Old 05-02-2012, 08:40 PM   #1
domains OP
domains's Avatar
Oddometer: 162
Drilling main jets bigger
I'm working on a xr650L motor and biggest jet I can buy is 155 but I want to go 160
Is there a drill bit I could buy for 160?
domains is offline   Reply With Quote
Old 05-02-2012, 09:13 PM   #2
domains OP
domains's Avatar
Oddometer: 162
Can I buy a 0.60mm. drill?
Old 05-02-2012, 10:25 PM   #3
PistonPants
Crankcase Scavenger
PistonPants's Avatar
Oddometer: 454
I might have a 160 from out of a dynojet kit. The kit comes with 155 and 160 mains.
Piston
PistonPants is offline   Reply With Quote
Old 05-02-2012, 10:43 PM   #4
Beezer
Oddometer: 5,883
there is a bit that size.... but I'm not sure thats what you want to do.... mostly because I'm not sure how they measure the jet size. I do know that Mikuni, Dynajet, and Kehin all have different sizes for the same number:
Width------Kehein # -- DynoJets # -- Mikuni #
0,0350---- 92,5--------- 92----------- 86,3
0,0360---- 95----------- 94----------- 88,1
0,0370---- 97,5--------- 96----------- 90,0
0,0380---- 100---------- 98----------- 91,9
0,0390---- 102,5------- 100---------- 93,8
0,0400---- 105--------- 102---------- 95,6
0,0410---- 107,5------- 104---------- 97,5
0,0420---- 110--------- 106---------- 99,4
0,0430---- 112,5------- 108--------- 101,3
0,0440---- 115--------- 110--------- 103,1
0,0450---- 117,5------- 112--------- 105,0
0,0460---- 120--------- 114--------- 106,9
0,0470---- 122,5------- 116--------- 108,8
0,0480---- 125--------- 118--------- 110,6
0,0490---- 127,5------- 120--------- 112,5
0,0500---- 130--------- 122--------- 114,4
0,0510---- 132,5------- 124--------- 116,3
0,0520---- 135--------- 126--------- 118,1
0,0530---- 137,5------- 128--------- 120,0
0,0540---- 140--------- 130--------- 121,9
0,0550---- 142,5------- 132--------- 123,8
0,0560---- 145--------- 134--------- 125,6
0,0570---- 147,5------- 136--------- 127,5
0,0580---- 150--------- 138--------- 129,4
0,0590---- 152,5------- 140--------- 131,3
0,0600---- 155--------- 142--------- 133,1
0,0610---- 157,5------- 144--------- 135,0
0,0620---- 160--------- 146--------- 136,9
0,0630---- 162,5------- 148--------- 138,8
0,0640---- 165--------- 150--------- 140,6
0,0650---- 167,5------- 152--------- 142,5
0,0660---- 170--------- 154--------- 144,4
0,0670---- 172,5------- 156--------- 146,3
0,0680---- 175--------- 158--------- 148,1
0,0690---- 177,5------- 160--------- 150,0
0,0700---- 180--------- 162--------- 151,9
0,0710---- 182,5------- 164--------- 153,8
0,0720---- 185--------- 166--------- 155,6
0,0730---- 187,5------- 168--------- 157,5
0,0740---- 190--------- 170--------- 159,4
0,0750---- 192,5------- 172--------- 161,3
0,0760---- 195--------- 174--------- 163,1
0,0770---- 197,5------- 176--------- 165,0
0,0780---- 200--------- 178--------- 166,9
0,0790---- 202,5------- 180--------- 168,8
0,0800---- 205--------- 182--------- 170,6
0,0810---- 207,5------- 184--------- 172,5
0,0820---- 210--------- 186--------- 174,4
0,0830---- 212,5------- 188--------- 176,3
0,0840---- 215--------- 190--------- 178,1
0,0850---- 217,5------- 192--------- 180,0
0,0860---- 220--------- 194--------- 181,9
0,0870---- 222,5------- 196--------- 183,7
0,0880---- 225--------- 198--------- 185,6
0,0890---- 227,5------- 200--------- 187,5
Beezer is offline   Reply With Quote
Old 05-02-2012, 10:51 PM   #5
Tosh Togo
Oddometer: 1,594
Yes, you can- http://findnsave.elpasotimes.com/Pro...h-Jobber-Drill
But the proper size jet is better, and in this case cheaper than the drill's cost. With itty-bitty holes that size, the finish surface of the hole and any burrs at the entry/exit can change the flow. If you still want to drill, find someone with a set of wire-gauge drills and have them do it for you.
Tosh Togo is offline   Reply With Quote
Old 05-03-2012, 03:56 AM   #6
debaisley
debaisley's Avatar
Oddometer: 1,424
any size jet you could want http://www.jetsrus.com/a_jet_kit_dir..._1992-2009.htm
debaisley is offline   Reply With Quote
Old 05-03-2012, 05:55 PM   #7
Weldit
Weldit's Avatar
Oddometer: 336
160 actually is very close to a drill size in the mega drill index - the one with number and letter drills
if you have a set or access to a set like that then give it - what can you hurt the 155 is not right
I have drilled jets with good luck - just file off the original # or scratch it out so you know it has been modified
if you have a digital vernier caliper you can measure the drill and get the one that is the right size
but jets are cheap so buying a 160 is only going to cost $5.
