Old 04-26-2012, 08:35 PM   #1
upsman OP
Oddometer: 262
Cleaning up my airhead
I was curious what are the common cleaners, polishes, and waxes that are used to clean the bikes up.
Thanks Greg
upsman is offline   Reply With Quote
Old 04-26-2012, 08:39 PM   #2
go gonzo
The Mustard of Pants
go gonzo's Avatar
Oddometer: 192
I've been using straight white vinegar in a spray bottle lately.
go gonzo is offline   Reply With Quote
Old 04-26-2012, 09:40 PM   #3
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,980
I use dish soap and water once a year on my R69S.
Before.
After.
caponerd is offline   Reply With Quote
Old 04-27-2012, 04:42 AM   #4
upsman OP
Oddometer: 262
cleaning
wow nice bike and so far very simple solutions. Im just trying to clean the bike up a little. Thanks
Old 04-27-2012, 07:35 AM   #5
WU7X
The Old Fart
WU7X's Avatar
Oddometer: 1,982
When rebuilding my Bings, I was told to soak the parts in a Pine-sol and water solution. I tried it at a ratio of ~4:1 Pinesol. Worked wonders. Now I use Pinesol on all the greasy/dirty external parts of the R100.
"Seika" - 2013 DL650 + DMC M72D Sidecar
"Gracie" - 1983 R100RT 60th Anniversary Edition
"Dusty" 2011 Adventurized 4Runner
Adventure is worthwhile." ~ Aristotle
Airhead #14449
WU7X is offline   Reply With Quote
Old 04-27-2012, 07:44 AM   #6
upsman OP
Oddometer: 262
i have read that about the carb cleaning, i will try it with the rest . thanks
Old 04-27-2012, 09:13 AM   #7
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,416
No pressure washer!
boxerboy81 is offline   Reply With Quote
Old 04-27-2012, 09:24 AM   #8
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,185
I never used a pressure washer on my R90/6 but did use a regular garden hose. Recently when I rebuilt the front and rear wheels there was ample evidence of water having gotten inside. I think the garden hose might be too much too. Don't know how to be more careful. Maybe I should change the wheel seals more often than once every ten years. Do you think?
---Albert Einstein
Old 04-27-2012, 10:34 AM   #9
supershaft
Oddometer: 9,110
I have never tried Pine-sol.
Pressure washer? I have used them all my life on motorcycles as have tones of others I know. As long as you mind what you are doing, they work great with no problems.
I think soaking bare metal with WD40 and then washing with Simple Green works real well as long as you don't let the Simple Green dry on anything ever.
Old 04-27-2012, 11:14 AM   #10
upsman OP
Oddometer: 262
i washed my dirt bikes for years with the pressure washer and never had a problem, i will try the wd40 and simple green trick as well thanks
Old 04-27-2012, 11:37 AM   #11
limeymike
Who Me?
Oddometer: 604
I don't think you can say never use a pressure washer on a bike, just know what you are doing before you start.
limeymike is offline   Reply With Quote
Old 04-27-2012, 11:53 AM   #12
supershaft
Oddometer: 9,110
I said real well. I meant better than anything else I have tried. Depending on how bad the metal is stained nothing works real well as far as I know excepting a bead blaster. I put one of those big, shallow drip trays underneath them and let the WD40 soak for a day or two with a extra squirt in between. I think it helps but I wouldn't bet on it. Good luck!
Old 04-27-2012, 12:02 PM   #13
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 626
Shout laundry spot remover works wonders on grease as it is a surfactant. Spray on, brush off. Don't let it dry, and try to avoid allowing it to soak on rubber, plastic, or paint.
Current: 93 R100GS, 03 XR650R
Prior: 73 CB350, 77 R100/7, 83 R100RT, 04 XR650L
I love every motorcycle I've owned and even some that I haven't.
ignatz72 is offline   Reply With Quote
Old 04-27-2012, 01:11 PM   #14
bmwloco
bmwloco's Avatar
Oddometer: 1,385
Simple Green, and a little Hydrogen Peroxide in a bottle for (10:1 H20/Hydrogen Peroxide) will clean most any bug juice off. Simple Green on a clean shop towel for the rest.
Then again, I am not much of a shiner or polisher. It makes it easier to find oil leaks if they are dirty.
YMMV.
'66 BMW R60/2, '83 BMW R100RS,'81 BMW R100RS "Das Beast", '87 BMW R850R '77 Honda XL125
Airhead #371
bmwloco is offline   Reply With Quote
Old 04-28-2012, 12:20 AM   #15
fishkens
Further...
Oddometer: 5,147
Did someone say bug juice? You shoulda seen my boots.
fishkens is offline   Reply With Quote
Times are GMT -7.   It's 03:26 PM.
