Old 05-06-2005, 10:56 PM   #1
Gerg OP
Cupcake
Gerg's Avatar
Oddometer: 8,454
'05 KTM Carb Needles
I know, I should have taken a picture BUT you cant move the needle on the '05 carb. There is a clip and two slots above the clip but below the clip is a nylon bushing that I could not budge! So I reverted to my Harley Days and dug out my #4 washers and put two of them in to raise the needle.
I also did a canisterectomy. That was an adventure. I broke a bolt trying to get the side panel off. The one that holds the rack. Both sides were buggered up. Luckly there was enough sticking out that I could get a pair of vice grips on it. A little penetrating oil and it came out. The bolts almost look like they were bottomed. The last few threads on both bolts were really buggered.
And I've added a Powerlet to run my air compressor. Now I get to put it all together tomorrow. What fun
Anybody have the detail of the airbox mod. I cut a 2" square hole in the airbox cover and put a chunk of UNI Filter in it. When I reassembled it all it seems like there is no point to doing that. The side panel fits WAY to close to provide any air to that opening
Do I need to cut a hole in the side panel as well as the airbox cover?
Gerg
Greg
Certified Ole Fart
Gerg is offline   Reply With Quote
Old 05-06-2005, 11:01 PM   #2
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Gerg
The washer is a real tight fit on several of the BSTs I've run into. The needles are hard, so you can apply a good amount of pressure without fear of breaking one.
So... how's tricks?
creeper is offline   Reply With Quote
Old 05-07-2005, 12:16 AM   #3
Mack
Gone, but never forgotten. RIP, Mack...
Mack's Avatar
Oddometer: 3,797
Anybody have the detail of the airbox mod........
Gerg
Pic thanks to Arch
KTMtalk.com seems to be down tonight, but if you search the hardparts listings, you should be able to find the screened airbox cover.
EDIT: Site is back up:
Hard Parts Catalog: Radiator Air Box, and Filters
Part Number: 58406003200
Description: AIRBOX COVER RACING LC4 640
Retail: $29.95
Österreichische Motorräder und deutsche Autos. Wie wundervoll kann das Leben sein
Mack screwed with this post 05-07-2005 at 12:35 AM
Mack is offline   Reply With Quote
Old 05-07-2005, 06:11 AM   #4
Gerg OP
Cupcake
Gerg's Avatar
Oddometer: 8,454
When you run that cover you don't put the side panel on?
Thanks for the pics!
Gerg
Greg
Certified Ole Fart
Old 05-07-2005, 06:31 AM   #5
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,247
weird, can't imagine they did that on purpose... the replacement needles from Sudco are listed on a thread somewhere cugino pegaso listed them i think - nobody has tried them to my knowledge. if you got 65 bucks burning a hole in your pocket the north bay area here in cali has a shop called factory pro that makes a custom Ti needle for the BST
doesnt the one on the dash work? I used it w/ someones BMW pump at WARPED.
Gerg
Gerg
Sommer KTM has tested with the side panel back on - air gets in there don't worry. Others like PASSMORE have the unipod filters going all the way thru the side panel - the question is getting the airbox and pipe mods balanced (w/ the carb tuning). If you do weird stuff like Passy then you will have to tinker with the extent of airbox modification, the carb tuning, and the pipe setup. If you stay in more known territory then others work will get you close.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 05-07-2005, 07:10 AM   #6
AceRph
Affluenza Free!
AceRph's Avatar
Location: Where the stupidest people on earth run things
Oddometer: 24,666
Geez gerg! How many thumbs to do you have on one hand?
AceRph is offline   Reply With Quote
Old 05-07-2005, 07:58 AM   #7
Gerg OP
Cupcake
Gerg's Avatar
Oddometer: 8,454
Well, I got that nylon shim to move this morning. Amazing what you can do with clean (and rested) hands
Now the search for some mainjets (sound familair Meat?).
She's a bit flat when you really try to honk it. There should be more grunt above 5500 RPM.
Impatiently waiting for my IDS2 quiet core (and the local Hardware store to open so I can finish putting her back together).
Gerg
Greg
Certified Ole Fart
Old 05-07-2005, 08:06 AM   #8
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Gerg
Harley shop... same as Mikuni HSR 40/42/45... bla bla bla
So... how's tricks?
Old 05-07-2005, 08:13 AM   #9
Gerg OP
Cupcake
Gerg's Avatar
Oddometer: 8,454
Headed there at 9:00. I think I'll ride big orange
Gerg
Greg
Certified Ole Fart
Old 05-07-2005, 09:07 AM   #10
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,743
Gerg
Assuming your relating to the inner panel not the outer right? In that case discard the inner panel.
Also make sure you use something around the circumfrence of the new airbox vent. The new vent does not sit flush on the airbox and requires (improvision)
I used some hard foam to prevent the cover from tweaking when you screw it down, it also eliminates larger particles from sneaking into your airbox.
Renazco is offline   Reply With Quote
Old 05-07-2005, 09:14 AM   #11
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
What James said. This is one I made from CF plate... the foam on the back is 1/4" closed cell. James knows way more about foam than I do, but this stuff is semi-soft and "conforms" to the airbox edge.
So... how's tricks?
creeper screwed with this post 05-25-2006 at 07:21 PM
Old 05-07-2005, 09:48 AM   #12
Renazco
Renazco's Avatar
Oddometer: 4,743
What Scofflaw ( ) said. This is one I made from CF plate... the foam on the back is 1/4" closed cell. James knows way more about foam than I do, but this stuff is semi-soft and "conforms" to the airbox edge.
You lost me babe,, I was alluding to the KTM airbox mod
btw, the closed cell is not allowing any air in
Old 05-07-2005, 09:58 AM   #13
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
The closed cell stuff is the gasket... the air goes thru the UNI pop-ins.
So... how's tricks?
Old 05-07-2005, 10:04 AM   #14
Renazco
Renazco's Avatar
Oddometer: 4,743
O.K. I studied the photo's again and see the foam layer,, I was expecting to see something around the circumfrence but looks like you just lined the whole thing..
I also assumed you were alluding to using closed cell in place of the uni filters, my bad Doc
Old 05-07-2005, 10:08 AM   #15
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
No biggie... it's easier to glue down a big panel of foam than a narrow edge gasket. When I was makeing rectangular screened ones, I did the same thing... used the foam to hold the screen in place.
HSR42?
So... how's tricks?
Times are GMT -7.   It's 03:46 PM.
