Old 01-25-2015, 09:04 PM   #1
beewill OP
beewill's Avatar
Oddometer: 125
990 Tanks on 950?
I've seen a few things on 950 tanks on 990's with some cutting for the fuel pump, but what about 990 tanks on a 950? The only solution I currently know of, at least I think, is grabbing a block off plate from a set of Safari tanks.
First question, is there a soruce for these plates and/or does anyone have one laying around they didn't use can would like to part with.
Second, any other known ways to get the 990's to work on 950's?
2004 KTM 950 Adventure
A bore is someone who deprives you of solitude without providing you with company.”
― Oscar Wilde
beewill is online now   Reply With Quote
Old 01-25-2015, 10:34 PM   #2
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,714
Block off plate is a must for obvious reasons
No too hard to make if you have a fuel pump to make the template but make sure you use viton for the gasket.
Pete
Tuetleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 01-25-2015, 10:51 PM   #3
DirtyADV
DirtyADV's Avatar
Oddometer: 2,199
Gasket that comes with safari plate does not seem to be up for the task in the long term, after a couple of years I dont think I was far from a leak:
sorry for bad picture
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 01-27-2015, 06:34 PM   #4
beewill OP
beewill's Avatar
Oddometer: 125
Good call on the Viton gasket, a must when dealing with gasoline.
Anyone have an old fuel pump lying around I could use for template or have dimensions.
Or better yet, any 990 Safari owners still have the extra plate ?(did they come with plug or do you order extra?) If the latter anyone know of a source?
― Oscar Wilde
Old 01-27-2015, 09:49 PM   #5
DirtyADV
DirtyADV's Avatar
Oddometer: 2,199
Think plate was a separate item but not sure.
Was able to source one through this great site for cheap, its not in use right now, a bit reluctant to give it up since I have 990 tanks laying around and several 950s and should one tank there fail plate will be needed.
And Im not sure were it ended up? Will try to remember to take a look for it next time I visit my storage, could at least measure and give detailed pictures.
Think CJ did a plate that went inside hole and used an O-ring also similar to what is in place if installing the pump, not sure if that made it into production or if it was a one off ...or if it was someone else, bad memory.
/Johan
Old 01-28-2015, 01:10 AM   #6
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,883
I remember something similar.
/Johan
You could ask CJdesigns for details/prices.
Cheers
Old 01-28-2015, 10:19 PM   #7
Qwik
Adrenaline Addict
Oddometer: 6,562
Might also try contacting them at http://safaritanksusa.com/index.php?cPath=29_35
And see if they will sell you the block off separately
Speed bumps never seem to make me go any faster
Qwik is offline   Reply With Quote
Old 01-28-2015, 10:52 PM   #8
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,714
I once had a set of the safari tanks and bought the block off plate separately.
About AU$30 IIRC
Pete
Times are GMT -7.   It's 12:27 PM.
