found it to be accurate (to what +/-?).
Thanks in advance for your comments.
PASSMORE is offline   Reply With Quote
Old 05-05-2005, 11:42 AM   #2
FatChance
Road Captain
FatChance's Avatar
Oddometer: 6,583
As for accuracy, I would expect the elevation error range to be about the same as the position error range, or accurate to within about 15 feet?
FatChance Slim
Pain in the Butte Ranch
Durango, Colorado
- I don't want a pickle, I just wanna ride on my motorsickle...
FatChance is offline   Reply With Quote
Old 05-05-2005, 12:01 PM   #3
Eurobiker
Vintage Cat Herder
Eurobiker's Avatar
Oddometer: 5,123
Your vertical accuracy is about twice the horizontal accuracy. So if you're good to 10 ft. horizontal, it'll be 20 ft. vertical. The relative accuracy of 2 points will be much better though. So if you want to know the delta height between 2 points, it's generally much better.
I just fired up my eMap and it showed my elevation at 5815 ft. with an accuracy of 16.8 ft. If you're out and find a USGS, FS or BLM benchmark with the elevation stamped on it, set your GPS receiver on the marker for an emperical check.
Mark
When asked about the Sandia Classic, I would always say; "you better come now, because we never know if this will be the last one." Sadly, that would be last year.
Eurobiker is offline   Reply With Quote
Old 05-05-2005, 12:32 PM   #4
Bill the Duck
Unwitting Accomplice
Bill the Duck's Avatar
Oddometer: 10,577
May I heartily recommend GARMIN. See my recent thread in this forum.
BTW, I saw a 276c on JKAM's V-Strom last weekend. Quite readable even in direct sun. Cool features too.
"You will soon find more adventure in life." - A Peking Noodle Co. Fortune Cookie
"The truth shall set you free, but first it will piss you off." - David Icke
"Tho only truly tolerant ones are those who don't care. " - Mike Berlien
"Believe in something! Even if it's wrong! Believe in it!" - Glenn Beck
Bill the Duck is offline   Reply With Quote
Old 05-05-2005, 01:22 PM   #5
txrider
txrider's Avatar
Oddometer: 375
276c is a nice piece of gear, the only other contender is the 2610.
I would say the 20ft mentioned earlier is about right for accuracy, at least what the GPS reports.
2004 KTM 625 SXC
2004 Yamaha FZ-1
1996 KTM 620 RXC
txrider is offline   Reply With Quote
Old 05-05-2005, 02:09 PM   #6
Manuel Garcia O'Kely
KG6WOU - CM87RX
Manuel Garcia O'Kely's Avatar
Oddometer: 3,905
Yea, vertical accuracy is good....HA - I've driven across the Golden Gate Bridge and been told that I was a submarine - at -30 feet.
IF you are getting the WAAS signal and have it activated, accuracy improves but I'd say +/- 50 feet is more the rule - but who cares? That's close enough. Unless you are making a landing IFR and it's Zero-Zero [0' ceiling and 0' horiz. visiblity].
Manuel Garcia O'Kely is offline   Reply With Quote
Old 05-05-2005, 02:57 PM   #7
HardCase
blue-eyed white guy
HardCase's Avatar
Oddometer: 4,351
I've noticed that my elevations readings can sometimes change when I'm sitting still. I gather that means that the satelites are moving around in space? In any case, my comparison of GPS versus Forest Service markers or USGS elevation points is that the GPS is no better than a + or - 50 feet at any given time. That's close enough for my purposes.
Μολών λαβέ
Hard cases make bad law.
HardCase is offline   Reply With Quote
Old 05-05-2005, 05:15 PM   #8
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 2,934
We generally say that horizontal accuracy is 5-10 metres (15-30 ft) with WAAS off.
Vertical accuracy is 10-50 metres (30-150 feet). This is a 10-20 metre error plus up to a potential 30 metre discrepancy due to differences between the model used to calculate height and the true shape of the earth.
www.rockymoto.com.au
Parts and accessories for your adventure bike
BurnieM is offline   Reply With Quote
Old 05-05-2005, 05:42 PM   #9
TiWorld
John
TiWorld's Avatar
Oddometer: 200
When I drive along the coast highway, my 276c says I'm roughly -35 ft., -- snorkel territory. I'll call Garmin and see what they say, but I've found altitude to be pretty far off,... maybe it's just my unit.
___________________
'04 1150GS ("Photon")
'03 Super Sherpa (Monster84's)
TiWorld is offline   Reply With Quote
Old 05-05-2005, 07:33 PM   #10
pbansen
Hosehead
pbansen's Avatar
Oddometer: 399
Elevation seems to be hit or miss...
I'd agree that vertical readings generally seem to have twice the error (at least) compared to horizontal position. On the other hand, every day on the way to work, I pass a 6,000 foot elevation benchmark. For a while, I was keeping my Garmin 76C in the car on a windshield mount and I'd fire it up when I left the house in the morning. As I'd pass the 6,000 foot marker, I'd glance at the GPS to see what it said. More often than not, it would be within a couple of feet, which I find amazing, because at other times it was 70 feet off of a known elevation...
pbansen is offline   Reply With Quote
Old 05-05-2005, 08:24 PM   #11
Gerg
Cupcake
Gerg's Avatar
Oddometer: 6,993
Mine is +/- 50 feet. I usually do the checking by the altitude markers that CalTrans puts oout. And knowing CalTrans, THEY are probably 50' off.
Gerg
Greg
BOOF 160, AMA, RA, MOA, HOG
Live life like you stole it!
Your $5 off SMUGMUG Coupon is
hESgLtqESqM1Q
Gerg is offline   Reply With Quote
Old 05-06-2005, 04:51 AM   #12
rikkitik
More toys than time!
rikkitik's Avatar
Oddometer: 44
Send a message via Yahoo to rikkitik
Greeting,
Elevation accuracy with any GPS unit is dependent on the number of satellites you manage to track at a given moment. I use a Garmin SPIII+ and the error is rather small when I have a full compliment of signals to track. IT is NOT as accurate as a location - remember that thing is trying to compute elevation is 3D mode.
Even the best units I used while playing professional soldier has some elevation errors although locational were good to +/- 1 meter. Heck, 3 feet is pretty close - especially when close does count in horseshoes and hand grenades.
Rikkitik
rikkitik is offline   Reply With Quote
Old 05-06-2005, 05:29 AM   #13
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 2,934
'Don't sit so close together. One grenade will kill you all'
Old 05-06-2005, 01:57 PM   #14
TiWorld
John
TiWorld's Avatar
Oddometer: 200
FWIW, I called the friendly Garmin support line. Was told that the 276c elevation accuracy is +/- 100 feet.
___________________
Old 05-06-2005, 06:03 PM   #15
PASSMORE
PASSMORE's Avatar
Oddometer: 4,133
Dammit! Was hoping I could "get by" with one to get a base floor elev. for our building project. +/- 50 feet ain't gonna cut it for that....
Damn....
vB code is On
Times are GMT -7.   It's 10:42 PM.
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright ADVrider 2007
