06-22-2012, 08:00 AM
#76 |
Mad Scientist
Oddometer: 2,966
Dual plugging is a waste of money and added weight on a 750.
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
06-22-2012, 01:07 PM
#77 |
because I can
Oddometer: 6,073
I can think of some race results that would make that a debatable question.
I was just wondering. I don't guess you are having any detonation issues mk? I am still suspecting you could run higher CR dual plugged? Plus making best power at a more retarded ignition timing is always a plus. More torque times rpm. |
06-22-2012, 03:20 PM
#78 |
Oddometer: 1,116
All the quickest airheads I've seen have dual plugs. Maybe all these good tuners just do it because someone once said it was a good idea, but I doubt it. If you have dyno charts for the same engine with and without dual plugs I'd be very interested to see them. As for the extra weight.. one coil and two spark plugs? Take a piss before the race and you'll save that weight :)
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. Bertrand Russell |
06-22-2012, 03:29 PM
#79 |
because I can
Oddometer: 6,073
You should always take a piss before each race! Crashing with an empty bladder is safer than crashing with a full one just in case it springs a leak.
06-22-2012, 03:47 PM
#80 | |
Oddometer: 1,116
You can usually tell which race is next up by who's lining up for the bathroom
06-22-2012, 05:03 PM
#81 |
combustophile
Oddometer: 1,559
All the quickest airheads I've seen have the best riders.
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton "...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater- |
06-23-2012, 10:38 AM
#82 |
Mad Scientist
Oddometer: 2,966
Agreed!! When you look at the flash across the piston with a small bore motor a single spark plug is fine. I have been building 750 race motors for over 20 years with results in the 60HP+.
06-23-2012, 01:52 PM
#83 |
Oddometer: 718
Does anyone have single/dual plug comparison dyno charts to post up?
Over on the Norton Commando forum there is a guy who has posted up lots of head flow charts...seeing is believing.Some interesting results on port sizes, lie the standard head flows better than the factory ported one ![]() I twin plugged an R100 20 years ago,as was the fashion but I think it was the lighter flywheel and 40 mm carbs that made it go well, |
06-23-2012, 02:40 PM
#84 |
because I can
Oddometer: 6,073
Dyno and flow charts? The problem with both is that the numbers all depend on the dyno and flow bench and how they are run. Huge differences can be had with both depending on a lot of variables definitely including the test equipment itself. The numbers can be manipulated on purpose too! Making fair and objective comparison runs is a skill and harder do do than most imagine. My advise is don't be a sucker.
Small bore? A 750 is still a short stroke, big bore engine. 82mmx70.6. 1.16:1 bore to stroke ratio. Not nearly as short stroke as our R65's and R100's at a whopping 1.33:1 ratio but . . . . 1.33:1 was considered a REAL short stroke for a long while! supershaft screwed with this post 06-23-2012 at 03:04 PM |
06-23-2012, 03:27 PM
#85 | |
Oddometer: 718
![]() Piccy from last weeks meet. Lots of mods are done and tried on ONE dyno by the same guys and they have tried almost everything to make these things faster...cams, carbs, pipes etc. Latest one is the Ignitech programmable ignition that you can adjust while the motor is running, Ignition, flat slide carb and exhaust with no other mods turned out 18 HP. More than the bikes with fancy cams and pistons on the same dyno. The guys who own the dyno do it free. Then the bikes are tried on the track measured with transponders. I'll mention next month that their dyno is for suckers....
Voltaire screwed with this post 06-23-2012 at 03:31 PM Reason: correcting grammer |
06-23-2012, 04:59 PM
#86 |
because I can
Oddometer: 6,073
You need to read my words again. IF you come to understand them, run them by your friends. I am sure they would agree. Now that I think about it, you had better just have them read what I wrote. You are getting a pretty long history now of turning what I write on its head. You are still putting some pretty stupid words in my mouth but at least you aren't using quotation marks while you're doing it!
What is with you guys?
06-25-2012, 02:02 AM
#87 |
Oddometer: 1,116
I'm not disputing your power outputs, I'm asking if you have direct comparison dyno charts for single and dual plugs.
06-25-2012, 02:15 AM
#88 |
Oddometer: 1,116
And how may plugs do these bikes have?
06-25-2012, 04:42 AM
#89 |
combustophile
Oddometer: 1,559
some single, some dual: it varies
06-25-2012, 04:57 AM
#90 |
equitem casus
Oddometer: 2,623
what I need...
I'd like that kind of power... :~)
Think beyond yourself.~ap blog Max the Motorcycle - children's book written by Mrs. FTB SmugMug Photo Gallary |
