Old 06-26-2013, 06:27 AM   #421
dvwalker
Working to ride
dvwalker's Avatar
Oddometer: 800
Originally Posted by Saltydog86 View Post
Who sells the tank with pump included?
hey saltydog, ktm powerparts has part #'s that include the FI pump
dvwalker is offline   Reply With Quote
Old 06-26-2013, 08:37 PM   #422
wizz
Oddometer: 2,659
Would like to put on fatter grips, any suggestions?
"These things are like intellectual viruses loose in the theater of discourse, and you canít really argue with these people, because they donít understand the rules of argument," Terence Mckenna
"An honest tune with a lingering lead has taken me this far"WSP
2006DucatiMultistrada620, 2013 KTM 350 exc-f
wizz is offline   Reply With Quote
Old 06-26-2013, 09:56 PM   #423
David_Moen
David_Moen's Avatar
Oddometer: 1,312
I put on Pro Grip 737 Rally grips. They are a bit bigger than stock, nice and soft/grippy, and are said to wear well too.
2013 KTM 350EXC-F, 2005 BMW R200GS, 1984 Kawasaki GPz 750
David_Moen is offline   Reply With Quote
Old 06-27-2013, 10:10 AM   #424
AKoffroader
AKoffroader's Avatar
Oddometer: 495
Lowering
Is there anyway to lower this bike? I sat on one and with a 30" inseam it was way too tall to get a foot on the ground.
With out a shock linkage, I didn't see a way to lower it.
Greg
1978 Yamaha TT500, 2008 Yamaha WR250R, 2008 Suzuki DR650
AKoffroader is offline   Reply With Quote
Old 06-27-2013, 10:33 AM   #425
shortbritches
Oddometer: 111
A person can have the shock shimmed.It will lower it about an inch but you also lose some travel.Also you can get a lowered seat.With that said I did neither and have a 30' inseam.
"I will not follow where the path may lead, but I will go where there is no path, and I will leave a trail". Muriel Strode,1903
2012 KTM 350 EXCF - 2008 WR250R
Kelley Joe
shortbritches is offline   Reply With Quote
Old 06-27-2013, 10:42 AM   #426
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,271
Greg
I lowered my 500 EXC. I took the rear shock to a suspension specialist (Factory Connection) and had them shorten it one inch. I then raised the forks correspondingly to balance the front to the rear and then reset the sag. I can now "almost" flat foot at stops. Lower CG also helps handling and turning.
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 06-27-2013, 07:05 PM   #427
Scubatoe
Trained monkey
Scubatoe's Avatar
Oddometer: 213
Greg
I've got a 30" inseam. I picked up the low seat from Seat Concepts cover and foam for $160 and had it installed by an upholstery shop for $15. Works great for me height-wise, still leaves something to be desired as far as comfort goes, but definitely much better than stock.
Scubatoe is online now   Reply With Quote
Old 06-27-2013, 08:45 PM   #428
Johnrunner89
Oddometer: 50
Hey guys, new to the forum (long time reader though and finally caved in after a couple buddies told me to join) and kind of new to riding (only been riding a couple years). I too ride a KTM 350exc (13') and love the bike! Have shy over 1100 miles on mine and love it more after every mile. Currently have a 14/52 gearing setup and love it but would like 3rd/4th gear to have a little more giddy up down south. I was thinking about adding an FMF exhaust and pipe to my bike but know it's pricy. For those who have done the upgrade, what would you say about the performance upgrade? Any info would be appreciated. Thanks.
Johnrunner89 is offline   Reply With Quote
Old 06-27-2013, 09:35 PM   #429
desertkev
Charity Founder
desertkev's Avatar
Oddometer: 32
Got mine with 2.8 hours on it, nice 80 gentleman bought it and on his first ride with what he calls his "geezer riding club" went down on sandy washboard. A small 5mm stress mark in left tank plastic, he got the worst of it, fully armored and broke 3 ribs.
I adore it! It is my first dirt bike and I am learning as I go. Although I know the role that the motorbike was designed to do, I find myself more and more taking it out for those little annoying errands and making them into little hooligan adventures around Tucson. If you see a 350 on a sidewalk, an alley or cutting across a wash you are seeing one happy guy!