I was working on an old scab xr and didn't want to spend any $$$
160 is .160 mm or something like that - it will be obvious when you measure the drill that fits in your 155
now drilling out pilot jets is a much more involved process !!
as they are only .6mm = very small hole - had to use a torch tip cleaning file & strands of wire for measuring size
not recommended - except for the really impossible to find jets - and then get your self a set of jet files.
but the old scab XR runs like a scalded dog now and cost Nothing but time and patience !
'11 Dakar 990
Weldit is offline   Reply With Quote
Old 05-04-2012, 06:39 AM   #8
elsalvadorklr
southern xr rider
Oddometer: 4,154
i used acetylene torch cleaners/reamers used to clean the tips of the soldering torchs.
with mixed results,
I used it to ream a few small pilot jets I had on my 88 xr600....they are the same(close) to the jets in the xrl cv carb
the issue I had was not the reaming part but actually guessing what size I had after reaming and in the end I had some jets shipped to me while I played aroud with my jets here with the reamers.
the main jets you could use a jewelers drill as the hole sizes are bigger
again I used the jets I had and reamed the small ones to the size I thought I wanted.
In the end it wasnt as useful as I would of thought,
My recomendation is to use keihin jets and buy a bunch so you can play around with them.
cheers
elsalvadorklr is offline   Reply With Quote
Old 05-04-2012, 06:42 AM   #9
elsalvadorklr
southern xr rider
Oddometer: 4,154
jaja we did the same thing use the torcj cleaners then find dffernet wire gauges to gauge what size you had reamed to...I did this with a 58 pilot jet, very small and wanted to get a 61 or so approx jet size...
its very hard to do since the reamer does not leave a smooth finish and THATS the issue, I tried to polish the hole with nylon wire gauge after and some polishing compound but the result was a size 62 or so pilot or more which I had already.
Old 05-05-2012, 05:06 AM   #10
hotwheels
Oddometer: 57
Drills for jets
I've been drilling jets, both main and idle for years with great results ! You need to get two sets of drills both numbered, #'s 1 to 60 and #'s 60 to 80. The #'s 60 to 80 are very small you can't chuck them in a drill. I hold the drill in a small vice and spin the jet in my fingers to drill the hole. I go slowly I find the smallest drill that WON'T go thru the jet and drill with that one, if the mixture screw won't tune, I go larger until it does. You need to learn to tell when the mixture tunes properly, one way too rich, the other way too lean. When the screw tunes both ways the idle jet is the right size. The main jet is differnt and you need to tell when the mixture in either too lean or too rich by how the engine sounds at wide open throttle. Remove the burrs after drilling the jet by taking a much larger drill, but that fits into the jet and lightly dress of the burr caused by the original drilling. This method is quite useful when jets are just not available (Yamaha SRX250).
hotwheels is offline   Reply With Quote
Old 05-05-2012, 08:28 AM   #11
markk53
jack of all trades...
markk53's Avatar
Oddometer: 9,077
As is clear it is all about surface finish in the jet as to the flow gained. The fuel is fluid and fluid dynamics come into play. A rough jet hole surface could actually cause less flow than the size where the jet started. Example, a 2" corrugated plastic tube used on a defroster system in a piece of heavy equipment actually had a functional flow rate about 1/2" diameter due to the speed of the system and the turbulence of the corrugation of the tube along with other minor factors. With a smoother manifold the flow was significantly increased. (Thus the reason for the K&N tubes used on cars vs the accordion type tubing.)
Best is if you can find a jet of the size needed on-line. But if drilling is necessary, be very aware of he ID surface condition after drilling. Use a magnifier to look at it if you can do so.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 05-05-2012, 11:32 AM   #12
Beezer
Oddometer: 5,883
if you look at my post #4 you'll see a chart that equates brands by size. This is very handy if you know the manufacturer. years ago I discovered that the guy behind the parts counter will sell you jets without knowing what they really are. This will drive you nuts if you are trying to jet and buying different brands. Long and short of this story is that I had a mix of jets. I ended up sorting them by flow with a home made checker. The first was a 20cc pipette & I simply timed the flow 5-6 times and averaged the result. Then later I used a differential pressure tester (leak down) rigged to a block. Put in 80 psi & see what the other gauge says. It only gives relative results, but thats better than shooting blind.
Old 05-05-2012, 12:07 PM   #13
markk53
markk53's Avatar
Oddometer: 9,077
Quit making sense!
Good idea. It would let you know if you hosed up when drilling a jet too.
Mark - klx678
Old 05-05-2012, 12:19 PM   #14
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,944
what your looking for is called a hand operated pin vise using wire gauge drill bits. available at a jewelry supply house.
Hurricane Bob is offline   Reply With Quote
Old 05-05-2012, 12:57 PM   #15
tkent02
Oddometer: 2,802
Or you could just drop $2 and buy a jet. How silly.
tkent02 is offline   Reply With Quote
Times are GMT -7.   It's 11:22 AM.
