Old 04-30-2012, 09:59 PM   #1
guzzimike OP
guzzimike's Avatar
Oddometer: 1,396
The Custardline
I think I've finally finished farkalling the F8
The lastest effort was to fit the TT supertank and get rid of the low front guard so I don't have a repition of this......
I do have to say that the problem was not as bad as on the Boxer GS
Anyway, thanks to WW Ronin and others on this forum, who did all the design work for me, I fabbed a bracket out of a plastic chopping board and mounted an aftermarket KTM fender to the beast.
The blanking plate at the front of the tank nose, where the beak usually bolts on was cut from a piece of ally sheet.
What do you think? I recon it looks OK.
The fork guards are braced from behind with a bit of light galv. sheet and fixed to the fork legs with a single screw.
A local brake bloke fabricated the dual brake lines, which come down from stacked banjos at the ABS block.
So here is the finished job.
Armageddon Was Yesterday, Today We Have a Problem
East is East & West is West 2008
http://www.advrider.com/forums/ad.php?t=400050
A Long Weekend 2009
http://www.advrider.com/forums/showthread.php?t=523893
All the Way to Nowhere & Back Again. 2010
http://www.advrider.com/forums/showthread.php?t=619683
Save 5 bucks on your Smugmug, use my discount code
hQo9Atub1N9jg
guzzimike is offline   Reply With Quote
Old 04-30-2012, 11:24 PM   #2
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Very nice. That tank looks fantastic. The paint blends it right in and really hides its size. Goes good with the Ohlins decal too. I also like that side shot with the orange rear sprocket (Supersprox?).
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 05-01-2012, 01:38 AM   #3
guzzimike OP
guzzimike's Avatar
Oddometer: 1,396
Thanks Dan and thanks for the inspiration, it made my work very easy.
Yep, it's a Supersprox, came with the Woody 18" rear
A Long Weekend 2009
hQo9Atub1N9jg
Old 05-01-2012, 07:04 AM   #4
SportFaller
Dirt dont hurt, MUCH
SportFaller's Avatar
Oddometer: 668
great looking bike! how do you like the ohlins?
"The chokers, and the chain saws, and the log trucks have been stilled, now spotted owls, and hippy gals, run freely through the woods!"
Bikeless in WY
http://www.dakotadualsportriders.com
SportFaller is offline   Reply With Quote
Old 05-01-2012, 08:40 AM   #5
SenorPeligro
Proper Naughty
SenorPeligro's Avatar
Oddometer: 1,962
Awesome looking 800!
It's just good clean dirt.
Video Antics
Where am I Riding?
Baja Blitz Yard Sale
SenorPeligro is offline   Reply With Quote
Old 05-01-2012, 05:18 PM   #6
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
I'm jealous. When I had Woody make my wheels, I stayed with the 17" rear which was a mistake as I am primarily interested in dirt. Oh well. Maybe I'll have him make me a 18" rear that I can use for dirt then switch my 17" to a more road biased tire. I wonder if I can switch out the 17" to 18" and back with the same length chain? I guess it would also depend on if I changed the size of the rear sprocket. Someone must have tried this. I guess I'll ask Woody if I ever get around to it.
Dan
Old 05-01-2012, 06:32 PM   #7
bodhizafa
How hard can it be?
bodhizafa's Avatar
Oddometer: 637
I'm about to. An 18 inch Woody wheel being built now, with a 45 tooth rear and the stock size chain. I did order a 15 tooth front sprocket too though. I'm a bit worried about the tire hitting my mud gaurd thing because the chain will be pretty short.
I'll have one if you do.....
bodhizafa is offline   Reply With Quote
Old 05-03-2012, 04:27 AM   #8
guzzimike OP
guzzimike's Avatar
Oddometer: 1,396
Dan, I have the stock 16/42 with the 2.5" x 18 and it's fine. I do a fair bit of gnarly stuff and honestly can't tell the difference in gearing. The narrow tyre (130) is a hoot as it allows a lot more throttle steering, at the expense of shorter tire life I fear.
I can't really qualify that, however, as I changed brands of tyre at the same time.
I think if I was doing it again I would opt for 3.5 x 18.
A Long Weekend 2009
hQo9Atub1N9jg
Old 05-03-2012, 06:28 AM   #9
guzzimike OP
guzzimike's Avatar
Oddometer: 1,396
A couple of other details for anyone planning to do the same.
I had a lot of trouble trying to source spacers. They seem to be unobtainium (at least in Oz)
So I made my own, bought a length of 20mm aluminium rod, cut into desired length, drill a hole down the middle with a hand held drill. I doesn't matter if you are not completely accurate, it's not a bush, it's a spacer.
The spacers you see in the photos above, between the guard and the cutting board are ~15mm.
There is also one with an 8mm bolt through it that goes right up through the horn bracket and has a nut on the top of it to hold the horn on. This one is about 20mm long.
Then there are 2 about 10mm long between the cutting board and the original plastic doofus.
See WW Ronin's thread for more details.
I am attempting to avoid cutting into the main fuel tank.
To that end, instead of running fuel lines from the TT tank to the bottom of the main tank I have run a line from the TT tank to the vent on the main tank in the hope that as the fuel in the main tank is used it will suck fuel from the TT tank.
When I get home from this swing I will test this idea.
Stay tuned
A Long Weekend 2009
hQo9Atub1N9jg
Old 05-03-2012, 08:18 AM   #10
johnparjr
johnparjr's Avatar
Oddometer: 203
Usually when people do these big mods I think they look fugly but yours looks good
johnparjr is offline   Reply With Quote
Old 05-03-2012, 01:52 PM   #11
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,398
Looks good!
Camel Tank auxiliary fuel tank for F series BMW twins. www.Camel-ADV.com
AT-BZ-CA-CN-CO-CR-CZ-CH-FR-DE-GB-GT-HN-IE-JP-KZ-KR-LI-LU-MX-NL-NI-PL-RU-SV-UA-US
Camel ADV is offline   Reply With Quote
Old 05-04-2012, 05:51 AM   #12
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,768
Now that is one sweet looking 800, very well done
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 11-01-2012, 11:42 PM   #13
guzzimike OP
guzzimike's Avatar
Oddometer: 1,396
The Custardline Lives!
After chucking it down the road in outback Queensland, I was left with a rather second hand looking F800GS.
However, with the help of the insurance & Touratech the Custardline lives to fight another day.
This time the tank came ready painted, so, although I liked the Sunset Yellow remember what a PITA it was to paint last time and decided to leave it as is, at least for the moment.
A Long Weekend 2009
hQo9Atub1N9jg
Old 11-02-2012, 04:11 AM   #14
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,612
looking smart!
Love it! great job :o)
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Old 11-02-2012, 08:11 AM   #15
petzi-baer
Oddometer: 184
What happened? - You needed a new tank - seems you had a bigger spill. I thought those tanks were indestructible. Did you come out alright?
take care
petzi-baer
petzi-baer is offline   Reply With Quote
Times are GMT -7.   It's 03:35 AM.
