04-28-2012, 06:49 PM
#1 |
bench adventurer
Oddometer: 3,618
Gas vs electric dryers
The deal: I am having a friend build out my family room in my house to be a studio apartment. It has a separate entrance, a large bathroom, a wet bar (to which he will add a small cooktop) and under cabinet refrigerator. One wall needs to be built, and a small wall by the garage will be moved a few feet to accommodate the shower and washer dryer.
Now, the cost of a GE stackable is about the same for either an electric dryer vs a gas dryer. In the garage, i have a gas dryer, and it will cost about 500 bucks to run gas from where my dryer is to where the stackable unit will be. Since we will be running electricity to the cooktop and fridge anyway, it will be much cheaper to make the dryer an electrical one. Any input regarding maybe saving 400+ bucks to run it as electric vs gas? It is going to be a small unit for one person. Oh, utilities will be included in the rent (as will cable, wifi, garbage). Thanks
91 Hawk GT |
04-28-2012, 07:07 PM
#2 |
Woolf Barnato
Oddometer: 29,337
Electricity is made by burning gas to generate heat to generate steam to turn a generator and then you're going to turn that electricity back to heat. Why not burn the gas yourself? In other words, I believe gas is much cheaper.
'Gonna get me a six pack...push people off the highway!' "they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood." "I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!" "Yeah, that guy sure is terrible at touching moms" |
04-28-2012, 07:43 PM
#3 |
Oddometer: 7,202
It's a rental unit. Electric is safer than gas. The end.
There's a company out there that makes oil-filled heat exchangers for some dryers. The rationale is that it removes the direct high heat source (element or burner) from the intake airflow of the drum, greatly reducing the chance of setting the clothing on fire. It takes a bit for the oil to heat up, but once it does, it apparently produces a very even heat going into the drum. |
04-28-2012, 08:12 PM
#4 |
Oddometer: 2,385
Gas is cheaper right now. I ran all the major appliances in the house with gas, but also threw in some extra wire for electrical hookups just on the off chance I want the extra flexibility down the road.
04-28-2012, 08:25 PM
#5 |
Oddometer: 8,177
04-28-2012, 09:15 PM
#6 | |
Back at last
Oddometer: 9,996
You are in PG+E land are you not? That means you are paying oh, $0.15/KWH. An electric dryer costs about 2X as much, but in a single persons unit? I bet that if you google you can find a calculator that would take your KWh cost vs. Therms and give you a number you could use to estimate your payback. I have no experience with modern gas dryers - I've never lived where we had a gas hookup, and I'm a PG+E victim part time. Here in CO, I pay about 8 cents a KW/h, but propane costs a fortune at $4/gallon delivered. I just turned off my propane heater, it's costing me a couple hundred bucks a year in propane. As to safety: I'm sure that code requires that as a gas appliance it has to be anchored to the wall. Oh, when you ran the number, did you consider that the electric combo [at least my stack] is a single 240 line whereas with the Gas, you still need a 120 circuit. I don't know if that matters in your calcs. With the price of gas going down, I personally would make the bet that it would pay off.
"More than any time in history, mankind now faces a crossroads. One path leads to despair and utter hopelessness, the other to total extinction. Let us pray that we have the wisdom to choose correctly." Woody Allen "*enhance* not enjoy, gramps mcbuzzkill" - Lemon G.
04-28-2012, 09:52 PM
#7 |
Oddometer: 7,202
04-28-2012, 09:58 PM
#8 | |
bench adventurer
Oddometer: 3,618
Keep those ideas coming.
Oh, the dog? He is a 128 lb labradoodle. Most think he is a Newfie, until he stand next to one, very similar. Labs are a descendant from newfies, so he's got the the genes. Oh yeah, the dryer. I am in San Diego, we pay a lot for everything . Thanks for the tip, will look for a calculator on the sdg and e website. I would think electric would be safer, heck, the renter might not notice a gas leak. There is no code where i live that states the dryer has to be anchored, just the hot water heater. If it is a little more expense, i can just up the rent a bit (its not built yet, so no renter, and have not decided on a rental price). Rentals are high and in demand here. On one hand, i don't mind a little extra cost per month, having someone here is going to help tremendously with my mortage anyway. Not upside down on house, but market is weird. Couldn't sell it, and i ain't giving it away ( the house, anyway) ![]() Quote:
91 Hawk GT |
04-28-2012, 10:00 PM
#9 |
bench adventurer
Oddometer: 3,618
Ok, you might have just sold me on the electric dryer. Thank you. On the same note, the burners are going to be electric, not gas. No open flames. There is a fireplace in the room as well, i am taking it out.
91 Hawk GT |
04-29-2012, 12:21 AM
#10 | |
Oddometer: 7,202
The T/A who taught my computer ethics course in college was burned out by a neighbor who left candles unattended. |
04-29-2012, 01:41 AM
#11 |
Oddometer: 7,748
I'd also take a look at putting the apartment on a separate meter if at all possible. It avoids one source of potential conflict They want to leave the lights on all the time? No problem, they pay for it.
Solve the World's problems with your spare CPU cycles. http://www.worldcommunitygrid.org |
04-29-2012, 06:30 AM
#12 | |
Huh?
Oddometer: 2,421
Mrs. Dave and I had the same debate about a year ago. We looked up the info, and were educated. We went with gas and haven't looked back. The operating costs are a LOT lower - maybe $2-$3 worth of gas per month for two people. I can understand the hesitancy of gas in a rental unit, but since you've included utilities in the rent, your tenants have absolutely no incentive to use less energy. So, you *will* be paying every time some jackass decides to use a whole dryer cycle to dry a pair of underwear. You'll want to go with the cheapest form of power available. I didn't want the cost of running a gas line, so I ran the black pipe myself from the nearest stub on the gas line. It was actually easier than sweating copper water pipe. Just measure your runs carefully, and have the pipe lengths cut at Home Depot. Make sure you use the gas rated pipe dope (again, HD), and code usually requires a gas shutoff valve within 1 foot of the dryer. I had all my work inspected by the county, and passed with flying colors. I don't remember if it's required, but I think it's always a good idea to use metal dryer vent pipe instead of that slinky hose garbage. Even if a flare up does occur, it's contained in metal. If you're that concerned with flames (gas) in the unit, I understand, and you should go electric. But, I would lower the rent a bit, and make the tenants responsible for their own utilities, IMO. |
04-29-2012, 06:42 AM
#13 |
Back at last
Oddometer: 9,996
I'm going from memory, but threaded gas pipe joints may not be concealed, IIRC.
04-29-2012, 06:58 AM
#14 |
diplomatico di moto
Not "gas dryers".
"Gas". I've been in real estate and property management for a few years. Tenants are generally clueless and going all electric is a good way to reduce potential problems.
Rocker59 (aka guzzimike), Aux Arcs (NW Arkansas) Moto Guzzi: LeMans 1000 CI, Sport 1100, V11 LeMans Nero Corsa IBA #24873, MGNOC #21347 Just keep playing, no matter how weird it gets.
04-29-2012, 08:38 AM
#15 | |
bench adventurer
Oddometer: 3,618
ok, that did it. No gas, no candles, I already told everyone interested in the place, NO SMOKING. Not that there is anything wrong if someone wants to smoke, but not in my house.
91 Hawk GT |
| Thread Tools | |
