Old 04-28-2012, 05:28 PM   #1
excTC OP
Carbon Ktm lifeform
excTC's Avatar
Oddometer: 164
Question Lighting up a KTM 690
I am at the point of trying to get a better light on the front of my 690R. I am not intending to do night riding but to be able to ride when still out and needing to get somewhere. Of interest is how much light, will the lighting circuit cope, ease of fitting, protection from rocks , reliability and cost. Options I have thought of:
I have tried the option of new higher watt bulbs and that works a bit but the bulbs seem to fail often and the light is still minimal.
The E 690 light appears top be an option but my take on this is that is only a larger reflector and the bulb is similar.
990 lights as part of the rally raid fairing.3 $1100
Led driving lights mounted under the bars. Cost about $300. Against for me is more complexity wiring, gear, clutter but attractive is backup of multiple lights and probably better coverage of the track.
High out put replacement bulb. Halogen bulbs are available from $50 but don't have low beam and may not be legal. A Xenon kit has dual bulb as an option but is around $500 and has a bit of clutter to it.
Cyclops 7" driving light or similar. Cyclops is $350 plus bulb plus adapter. A similar unit from Ktm twins, trail tech is 8" and about $300. I worry a little about these being hit with a rock and taken out.
Some other dual light unit. Trailtec X2 $100 to $300 but I couldn't find a unit listed for the 690.
Any contributions, experiences or ideas would be appreciated.
KTM 530 EXC Royal Enfield Bullet 500 KTM 690R. Spot link The Land of Pickled Fish and Beyond
Team690 on the APC
excTC is offline   Reply With Quote
Old 04-28-2012, 07:32 PM   #2
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,029
good light nice price
[QUOTE=excTC;18566614
Any contributions, experiences or ideas would be appreciated.[/QUOTE]
I have the trail tech light X2($100 or so) it is a bit better then the stock light but I have an 08E vs the R's that suck. I have a friend who has 09R and the same light plug and play for both of us.
The road less traveled is the road I travel more.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." Dean Martin
StepOnIt is offline   Reply With Quote
Old 04-29-2012, 02:21 PM   #3
excTC OP
Carbon Ktm lifeform
excTC's Avatar
Oddometer: 164
Thanks steponit. Trailtech light might be a good option and I think they have a more expensive and probably more powerful version.
Team690 on the APC
Old 04-29-2012, 03:23 PM   #4
LukasM
Oddometer: 5,425
If you mean the X2 HID, I wouldn't recommend it. It's known to be unreliable, and while TT customer service is great, repeated failures can get annoying, if not dangerous if it's your light failing you during a night ride....
The TT 7" unit is nice in terms of light output, but not good for the street. For dual sporting I'd get the Cyclops which is a TT frame with a Hella high/low reflector in it.
Old 04-29-2012, 04:00 PM   #5
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,499
The 690E headlight is actually not too bad. If it's only for occasional use I'd go with that.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 04-30-2012, 02:56 AM   #6
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,120
Renazco has a hid kit for the stock headlight
Mudguts is offline   Reply With Quote
Old 04-30-2012, 04:16 AM   #7
excTC OP
Carbon Ktm lifeform
excTC's Avatar
Oddometer: 164
Light Bar
The cylops light looks good and sounds like it does a good job but I worry that it is vulnerable to rocks.
This light bar is something new and also about $350. Any one tried it??
Team690 on the APC
Old 04-30-2012, 05:51 AM   #8
jared1843
Drifter
jared1843's Avatar
Oddometer: 144
I love my cyclops and have had no issues with rocks. Looks awesome too.
I am here: http://tapatalk.com/map.php?us5ejq
2002 Suzuki DRZ400E - SOLD
2002 Honda RC51 - track only
2005 Suzuki DL1000 - SOLD
2010 KTM 990 Adventure R - SOLD :(
2011 KTM 690 Enduro R!
jared1843 is offline   Reply With Quote
Old 04-30-2012, 06:46 AM   #9
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
The Cyclops works fine. The H4 adapter plug is only like five bucks. I put a clear plastic guard over mine that is purpose built for headlight applications. No stone chips. And if you can find someone else that needs one it will cut your cost in half. http://www.xpel.com/products/universalhl.asp And don't use the provided instructions, they recommend using a water alcohol solution on the light then apply the guard then squeegee out the water. Didn't work for me. I just cleaned the bulb thoroughly then applied the guard. Be careful it is extremely sticky. You'll have one chance.
Here's the light with the plastic guard installed.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 04-30-2012, 07:23 AM   #10
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,029
Thats what you use the water so if you do not get it right you can a bit of play. The alcohol is to clean it, then spray some water on it and squeegee all the bubbles out. Recommend starting in the middle and going left to right or up and down then do the other half.
Old 04-30-2012, 07:30 AM   #11
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,029
light
I did not use the HID X2 light but this one
Torch Dual-Sport Model-Specific X2 Kit: Orange - KTM - 70W
Trail Tech Torch Dual-Sport X2 with model-specific KTM connectors.
For use with stock or Trail Tech High Output Electrical System.
KTM EXC/MXC/XC-W/XCF-W/EXC-R 2000-2012 CARBURETED ENGINES ONLY
Color: ORANGE
Lamps: Halogen Dual-Sport
Model-specific KTM X2 Halogen lights fit all KTM off-road models with factory lighting capabilities. This light will run on either AC or DC power.
Model-specific power wire harness 3600-SWHA included.
Graphic sticker decal sold separate.
Not compatible with rock guard.
It is not for road use but.... no problems so far
Old 04-30-2012, 08:22 AM   #12
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Good luck, it's a convex lens..... YMMV.
Old 04-30-2012, 08:29 AM   #13
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,554
Squadron LED w/ dimmer!
Yellow Pig is online now   Reply With Quote
Old 04-30-2012, 02:21 PM   #14
excTC OP
Carbon Ktm lifeform
excTC's Avatar
Oddometer: 164
E light
Clintnz I would have to go out and buy an E light and I have had regular problems with bulbs blowing. I think that I would rather put the money towards something that has the bling factor aswell. Cyclops is looking good.
Team690 on the APC
Old 04-30-2012, 02:26 PM   #15
excTC OP
Carbon Ktm lifeform
excTC's Avatar
Oddometer: 164
Question Hid
Mudguts I had a look at the HID and it has what looks like a box (ballast?) which would have to be squeezed in behind the current set. I find at times that the front guard causes a shadow with the current set up too. Anyone running one?
Team690 on the APC
Times are GMT -7.   It's 10:17 AM.
