05-01-2012, 01:28 PM
#1 |
do-over...
Oddometer: 115
Super noob question, Toaster panels
How do I get them off? Are they glued or something?
05-01-2012, 01:48 PM
#2 |
now in Mt. View, AR
Oddometer: 587
Ignore...I was thinking battery covers...sorry.
insert meaningless phrase here.... tennessee thumper screwed with this post 05-01-2012 at 02:05 PM |
05-01-2012, 01:50 PM
#3 |
Confirmed Curmudgeon
Oddometer: 3,904
Two screws on the tank Roundels, remove them and the Toaster panels will slide off. Snug the screws up real, real lightly-- if too tight, the enamel on the emblems will crack.
'73 R60/5 Toaster |
05-01-2012, 02:55 PM
#4 |
do-over...
Oddometer: 115
Ah..
Thanks,
I feel I should have been able to figure that out... |
05-01-2012, 03:05 PM
#5 |
Oddometer: 901
Not really, it's just such a small item noone seems to point it out. If I remember correctly they slide out toward the forks.
05-01-2012, 03:09 PM
#6 |
Mad Scientist
Oddometer: 2,967
Are you going to run it with rubber knee pads? I just ordered a set from BMW and they are available for around $23.00 each.
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
05-01-2012, 03:22 PM
#7 |
do-over...
Oddometer: 115
Nah
I am going to make identical copies in Walnut and coat with a ICA finish maybe a 20 degree sheen. I thought I would look awesome with a white tank and seat.
05-01-2012, 03:27 PM
#8 |
Oddometer: 3,904
So you're going Woodie instead of Toaster?
Treat those Toaster panels with care... they could be worth some coin...
'73 R60/5 Toaster |
05-01-2012, 03:47 PM
#9 | |
Shit for brains
Oddometer: 4,883
05-01-2012, 05:29 PM
#10 | |
Oddometer: 815
Pete |
05-01-2012, 05:43 PM
#11 |
do-over...
Oddometer: 115
Yeah, West systems epoxy is pretty good stuff. Though I have had some spectacular results with the ICA solvent based 2k products for high use exterior applications. It is nearly indestructible with the look of a lacquer finish, seriously you cant scratch it. I have never sprayed West Systems Epoxy so It would be tragic if I f'ed them up after the time its going to take me to measure and draw them.
Maybe I'll do a WS sample, as its way less expensive. |
05-01-2012, 05:56 PM
#12 | |
Mad Scientist
Oddometer: 2,967
05-01-2012, 06:01 PM
#13 |
do-over...
Oddometer: 115
05-01-2012, 06:37 PM
#14 |
dont wish it, do it.
This will be good to see, i just finished making a rack for a 75/5 that has a new solo seat fitted and have some hardwood rails ready to fit once the bike is repainted Dover white and the rack is back from the powder coaters. I will post up some pics when its done.
05-01-2012, 06:50 PM
#15 | |
Oddometer: 45
Regardless of solid or veneer, please put me in the group of folks interested in seeing the results. ;)
