Old 05-08-2012, 07:06 PM   #16
ten_fiver
ten_fiver's Avatar
Oddometer: 2,035
Originally Posted by Tucos View Post
Does the fender just smash up against the brake line T at the lower triple?
? Brake line T is on top of the lower triple, fender is underneath the triple.
ten_fiver is offline   Reply With Quote
Old 05-08-2012, 07:17 PM   #17
Tucos
Tucos's Avatar
Oddometer: 309
Right, but it angles down and the fender is higher than the bottom of the triple. Fender is loose in the pic, tight looks like the bracket is going to snap. Also the brake lines are tight against the sides of the fender.
Tucos screwed with this post 05-08-2012 at 07:29 PM
Tucos is offline   Reply With Quote
Old 05-08-2012, 08:23 PM   #18
ten_fiver
ten_fiver's Avatar
Oddometer: 2,035
Gotcha. I remember running into that as well. There are a couple options to help: One that I did was to invert the two front metal fender bushings so the front of the fender sits a little lower. Another option is to cut the plastic thing that holds the brake line T in half. Then you can rotate the two pieces outward to give more clearance. I didn't do the second one, I figured I'd see how everything was working before I did that- so far no problems.
Old 05-08-2012, 08:38 PM   #19
Tucos
Tucos's Avatar
Oddometer: 309
I will give that a shot, thank you. The suspension has been raised to 245mm and the brake lines are stock so that may become an issue as well.
Old 05-08-2012, 08:40 PM   #20
plumbtired
plunging into the farkle
plumbtired's Avatar
Oddometer: 184
No Prob!
Add some 1/2" plastic spacers, sets it down far enough and no need to split the bracket!
Will rub a little but not enough to worry about.
RidnChina
If they all worked right I'd be retired
08 990
98 DR
plumbtired is offline   Reply With Quote
Old 05-09-2012, 03:21 PM   #21
up2nogood
Oddometer: 66
Originally Posted by 2upAussie990 View Post
This is on my to do list, but I just have to work out if I donate an arm or a leg and whether I give left or right side as it's farkin near $550 over here to buy it from KTM. i'll end up just sourcing what I need from Ebay or something.
Screw that dealer. I just got a set from Pro Griffin at Maroochydore for $100. But I did also just buy a 990 from them, so maybe the two are linked....
Call 'em and see.
up2nogood is offline   Reply With Quote
Old 05-10-2012, 01:28 AM   #22
Escapegoat
Sidetracked again
Escapegoat's Avatar
Oddometer: 159
Cool2
Go to a different KTM Dealer and don't ask for a kit. (Talk to the boys at dalby moto) My front guard is off the 65, and the fork protectors are off something else. From what I have seen on the many mods, the lower fork leg protector screwholes don't line up correctly but it's easily worked out. I got the wire blake line keepers and the project may have cost about $150-$180.
I think I googled something like 'ktm part numbers high lift guard' and had a list to start with.
Failing that you can get KTM stuff sent to freight forwarders in the states. It won't save you much ATM coz the USD is up the shit.
Or PM me and I'll round up the part numbers next time I am in the shed.
Wheredafukami
Escapegoat is offline   Reply With Quote
Old 05-10-2012, 06:39 PM   #23
Meico640
Oddometer: 264
No it's just KTM's ass ripping prices here in Australia, just so you know a new 2012 990 is about $21k here on a good deal.
Nope, Just paid $21,800 for a 2012 990ADV in White( same as above Woo Hoo)
But did see Mr Dalby Moto do the same as Mr Alberta for the 990 High Card kit using the original Fender...
Meico640 is offline   Reply With Quote
Old 04-14-2013, 01:17 PM   #24
Pharaon
Oddometer: 6
Here is a picture with 690 SMC fender and 85SX fork covers
Pharaon is offline   Reply With Quote
Old 04-14-2013, 02:18 PM   #25
Tremblant1
Tremblant1
Oddometer: 13
Originally Posted by Pharaon View Post
Pharaon?
I just picked up a 2012 white adventure.
What fender and fork guard did you use?
Tremblant1 is offline   Reply With Quote
Old 04-15-2013, 02:57 AM   #26
2upAussie990
Oddometer: 464
Still haven't done mine yet, between moving house, xmas, floods, work, building sheds and patios, work, sleep, work eat, sleep my poor beloved 990 has done about 200km's in the past 6 months and that's been riding her to work and home
2upAussie990 is offline   Reply With Quote
Old 06-05-2013, 08:48 AM   #27
motocentaur
motocentaur's Avatar
Oddometer: 46
High fender mod ... done
People have made brackets for the fork guards to mount them but all I needed to do was use a heat gun and bend the plastic around a bit to get the outer two bolts to line up then drill a hole to bolt in the center bolt
Here's a part list from ktm-parts.com
60013025100 brake hose guide x2
60013025050 rubber for guide x2
54808020000 spacer bushing x4
4700109400030 Fork protector set 85sx
That was about $40 and the fender was another $40 and its from a 690 enduro R smc
"Love is the feeling you get when you like something as much as your motorcycle" - Hunter S. Thompson
http://www.motocentaur.com/
Http://inkfx.biz
motocentaur is offline   Reply With Quote
Old 10-17-2013, 01:55 PM   #28
alshaffer
alshaffer's Avatar
Oddometer: 48
High Fender in Orange
Originally Posted by RozzyCat View Post
I bought all the high fender parts (as described on the HOW link) in ORANGE for my '10 990-Adv. I had intended to install the mod before my Prudhoe Bay trip in June, but didn't end up doing it. I've had the parts listed on ADVrider Flea Market for several months, but no bites. Please search for it if you're interested.
(Apologies to the admin folks if I've broken a rule with this post... trying hard not to).
2014 Moto Guzzi Cali 1400 Custom
"Although motorcycle riding is romantic, motorcycle maintenance is purely classic." -- Robert Pirsig
"Beer is proof that God loves us and wants us to be happy." -- Ben Franklin
alshaffer is offline   Reply With Quote
Old 10-17-2013, 03:26 PM   #29
keener
Speed changes you.
keener's Avatar
Oddometer: 983
There is another option beside 690 fender.
Its made by Polisport.
see: http://www.polisport.com/motorbikes/produtos.php?ID=554
cheaper, stronger and slightly smaller (in my opinion) and has a groove to direct air to the rad.
I have used it on my bike for over a year and lots of highway and dirt miles, no problem what so ever. I didn't noticed any difference in highway compared with stock fender. I ordered it through my local bike shop.
04 ADV 950
keener screwed with this post 10-17-2013 at 03:34 PM Reason: added photos
keener is offline   Reply With Quote
Old 10-17-2013, 04:55 PM   #30
Top Bloke
Porky Rider
Top Bloke's Avatar
Oddometer: 111
Question Read the HOW
All taken from here (theres a 950 one as well)
1 7650801000030 KTM 690 Enduro Front Fender Black
1 4700109400030 FORK PROTECTOR L/S R/S 85SX 03
4 59001092050 SPECIAL SCREW M6X12.5 WS=8 .
4 0014060203 HH COLLAR SCREW M6X20 WS=8
4 54808020000 SPACER BUSHING
2 60013025100 - BRAKE HOSE GUIDE FRONT 03
2 60013025050 - RUBBER FOR BRAKE HOSE GUIDE03
Top Bloke is offline   Reply With Quote
Times are GMT -7.   It's 07:29 AM.
