Old 04-29-2012, 06:05 PM   #1
2GbeemerLUV OP
Bavarian Motor Pie
2GbeemerLUV's Avatar
Oddometer: 51
Question Pullin' the Plug
I'm trying to balance my carbs (bing 53). The bike seemed a little wobbly at idle so I decided to balance ala snobum by the shorting method. I started from 1 turn out on the air mix screw and 2 out on the throttle screw as a base. After the warm up, the left cylinder was responding to adjustments but the right cylinder was not affected by even drastic turns of the idle air screw. When i shorted the left, the right died. I pulled the plugs. Left cylinder plug was white/ weak, and the right was black as night. I changed the bad plugs. New plugs are Bosch platinum WR5DP, and gapped (.7mm). After only a few rounds of riding, shorting, and adjusting- I pulled the plugs again. Right was covered in soot and I couldn't take the popping and wobbles out of the idle.
Do I need to keep tinkering and practicing the method, or is there another problem? Not enough spark or coil pack/ wiring issue? Could it be a timing issue?
2GbeemerLUV is offline   Reply With Quote
Old 04-29-2012, 07:22 PM   #2
supershaft
because I can
Oddometer: 9,112
Usually what you are describing is caused by either the carb or leaking valves. If the float level and idle circuit is OK, chances are a leak down will reveal a leaking valve.
Old 04-29-2012, 07:59 PM   #3
2GbeemerLUV OP
Bavarian Motor Pie
Oddometer: 51
Thanks supershaft. What's the best way to determine which it is? Are we talking about a leaking valve cover gasket? There are no visible leaks on the head
Old 04-29-2012, 08:09 PM   #4
supershaft
because I can
Oddometer: 9,112
It takes a leak down tester to find a leaking valve. You need a air compressor to use one of those. It sounds like you don't have one. Get a manual and go through the carb's idle circuit and float level. Test that cylinder's plug cap or run it in pitch darkness and see if it is arcing right when it isn't idling right. If you don't run across the trouble by then get someone to check for a leaking valve.
Old 04-29-2012, 08:38 PM   #5
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
You might want to start by adjusting the valves.
ALWAYS adjust the valves before doing a carb balance.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Times are GMT -7.   It's 06:11 AM.