Know someone with Rheumatoid Disease who needs an understanding Support Group? Visit:
www.arthritisintrospective.org
We are a 100% volunteer org which is responsible for helping thousands of people find others for face to face support.
desertkev screwed with this post 06-28-2013 at 12:34 AM
desertkev is offline   Reply With Quote
Old 06-28-2013, 08:27 PM   #430
GratefulKicks
GratefulKicks's Avatar
Oddometer: 174
Here's my 350 xcf-w. I absolutely love it. 1200 miles to date. Running stock 13/52 gearing. Added FMF 4.1 Aluminum muffler but kept stock header pipe. Also switched to the newest EU map. Also put in the FMF Snap. End reuslt: Much, much more bottom end response...but this engine still runs best in the high rev range...that's it's sweet spot and seems to be at home there (ie, it's fastest). All the mods just made the bike more enjoyable when I want to be lazy with the clutch and gear shift lever or I'm caught by surprise and need to get on the gas at the last second without time to downshift...an agressive blip of the throttle and the front wheel comes right up to get me out of trouble :) . Runs a little bit richer so I've lost a little fuel economy, but not much. Did about 50 miles of double track and single track last weekend and still had 1.1 gallons of gas left in the tank. That means I went 50 miles on 1.15 gallons...or roughly a 100 miles per tank with pretty aggressive riding...that's really good if you ask me. In retrospect I would have made my modifications one at a time because I don't really know which of them had a profound effect on performance and which didn't do anything. At this point it's a moot point because the combination has the bike running just the way I want :)
Here's a pic I took late this afternoon on a little ride here in Vermont on a small grass track.
Motoz 120 rear tire is bomber and I've loved it. Highway Dirt Bikes integrated hand guards/top clamp/bar rider setup is by far the BEST I've ever used.
2014 KTM 350 XCF-W and 2013 KTM 350 350 XCF-W
2009 BMW G450X (SOLD)
2006 Kawasaki KLX 300R (SOLD)
GratefulKicks is offline   Reply With Quote
Old 06-29-2013, 05:13 AM   #431
Big Augie
Transient
Oddometer: 1,070
Valves checked at 40 hours, still no adjustments needed.
Working on getting the balance feel of the bike adjusted, front feels wishy washy on lose terrain compared to my 450. Softening the compression and not rebound on the front helps some, these bikes carry a lot less weight on the front wheel compared to the older models.
My doctor said I wouldn't have so many nosebleeds if I kept my finger outta there.
Ralph Wiggum
Big Augie is offline   Reply With Quote
Old 06-29-2013, 05:14 AM   #432
Magile
"What exit?"
Magile's Avatar
Oddometer: 492
I've been using Oury Street Grips on my 400EXC...they're bigger diameter than their MX grips. Plush rubber kills vibes; tacky surface allows a light grip. Cheers, M.
http://www.ourygrips.com/road-street-grips/
Magile is offline   Reply With Quote
Old 06-29-2013, 05:18 AM   #433
gplassm
gplassm's Avatar
Oddometer: 589
I see that you are in VT. I am in MA. Where are you getting your Moto-Z tires from?
Also, I am just curious, but is everybody running their TPS at 0.60 volts, or have people found it helpful to tweak them up?
Street bikes for the street. Dirt bikes for the dirt. Let's keep it that way.
gplassm is offline   Reply With Quote
Old 06-29-2013, 10:53 PM   #434
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,830
Originally Posted by dvwalker View Post
congrats on your new purchase NSFW, you're going to have a blast getting it setup then riding...this bike will put a smile on your face that's worth the bikes weight in gold
I learned the hard way on the factory chain as well, with 48t rear had to go up 2 chain links to 116. The tension blocks are nice and centered with this setup. But like I said in a previous post, 48t rear is compromise gearing.
If you need more lower "billy goat" gearing control (50t vs 52t) and do not want to swap chains, think about swapping out your countershaft sprocket.
thanks dvw.
i had the 14/52 and they're nice, but i need some highway gearing.
14/50 and rekluse is a great combo for me. 800 miles on the odo...
http://www.advrider.com/forums/showt...811515&page=34
other mods include lowering the bike by 5/8", lowered seat by seat concepts, aftermarket can, cush hub and a steering damper. the popping sound during deceleration is gone......
been very happy and can't wait to ride more.
NSFW is offline   Reply With Quote
Old 07-01-2013, 06:46 AM   #435
wizz
Oddometer: 2,659
[QUOTE=
other mods include lowering the bike by 5/8", lowered seat by seat concepts, aftermarket can, cush hub and a steering damper. the popping sound during deceleration is gone......:[/QUOTE]
Details on the cush hub?
Times are GMT -7.   It's 10:38 AM.
