Old 06-25-2012, 04:41 PM   #106
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
Is that a 750 or 1000?
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Boxer Metal is online now   Reply With Quote
Old 06-25-2012, 04:42 PM   #107
pommie john
pommie john's Avatar
Oddometer: 1,474
750.
It went to 92 hp when I took it out to 1000
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 06-25-2012, 04:45 PM   #108
Boxer Metal
Mad Scientist
Oddometer: 3,521
Originally Posted by pommie john View Post
750.
My best is 72HP. It gets expensive once you get over 50HP.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-25-2012, 04:50 PM   #109
pommie john
Oddometer: 1,474
From a 750? I agree it get crazy money after a while. Mine started out as 750 but I took it out to 1000 after a season.
The 68hp engine here had a 336, Venolia pistons ( the short ones, I bought from CC as they were called then) I can't remember what valves were in it but Jim Cray built it. As you can see on the graph it had Amal 38mm smoothbores and showed a slight improvement with 38mm Dells.
There wasn't too much else in the engine, modified oil system of course.
Bertrand Russell
Old 06-25-2012, 05:43 PM   #110
Boxer Metal
Mad Scientist
Oddometer: 3,521
For me it was a set of my own pistons, sport cam, larger valves, porting the heads, 36mm round slide carburetors and the biggest improvement was a 2/1 exhaust that I designed.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-26-2012, 12:00 AM   #111
pommie john
Oddometer: 1,474
I never had much luck with 2:1 exhausts. I made one that made decent power at the top end but it had a big hole in the torque in the mid range.
The simplicity of a 2:2 with something like a Supertrapp on the end has a lot going for it. Somewhere I have dyno charts comparing them. I'll dig them out in the next few days.
Bertrand Russell
Old 06-26-2012, 12:24 AM   #112
Boxer Metal
Mad Scientist
Oddometer: 3,521
We lost 5-7Hp with off the shelf 2/1's and we gained almost 10HP with mine. Merged header and a big collection pipe before the muffler.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-26-2012, 01:30 AM   #113
pommie john
Oddometer: 1,474
Was it a bit like the Gordon Blair Norton pipe? Very short headers, maybe 16" long into a single collector at least twice the length of the primary?
Bertrand Russell
Old 06-26-2012, 01:36 AM   #114
Boxer Metal
Mad Scientist
Oddometer: 3,521
I wont give out the specs but here is what it looked like.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-26-2012, 02:01 AM   #115
moorespeed
Oddometer: 65
yes i am the moorespeed, and i have never had less than 74hp at the rear wheel short stroke or standard stroke . the short stroke starts to pull from 6400 and makes max power at 9450, the standard stroke is about 1000rpm less. i have my own pistons 83mm and 88mm.
moorespeed is offline   Reply With Quote
Old 06-26-2012, 02:01 AM   #116
pommie john
Oddometer: 1,474
Interesting. Surprisingly long primaries.
Bertrand Russell
Old 06-26-2012, 04:39 AM   #117
bill42
Old-School BMWs
bill42's Avatar
Oddometer: 364
How much approximately is the actual horspower of a 1981 R100 motor that BMW rated as having 70HP at the engine?
bill42 is offline   Reply With Quote
Old 06-26-2012, 05:19 AM   #118
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
Probably about 55-60... downhill... with a tailwind.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 06-26-2012, 07:47 AM   #119
Boxer Metal
Mad Scientist
Oddometer: 3,521
The driveshaft eats up 20% so that would take it from 70hp at the flywheel to 56hp at the rear wheel.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-26-2012, 11:17 AM   #120
supershaft
because I can
Oddometer: 9,116
How much actual hp at the crank? I know of no one that has measured the power at the crank other than the factory. I suspect there rating is a bit high but they don't stretch the truth near as much as many manufacturers. At least here in the states I think the only airhead rated that high was '77 RS's half way into the '78 model year? I think a US '81 R100 was rated at 67?
I don't think our drive line eats up 20%. Oil alone makes a big diff but . . . . It's close! Different dyno's read different figures. It all depends on the dyno AND operator. The dyno I was around that dynoed a lot of airheads you were super lucky to get 56hp. Most were from 48 to 54hp and that's R100's.
Times are GMT -7.   It's 12:41 AM.
