04-24-2012, 07:25 PM
#1 |
Oddometer: 114
Valve noise.....
Got the 93 r100gs on the road a bit and like it.....New fork bushings , swing arm bearings , steering head bearings and
more . She drives nice but makes a lot of noise on the RH side . Valve clearance is at .004 on the intake and .006 on the exhaust . There seems to be a lot of end play in the exhaust rocker though - about a .005 gap . Anybody shimmed ?
i've monkeyed with the juice and fiddled with the flow . |
04-24-2012, 07:30 PM
#2 |
because I can
Oddometer: 6,088
I don't think a lot of people realize it but you can adjust rocker arm end play on the later shimmed setups just like you do on the earlier setups. There is still a lot of give there. I rarely ever change shims.
All things being equal, the right side is noisier because it is closer to your ear. Keep that in mind. Move your head and your knees around and you should get my point real quick. supershaft screwed with this post 04-24-2012 at 07:49 PM |
04-24-2012, 07:42 PM
#3 |
Oddometer: 114
Thanks . Both of the left rockers have minimal play and really are quieter . Thanks for the tip though . This is my first newer
air head and I didn't realize the rocker blocks were sleeve located till I read up on it . The post also emphasized the importance of centering of the pushrod . The pushrod on the sloppy rocker appears to be on the high side so I am wondering if pulling the blocks closer together will be as good as shimming from the top side of the rocker ???
04-24-2012, 07:54 PM
#4 |
because I can
Oddometer: 6,088
I look more at centering the rocker on the valve tip myself. Unless something is quite a bit off. I loosen the bottom nut to make adjustments. The bottom studs have way more thread purchase and are consequently way less likely to pull threads. I think using an old CC products style modified C clamp Vise Grip is THE best way to adjust rocker arm play down to a gnat's ass. In my experience, a fine frog hair does make a difference there.
supershaft screwed with this post 04-24-2012 at 08:08 PM |
04-24-2012, 08:04 PM
#5 |
Oddometer: 114
Cool , thanks I'll look it over .............
04-25-2012, 10:59 PM
#6 | |
Further...
Oddometer: 5,146
p.s. Ooh, I guess I should sign this super-fishkens
04-26-2012, 06:53 AM
#7 |
Oddometer: 114
Super fishkens , thanks for the input . That was one of the things I was most curious about .
The stacking of shims being an acceptable practice if necessary ...... Oh by the way , my super -single is the Yamaha SRX-6 !!8^)
04-26-2012, 07:05 AM
#8 |
Oddometer: 1,026
off topic
SRX-6 is one of my all time favorite bikes. Yamaha really did it right with that one but in typical fashion it didn't sell well here in the US. The average American rider will not suffer a kickstart single. Don't know what they're missing.
04-26-2012, 09:39 AM
#9 |
because I can
Oddometer: 6,088
Sure! Stacking shims is OK. I am guessing you just about have to sometimes?
Re-stacking shims? They almost always stay right where I adjust them to in my experience. Even for a lot of miles. |
04-26-2012, 11:37 AM
#10 |
BigBrowedNeandereer
Oddometer: 1,004
Well, that's just dead wrong. The rocker should be just off center to insure rotation of the valve to maintain seat and valve concentricity during operation.
Tons of garbage advise can never trump this. |
04-26-2012, 02:47 PM
#11 |
because I can
Oddometer: 6,088
I don't think you have to worry about the valve rotating. They very often look perfectly centered to me and they still rotate. I don't think you can get them to not rotate without modifying the keepers but I have seen quite few rocker arm tips get off to the side enough that it wears the rocker arm radius excessively on the part that touches the valve tip and none at all on the rest of the radius. It makes for a messed up rocker arm that needs replacing.
04-26-2012, 03:54 PM
#12 |
Oddometer: 1,116
To be honest, I don't see how you can make a valve rotate just by offsetting the rocker arm by a couple of mm. The valve is clamped tightly to the collets which are tight on the keeper, which is held by a fair bit of spring pressure to the spring and then on to the head.
can it really make a difference if the rocker arm is offset by a tiny amount. I'm very sceptical of that. There are plenty of engines from American V8s to Italian supercars that use roller rockers and they can't possibly spin the valves and they don't seem to suffer valve wear more than any other engine. It sounds like car club hocus pocus to me.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. Bertrand Russell |
04-26-2012, 04:19 PM
#13 | |
Oddometer: 360
Actually the collets butt together before they get a grip on the valve and allow the valve rotate. To center the rocker over the valve with enough precision to keep the valve from rotating would be next to impossible. SS is correct and DrT is dead wrong. |
04-26-2012, 04:25 PM
#14 |
Oddometer: 1,116
Hmm. OK. I must confess that I've not looked that closely at the BMW collets, but certainly on my Norton, the collets grip the valve, there's definitely a gap between them so they must be hard up against the valve stem.
04-26-2012, 05:40 PM
#15 |
because I can
Oddometer: 6,088
Thanks robtg! From what I have seen I think it would be next to impossible too.
As I understand it pj, very few motorcycle engines have rotating valves excepting BMW's although it is pretty common at least in American cars. So far that adds up with what I have noticed. |
